32LC56 Flickering Screen ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello everyone, requesting for some help. I have here an32" Lg model 32LC56 the symptoms of failure today are that the screen flickers after the tv warms up. I have changed all the output caps as one was bulged so I changed all the Samwha Wb caps with Panasonic Fm. Now I dont feel that this is an Lcd Glass failure as when the flickering appears the backlight flickers along with any image on the lcd screen. I am aware that these use smart backlight dimming or whatever but dont think that a failing Lcd Glass would also cause the backlight to flicker ? Has any one got any info on these sets and this failure googled it but answers are inconclusive TIA ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 32LC56 Flickering Screen ?
    Anyone ?
      Could be a bad panel, fixed the 26LC56 with same fault - tab bond failure - generally found 26" Chimeis to take well to tab shims so might be fixable. not sure about 32" set though, may use LG panel.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Its an Lg panel but it seems to only occur when I heat the mainboard flexing the panel doesnt affect the issue strange might tab it anyway to be sure.
          Can you disable smart dimming?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Good idea will do later and see what happens cheers
            • manstoblame
              • Jan 2011
              • 85
              May be the backlight tube itself is beginning to fail? or the connector to the bulb is loose its really hard to say and everything and anything else would just be guessing
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                This tv is a weird one, I factory reset it and turned off that crappy backlight feature which just makes the screen look dim and rubbish and now no flickering at all wtf ? Only got 4 screws in the back as well not a single glitch even after 1 hour and its nice and warm crazy will update if anything happens.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ok the issue only appears when the whole screen seems to be addressed, when its on a black screen with menu works fine but when watching tv and the whole screen is working and every line is being scanned it messes up is it possible that a tab driver is failing when it gets used which is causing the whole screen to mess up ?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Or could it be a Tcon or Mainboard fault very strange as fault only happens when whole screen is being used
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      try cooling the board(s) after it's warmed up
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Will do cheers mate, strange one for sure going to make a youtube video on it.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Tv is fixed !! Was two caps on the Mainboard which were causing a dip in the voltage that goes to one of the regulators. Will make a new thread and youtube video on the fix thanks everyone
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Also after replacing the caps notice a huge change in the overall image quality picture before seemed dim and poor contrast with the new caps picture seems bright and sharp amazing what bad caps can do seems to be all sorted
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Did you actually see the DCV dips on the voltage regulator? A multimeter with min/max is helpful in situations like this.
                              --- begin sig file ---
                              --- end sig file ---
                              • Rickig
                                • Mar 2015
                                • 112
                                • England
                                Change c970 cap on main board, 16v 100uf.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Yes after replacing the cap the voltage went up by .4 of a volt and the set works fine.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Thats the one that fixed it
                                    • Rickig
                                      • Mar 2015
                                      • 112
                                      • England
                                      Glad to have helped
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Cheers
                                        • Ado02
                                          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                                          by Ado02
                                          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                                          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                                          12-16-2024, 02:33 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          Macbook Air M2 A2681 Kernel panics after screen replacement
                                          by reformatt
                                          Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                          It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                          07-31-2025, 08:37 PM
                                        • survivalbloke
                                          HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                                          by survivalbloke
                                          SN: 8CG0213H8W
                                          ProdID 3C311UA
                                          This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                                          05-08-2025, 12:21 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
