Help! need to solder the wire to the TAB!
  • capwizard
    • Jun 2016
    • 1991
    55" TV has water damaged on the TAB, after I changed two shorted SMD capacitors, now TV has picture but the TAB has 8 etched copper wires. (Before TV was cut off and T-con board was hot.)
    My question is : it is very hard to solder the wires back to the TAB which took me whole day even I was using stereoscope............
    PS: I Apologize for the blurry pictures more better pics on the way.
  • capwizard
    • Jun 2016
    • 1991
    Re: Help! need to solder the wire to the TAB!
    My situation is same as this video but I did not see he finished the job?
    Recuperando flete LCD microscópio 500x Eletro Máquinas Wolinger tec.
    https://www.youtube.com/watch?v=E-vkCWtpl_8
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      can you not jumper wire around the ribbon cable ?
      • capwizard
        • Jun 2016
        • 1991
        I try to use a junk piece of the ribbon cable to do the job
        First I put solder on the junk TAB then try to overlap them together and put heat try to bond them together, because their do have the same spaces.
        The problem is the TAB piece is too small to heat it up. I cant use the gas torch, MIG or TIG................
        • llonen
          • Sep 2014
          • 495
          • hampshire
          I will have a play with this when I get to back to the workshop as I could do with the practise, I do wonder about the long term reliability of these types of repair though. If you are able I would recommend coming from the via's. The other problem is in exposing the copper track's from the reverse substrate side you are effectively removing most if not all the supporting material.
          I will however put some pic's up of the results.
          • srhofmann
            • Aug 2016
            • 135
            • usa
            Pelco 16045
            • capwizard
              • Jun 2016
              • 1991
              Thank you, I use 400'c iron still can't transform heat to the top of the coupon tape. I try to bond the junk pre solder TAB to the PCB instead of using wires to repair.
              PS: If this method works, we can fix most water damaged TV.
              • cpt.charlie
                • Sep 2013
                • 270
                • Spain
                Mmmmm, maybe you could use some conductive silver paint and some tape to avoid any shorts while applying the paint.
                • capwizard
                  • Jun 2016
                  • 1991
                  Thank you cpt.charlie That is a very good idea but which conductive silver paint I should make.
                  Make Conductive Silver Ink (complex ion based)
                  https://www.youtube.com/watch?v=EBlqPS8boLI
                  Conductive Silver Ink from a Ballpoint Pen
                  https://www.youtube.com/watch?v=dfNByi-rrO4
                  Expanded Version: Brew Your Own Conductive Ink
                  https://www.youtube.com/watch?v=mF_Z8RUZjJE
                  $1 DIY Conductive Ink and Paint (Non Toxic, homemade, cheap!) - Makerboat.com
                  https://www.youtube.com/watch?v=W_ouYLeIkoo
                  Super Conductive Carbon Ink
                  https://www.youtube.com/watch?v=aTQIr8SzIPk
                  How To Make A Conductive Ink
                  https://www.youtube.com/watch?v=WR7SHPGGQ34
                  How to make a Conductive ink - Acrylic based
                  https://www.youtube.com/watch?v=Gdqkgkee0Ok
                  conductive polymer
                  https://www.youtube.com/watch?v=uUlmncSK-xg
                  How to make a Conductive ink easy and cheap
                  https://www.youtube.com/watch?v=Ik9hXkjX15A
                  • srhofmann
                    • Aug 2016
                    • 135
                    • usa
                    conductive polymer
                    Good luck making reliable conductive paint. It needs to be flaked silver so there is plenty of overlap for conductivity, don't forget there's a binder agent to hold the silver together and to the substrate.
                    Pelco 16045 is what you want to use on something that's flexible like kapton tape or a flexible tab bond on a panel.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      I would think about using conductive epoxy not paint. Its not cheap though.
