T-con board issue? Philips 52PFL5704D/F7
  • ahardb0dy
    • Jan 2015
    • 24
    Would this be considered a T-con board issue?
  • ahardb0dy
    • Jan 2015
    • 24
    Re: T-con board issue? Philips 52PFL5704D/F7
    Anyone?
    • funtastic
      • Nov 2012
      • 63
      • New Zealand
      If you apply pressure to the top of the frame above the lines does it alter them?
      • AFajitas
        • Dec 2014
        • 183
        This guy had the same issue as you, claims his TV was working fine, then he put the main and tcon in the same model TV and it caused this issue, even when he switched the parts back. https://www.badcaps.net/forum/showthread.php?t=34358
        • AFajitas
          • Dec 2014
          • 183
          Unless he was confused, could be the driver boards on one of his panels frying the tcon board.
          • ahardb0dy
            • Jan 2015
            • 24
            No, doesn't change at all
            I'll have to take a closer look at the T-con board tomorrow, I pulled it out and cleaned it with alcohol and after I got the ribbon cables seated correctly is when the picture came back on,
            When I first got the TV from my old boss it had no picture at all.
            I do have a multi meter in case I need to check voltages, just would need to know what and where to check.
            • funtastic
              • Nov 2012
              • 63
              • New Zealand
              To me it's either the panel or the t-con as it's receiving an image fine from the mainboard.
              Need someone experienced to help you out like budm or tom66.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8221
                Does the tcon have 2 ribbon cables coming out of it to the LCD? Unplug one and see if half of the screen turns white.
                • ahardb0dy
                  • Jan 2015
                  • 24
                  yes, it has 2 ribbon cables, I'm pretty sure when I remove one half the screen will go white, I will check that again and post back in a few.
                  What would that mean if half the screen goes white?
                  Want to add when I first got the picture to come back, you could see the picture all the way across the screen, except their were lines on the left side of the screen, (could see through the lines) now all I'm getting are the lines as I posted in the pic above ( on the left side)
                  • ahardb0dy
                    • Jan 2015
                    • 24
                    Just was checking things on the T-con board:
                    If I remove the ribbon cable for the left side, the left side of the screen goes pure white, right side still has picture but it is frozen.
                    if I re-install it and remove the ribbon cable for the right side the whole screen goes out.
                    at one point after shutting the tv off than turning it back on the left side that had the lines was solid black, turned the tv off and on again and the lines showed back up.
                    I removed the T-con board again, to check it out closely, nothing looks bad visually.
                    Cleaned the contacts on the cables coming into the t-con board, didn't change anything.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8221
                      I think you need a new tcon board. You removed the ribbon and the defect on the screen went away and turned white, correct? You could check fuses, etc... but after that, it may go to replacing IC's and I am not shure if you want to do that or not, unless a replacement tcon is too expensive.
                      • ahardb0dy
                        • Jan 2015
                        • 24
                        Yes, the side of the screen I removed the ribbon cable from went to white.
                        Also just tried cooling the board and a little heat, no change doing either.
                        Guess I'll have to keep my eyes open for a new board, I see how hard they are to find.
                        Thanks Appreciate the help !
                        • ahardb0dy
                          • Jan 2015
                          • 24
                          Has anyone had an experience with the places that offer to rebuild the T-con boards? I see there are a few on E-bay.
                          • ljintexas
                            LJinTexas
                            • Jan 2015
                            • 669
                            Buffer board...or bad ribbon cable connection. Could also be a logic board..have you tested the logic board in self test mode to see if it generates test patterns?
                            • Soulzink
                              Samsug washing machine. Power supply DC41-00189a board issue
                              by Soulzink
                              Hi everyone,
                              I am trying to fix a samsung washinmachine power supply main board.
                              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                              The power supply board reference is the following: DC41-00189a
                              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                              04-19-2025, 06:26 AM
                            • Asraf Atb
                              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                              by Asraf Atb
                              Hi everyone,
                              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                              01-27-2025, 05:02 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • notallbad
                              TCL 55RP620K power board issue
                              by notallbad
                              Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                              0% p_dim at 1.65v and a_dim at 1v
                              50% p_dim at 3.3v and a_dim at 1.65v
                              100% p_dim at 3.3v and a_dim at 2.88v
                              Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                              Leds are 2 rows of 15 6v leds.
                              On inspection of the power board found diode MBR3200 shorted so replaced with...
                              07-12-2025, 05:45 AM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
