Antec TPII-480 replacement caps ?
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    These beauties came from an Antec Truepower 2.0 480W powering a GA-M55plus-S3G with bad caps in its VRM
    What to use for replacements ?
    From various posts, it seems:
    1. Those Fuhjyyu TM are low ESR
    2. I could safely substitute 3300uf 6.3v
    Am I correct ?
    I'm tempted to try some Nichicon HM recycled from deceased motherboards
  • tazwegion
    • Jun 2006
    • 444
    Re: Antec TPII-480 replacement caps ?
    Double post.
    Viva LA Retro!
    • tazwegion
      • Jun 2006
      • 444
      Used capacitors are an unknown quantity in that they may be fine or die next week best to use new components in a mission critical system unless you're okay with replacing them in an ongoing fashion.
      I understand you having difficulty sourcing suitable components at reasonable prices being in Australia myself but have had good experiences with the Hitano EXR series (low ESR) capacitors from Wiltronics in Ballarat Victoria and will buy Internationally when I must just not China/Hong Kong suppliers on eBay.
      Thankfully I had enough SamXon capacitors on hand from previous purchases to re-kit my TP480w PSU's.
      BTW keep in mind you can substitute larger values without a problem but you can't use lower spec'd components and expect no negative consequences.
      Viva LA Retro!
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Yeah, 3300uF 6.3V would be good. I'm pretty sure they used such high capacitance just to get the lower ESR. Fuhjyyu are trash though. What are the brand and series of the 3300uF 6.3V caps that you have in mind?
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I should have said in the first place that original Fuhyjju's dimensions are 10 (Diameter) x 35 (Height)
          And their placement was pretty squeezy
          Given larger values have larger dimensions, subbing larger isn't an option
          I'd be using Japanese ones tested on my ESR meter - yet to have a problem with equivalents used for other purposes
          Nichicon HM (in suspect date ranges) or Chemicon KZG - I know, I know, but hate adding good money to consumer grade crap that's built to a price not a recipe
          I thought I had some new Sanyo WGs, but of course cannot find them - if they turn up, would be the ones used
            • 31087
            panasonic does 3300uf 6.3v 10mm FK series
            and 2700uf 10v 10mm FK series
            and 2700uf 6.3v 10mm FR series
            and the esr etc are probably far better than those 3300uf fuckyou's
            i just checked my datasheets.
            all 3 of those blow away the fuckyou 4700uf 6.3v caps in esr & ripple!!
            • c_hegge
              • Sep 2009
              • 5219
              Yup. http://au.rs-online.com/web/p/alumin...itors/0571054/
              or
              http://au.element14.com/panasonic/ee...rad/dp/1744878
              They are actually quite decent PSUs if you fully recap them.
              • mockingbird
                • Dec 2008
                • 5484
                Rubycon ZLJ is also sold in 10mm:
                http://www.digikey.com/product-detai...466-ND/3134422
                According to c_hegge's article on polymodding, those CWT Antec units do not work properly with Ultra-Low ESR capacitors. He writes:
                After the results of the first test, I had high hopes for this unit, since the performance was very similar to how it was originally. However, my hopes were short-lived, because my test PC wouldn’t even boot with the poly-modded SP-400 installed. This unit is clearly not designed to work properly with these capacitors. Let’s see if our next contender can do better.
                ...a bit odd considering the ripple measurements looked good. But you shouldn't use Nichicon HM for this reason, with a 0.012 ESR rating.
                • c_hegge
                  • Sep 2009
                  • 5219
                  I've used MBZ in an SL-350 before and it was fine. I think it may have been the drop in capacitance that the SP-400 wasn't happy with. Not that I would advise using KZG or suspect HMs on it, though. You might as well recap it with more Fuhjyyus.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Ah, in that case good HM caps would be just fine on it... But I wonder what he means by "suspect" HM... Nothing is suspect about HM up until 2004, in the sense that they will certainly fail. After that, there's some debate as to when exactly they fixed the series.
                    Still, would be interesting to see how long they last in a PSU as opposed to a motherboard VRM.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      I would never use HM / HN/ HZ in power supplies. I think they are too low esr for that use. The lowest esr capacitor series I use for psus is Panasonic FR.
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        LOL - when was the last time you found any Fuhjyyu worth reusing ?
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I haven't, and neither have I found any KZG or suspect HM that were re-usable.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            Anyway, it's going to get new Sanyo WG 3300uf 6.3v once I get my hands on them
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Did you source those from China?
                                • 31087
                                i'd be suspicious of sanyo.
                                they are very expensive and hard to find.
                                if they seem cheap - as in the same price as pana/ruby or if they are on taobao/ebay etc they are fake.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  I think those have too low ESR to work well for PSU use.
                                  Do you have a oscilloscope to check with after modding?
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    We already covered that Per . c_hegge measured ripple and it was slightly improved with Ultra-Low ESR caps (Even lower than what he is planning on using)...
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      eBay - egekecu/PCMCS
                                      And to preempt the inevitable, the final cost of those c_hegge referenced makes the difference between cap replacement and it meeting the garbage can
                                      • pfrcom
                                        Oldbie
                                        • Jun 2006
                                        • 1230
                                        Anything dated before 2006
