The "Indestructible iMac" v2.0 - Poly revision 2
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Alright, here we go again!! This is a first generation iMac G5 (the last one was a second gen). This was one of the donors given to me by a fellow forum member here. I wanted to get one cranked out right away, just so he doesn't think his contributions were for nothing!
    The changes in polymer caps from the previous one are that I used 1800uF 6.3v Nichicon LG series caps in place of the 1800uF 6.3v lytics that it originally had. I used 1500uF 6.3v UCC polymers in the last one, and it worked without a hitch, so I didn't foresee any reason why I would have any trouble here. I did one of the 20" ones first. My plan was to do both poly revisions on each size iMac. When the deal was worked out with the donor, I didn't have the other 20" I used in the other experiment, so he donated 2 of each. Now, I have a spare 20".....
    Anyway, onto the project:
    Getting ready to start:
    Back removed. The motherboard had no bad caps, amazingly enough, there were actually some good Nichicon HN series caps in it. The date code was 0422 (made in the 22nd week of 2004), they should have failed by now! Pre-testing, this system actually would POST.
    Crack open the Ac-Bel PSU (might as well start at the beginning), and tadaa!! there's the bad caps! I'm surprised it would even POST like this.
    Recapped in Rubies:
    Junk L-TEC caps:
    Revived PSU:
    Now onto the logic board. I was shocked to see the original caps were still good, even the rubycon's. I've seen these heaters cook rubycon and UCC lytics many times.....I was amazed beyond words that the HN's were still good as well, those would fail under normal operating conditions, forget about extremely heated conditions. All the caps on this board were original, it had not been recapped previously.
    The 'miracle' nichicons:
    Unbloated rubies:
    I'm getting to the point I can have one of these apart in about 10 minutes....
    ...and the polymer goodness!
    Nichicon LG series:
    Some 330uF 16v UCC's replacing the 1000uF 16v HN's:
    Back together:
    It POST's:
    ...and OSX being installed:
    it's up and running now, and another iMac polymodding experiment seems to be successful!!
    Keep in mind, the primary purpose of these experiments is to see what will play nice in these systems as far as polymers go. Longevity testing is rather nill, as in a heat-stressed environment, polymer caps will outlast even the best lytics on an exponential scale, so that's not a mission objective here. By the time the polies would fail, we'd all have long white beards anyway. I just wanted to make sure that the poly mods and alternative capacitor values didn't compromise stability in any way.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: The "Indestructible iMac" v2.0 - Poly revision 2
    Here's the same rework above, except done on a 17" model this time. The 20" seems to be a little easier to take apart, but they're both pains in the asses.....worth the effort though.
    Anyway, onto some pics:
    PSU with more toasty L-TEC craps:
    Logic board with popped UCC caps:
    Some poly goodness:
    If you know anything about aviation, you know what the term "3 green" means.....in iMac talk, it means 3 green LED's and a working system!
    OSX 10.5 installed (1.8GHz 1GB ram, runs great)
    With this experiment drawing to a close with great success, keep your eyes peeled for the official release of the Badcaps.net iMac full polymer kit!
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      maybe you should sell a PSU recap kit as well... if it is not pre-included already.
      sigpic
      (Insert witty quote here)
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        put a really bold note in the descrition of the kit.include a link.
        seems every one i have recapped had a sick psu too.
        i would do the board and it would be fine here.customer reinstalls it and its about as stable as charles manson.send me the psu and its blown to hell.if your cap kit customers are willing to do the mobo the psu is easy.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Seems AcBel has a million different revisions of these PSU's. I have 8 of them (donor sent 4 spares with the systems) and nearly every one of them has a different cap configuration... I never realized there was a difference between the 20" and 17" PSU's.... The 20" PSU is a little thicker, but even PSU's intended for the same size iMac's are different internally. Kind of hard to make a kit for the PSU...
          Team : 49813
          Join in!!
          Team Stats
          • seanc
            • Nov 2008
            • 1319
            Have you got an Acbel 614-0334 there?
            If you've got one that's dead to the world I'd be interested to know what the fix is. I've got a dead one.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              I'll have to look and see. I didn't look at the model numbers of them, I just recapped them all, and they all worked. I have 4 spare acbel imac PSU's, 2x 17" ones and 2x 20" ones.
              Team : 49813
              Join in!!
              Team Stats
              • seanc
                • Nov 2008
                • 1319
                Mine's from a 20". I actually have an identical working power supply, I just don't want to risk opening it, they're too damn expensive!
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  true but you and i are spoiled by just opening the bins and grabbing what is needed for the job at hand.i noticed several revisions of these but since i dont have time to make kits i never thought of the difficulty in making one.
                  i will track and post the parts list on the next ones.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    I just looked at the 2 spare 20" units I have, both are 661-3350.
                    KC8 speaks the truth, sometimes I forget how spoiled I am. I just open the bin, and all the parts I need are right there.... lol
                    Team : 49813
                    Join in!!
                    Team Stats
                    • godonr
                      • May 2009
                      • 111
                      Is it from a first generation 20" G5? When you say "dead one," do you mean no 5vsb on 9 and nothing on 22 when it's plugged in but not jumpered (15 to 16)? The 661-3350 replaces all the variations Apple put in those first machines. Apple's GSX doesn't even list the older numbers... just the 661-3350. If you have recapped already, check the underside and look for Q1 near the PWM. An E-C short will keep the supply from turning on.
                      • meanderer
                        • Jul 2010
                        • 50
                        What's the reason to lower the caps value from 1000uF to 330uF?
                        What functions do they serve in the circuit that allows such swap?
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          those are the 12V input filter caps.
                          they're basically additional filter caps for the power coming from the PSU..
                          most normal computer mainboards with polymer caps from the factory have such low values as standard.
                          haven't seen any new(-ish) PC mainboard with 12V input filter poly caps with higher values than 470uF 16V x4
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Topcat, why do you only sell 1500uF polys as part of kits and not separately? I use 1500uF polys on motherboards not mentioned in your kits (Like in my thread on the GA-7VA-"DS3L")
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              Thats because I don't have a huge stock of them yet. When I get my stock built up, I will then sell the individual caps.
                              The iMac G5 full poly kit is officially available!
                              https://www.badcaps.net/store/produc...roducts_id=108
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                IIRC, ESR is a lot more important than capacity in switchmode supplies. If you can get lower ESR caps you can make it with lower capacitance and still keep the same level of ripple. Some might argue that transient response may be compromised because the caps are too small, but for one this is a computer and it doesn't have high level transients, and secondly it's the job of the control loop to keep voltages stable during those transients.
                                A working TV? How boring!
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  this is a dumb question, but that imac looks EXACTLY like the beta tester you sent me... is that the same one? do you remember?
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    I think it is.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      ok then.
                                      cool.
                                      sigpic
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        so i can use mobo-grade caps in a psu with using lower-capacity as well? cool!
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
                                        • tommy97
                                          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                          by tommy97
                                          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                          Any ideas what might've...
                                          04-20-2024, 04:48 AM
                                        • CapLeaker
                                          Poly VVX-250 VOIP POE problem not booting fix
                                          by CapLeaker
                                          I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                          Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                          11-25-2023, 10:46 AM