                      • capwizard
                        • Jun 2016
                        • 1991
                        Pelco 16045 : PELCO Isopropanol Based Graphite Paint
                        Conductive graphite paint, primarily designed for SEM sample preparation. The graphite flakes, with an average size of 1µm, are bonded by a cellulose resin with isopropanol as diluent. Good bonding properties on most materials. Graphite content is 20%. Ideal to mount samples on sample stubs or to make a conductive path to the sample surface. Let fully dry before using in the SEM. Maximum service temperature: 200° C. Use Graphite Paint Extender to dilute when needed.
                        " would think about using conductive epoxy not paint. Its not cheap though."
                        Pic1 : Yes, Not cheap, 1 oz is $276.9.
                        https://www.tedpella.com/adhesive_ht...Comparison.htm
                        • capwizard
                          • Jun 2016
                          • 1991
                          No time to built it myself. Customer is waiting for his TV. So, I ordered this from Amazon to try it. Will let you guys know the result.
                          5 pieces 0.3ML Silver Conductive Wire Glue Paste For Electronics Repair Applications
                          https://www.amazon.com/pieces-Silver.../dp/B00FEFTHK0
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Did you read the comments or look at the shipping times ? It looks like it's coming from China.
                            Conductive epoxy doesn't have to be that expensive.
                            • capwizard
                              • Jun 2016
                              • 1991
                              Oh Oor I did not pay attention to it, i'm in a rush.
                              If you don't mind the watery consistency and the fact that you may not get all that you paid for, go for it.,Although it is very conductive, there are two problems with this particular product
                              1. It's not very viscous compared with similar products purchased elsewhere. It makes it very difficult not to short out pins on SMD devices.
                              It's more of a paint than a paste.
                              2. All the syringes had significant amounts of material already squirted out into the needle covers - see attached picture.
                              You won't be getting the usable amount that you thought you paid for. They are shipped in a bag, rather than a box, so I assume that the plungers get depressed during shipping and the material squirts out.
                              I sent a message to the vendor about this but they never replied..
                              Didn't Work At All:
                              Its a great idea, but I let it dry for over 24 hours and it never hardened. It comes in nice syringes with additional tips, but they weren't need since the "glue" never hardened, so I could use it over and over if I wanted......
                              • srhofmann
                                • Aug 2016
                                • 135
                                • usa
                                Just hit the website. The replacement for 16045 is 16062 which in small quantities is 45 bucks and flexible. The epoxy that you said was 276 isn't flexible.
                                As an alternative you could try a rear window repair kit. I would try it first on some plastic tape and see if it's flexible and stays conductive.
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  you're A genie, I never thought about that, a rear window repair kit, Defroster Repair kit?
                                  http://www.frostfighter.com/frost-fi...r-comments.htm
                                  ebay : Auto Car Truck Defroster Tab or Grid Repair enough to do 10 or more repairs US $52.95 More expensive!
                                  • pudgi300
                                    • Nov 2008
                                    • 35
                                    The repair you are trying to do is very tough. I also have microscope to do repairs. I have seen damage to jumpers from water that cannot be repaired because the jumper got burnt. Sometimes when the jumper is in good shape you can use:
                                    3M conductive adhesive 970312
                                    I bought some a few years back on ebay. It is a doubleback tape that has little conductive strains in one direction only (everything in the intrack direction).
                                    It is expensive so the guy sells it in smaller pieces.
                                    • cpt.charlie
                                      • Sep 2013
                                      • 270
                                      • Spain
                                      That's basically conductive paint, keep in mind that there are different qualities.
                                      • pudgi300
                                        • Nov 2008
                                        • 35
                                        The 3M conductive adhesive 9703 is doubleback tape that has conductive strips going one way. It is not paint
                                        • Dannyx
                                          Wire twisting tool for small wires - ideas ?
                                          by Dannyx
                                          Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
                                          08-23-2020, 06:29 AM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • kalemaroni
                                          Dell DC Brown wire
                                          by kalemaroni
                                          There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                                          08-26-2025, 10:10 AM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
