what capacitor should I purchase for LCD display PCB?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I want to fix Video door phone which works its doorbell but it is not able to display any screen.
    So I disassembled its plastic case and I detached FPC film cable from LCD display in order to inspect LCD display's PCB
    I measured ESR resistance of all smd capacitor on this PCB and I noticed that there is some SMD capacitor which has high ESR value(48ohm 50V 0.47uf,15 and 28 ohm 50v 3.3uf,10 and 8 ohm 35v 10uf)
    I desoldered this 5 suspicious SMD capacitor like below screenshot.
    images2.imgbox.com/51/b8/8WVZwDpV_o.jpg
    But I cannot identify specification of desoldered capacitors below screenshot. What capacitor should I purchase for LCD display's PCB?
    • 31099
    any caps higher than 1uf you can use any good low impedence cap like panasonic FR or rubycon ZLJ etc
    for 1uf or under it's not easy to find good electrolytics so use a polypropylene film cap
    • chth96
      • Nov 2022
      • 118
      • indonesia
      Is it possible to use KMG Series capacitor for over 1uf smd capacitor on LCD display's PCB?
      And As far as I know, polypropylene film cap is non-polarized. Is it possible to use 0.47uf non-polarized film cap instead of smd or dip 0.47uf polarized capacitor?
        master hoarder
        • May 2008
        • 12175
        KMG is UCC's general purpose series... but even these should be better than bad caps with 5+ Ohms of ESR.
        Film caps (be it PP or PE) are pretty much always fine to use as replacements in places where low capacitance (under 1 uF) electrolytic caps resided before. Both PP and PE tend to have better high-frequency filtering than electrolytics do.
        • chth96
          What capacitor should I purchase for Power Supply of obsolete game consoles?
          by chth96
          hello.
          I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
          It hardly ever freezed after I finished to recap all of caps in the power supply.
          But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
          To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
          It seems that quality...
          10-01-2024, 08:14 AM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
