HP officeJet 8012e ... A printer update will be installed to fix this problem
  • Artefil
    • Sep 2023
    • France
    One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
    On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
    The screen displays the following message :
    "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
    But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
    Have you ever faced this problem, how do you solved it (except sending back to HP, because the printer is no more under warranty), is there a solution using the back USB connector forcing an update to be pushed into the printer ? Any solution or beginning will be great.
    Artefil.
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • re-atari
    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
    by re-atari
    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
    02-03-2025, 06:49 PM
  • L3git
    HP Officejet Pro 8620 Printer (Doesn’t print due to “failed or missing print head”)
    by L3git
    Hi all, first I'd like to say thank you for taking the time out of your day to help me. So I have this HP Officejet Pro 8620 Printer that doesn't want to print at all. Once I turned the printer on I'm given this message “the print head appears to be missing, not detected, or incorrectly installed. Error Code: 0xc19a0013.” I was wondering if it's still worth repairing and if so what can I do to fix it? I've attached pictures of the message and the printer itself. Thank you again!...
    09-19-2022, 03:28 PM
  • pkslowk
    Debug Card Error Code and Solution
    by pkslowk
    Sr. Motherboard Debug Error Code Solution
    1 Intel 845 E9 Bios Related Problem
    2 Intel 845 D4 CPU Socket Related problem
    3 Intel 845 37 Bios Related Problem
    4 Intel 845 7C Bios Related Problem
    5 Intel 945GCPE 34 Bios Related Problem
    6 Gigabyte 845 2 Ram Related Problem
    7 IBM Server A6 A7 Ram Mismatch Problem
    8 Asus 845 29 CPU Related Problem
    9 Lenovo I946 97 C-Mos Jumper related
    10 Gigabyte 845 A0 CPU Related Problem
    11 Asrock G31M-VS D7 Bios Related Problem
    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
    01-28-2021, 12:51 PM
  • Nozle Gmail
    Lenovo M90q Gen 4 Problem Bios crash update
    by Nozle Gmail
    I have a Lenovo M90Q Gen 4, with Intel 13500.
    Yesterday, the BIOS was updated to the latest version, and for some reason, the process failed. Now, the computer displays nothing on the screen, and approximately 20 seconds after turning on, it immediately shuts down again.
    I tried copying the USB BIOS from Lenovo's website to a FAT32 USB drive and setting the motherboard jumper to CMOS mode (pins 2 and 4), even though the manual indicates maintenance mode, but I haven't found any jumper with that name.
    When I insert the USB drive and set...
    05-31-2025, 08:28 AM
