TS100 Tips - Recommended Vendor?
  • clearchris
    • Dec 2013
    • 687
    I have a pinecil on the way
    https://www.pine64.org/pinecil/
    but it comes with a conical tip. Going to have to replace that with a chisel tip. Anyone have any good ali vendors for ts100 tips?
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: TS100 Tips - Recommended Vendor?
    I've used tips from aliexpress. About 5€ a piece. Finer tips were 10€/piece I think. They all work great.
    • estabilito
      Tips geting oxidized when using wick
      by estabilito
      Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
      i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
      Temperature: 350-365celsius
      station: jbc cd-2bqe
      Wick: edsyn
      flux: warton hf rework jelly
      Do you have any tips?...
      04-12-2025, 11:55 AM
    • corrize
      Quality solder iron tips and Kapton ?
      by corrize
      Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
      I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
      Do you have brand of qually tips pls ?
      Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
      05-24-2021, 11:35 PM
    • aurgathor
      Recommended replacement cap & voltage
      by aurgathor
      I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
      Questions:
      1. What are some the recommended caps for these values? (I will probably order from digikey)
      2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that r...
      08-25-2024, 05:14 PM
    • woody-009
      Tips on how to remove a very stuck memory chip on a GPU?
      by woody-009
      Hi Everyone
      I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
      So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the...
      05-10-2022, 02:54 AM
    • corrize
      Tips for reduce shaking ?
      by corrize
      Hello, I have a little problem. When I use hot air, I'm shaking a little with tweezers, and I'm scared to push a little qfn for check if it floating. So sometime, I prefer to not try and « hope » the solder is done.
      I use the blue tweezers mechanic AAC-14 and a I put just my fist on the table.
      Do you have tips to reduce shaking pls ? Maybe shorter tweezers, or something for wedge the fist or arm ?
      (I add : no coffee, no alcohol and I don't smoke).
      08-31-2023, 08:56 AM
