Replacement for the Siemens Bakelite caps in an early 1980s SMPS
  • rewease
    • Sep 2010
    • 8
    There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
    Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
    Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY, LXZ or Panasonic FR. After all it's an SMPS.
    But then again it's an ancient SMPS and some folks say that super low ESR is not always the best choice for ancient gear as it may be designed expecting a certain resistance in the caps to limit current spikes. The original Siemens EK caps are probably the same as Roederstein EK but I have no idea what their properties may have been when new.
    So another idea would be using something more general purpose like Panasonic EB.
    What caps would you use in such a PSU?
    • 31283
    Re: Replacement for the Siemens Bakelite caps in an early 1980s SMPS
    i would use what i would call entry-level low esr caps.
    something like rubycon YXF
    and dont think that just because siemens and some audiophile company use the same series code that they are related - they probably arent.
    what the are height, diameter and pin-spacing?
    • Olkus
      • Aug 2023
      • 11
      • Poland
      Roederstein is a part of Vishay. This caps are not audiophile, I think the replacement of the EK is Roederstein EKE or EKC.
        • 31283
        i was reading on an audio forum preople checking esr on these caps - they are VERY low!
        maybe as low as panasonic FM/FR series!
        • rewease
          • Sep 2010
          • 8
          I suspect they may be some sort of OEM production for Siemens by Roederstein. The rather unique casing, marking, etc all look like they came from the same production line with just the logo stencil swapped. But I can't know for sure.
          Pin spacing is 5mm. Dimensions I have to guess right now. Something like 16x35mm.
          Thanks. EKCs specs look similar to other current day low ESR caps.
          That's good news so I don't have to worry about going too low ESR.
          I can get Panasonic FR or Nippon KY delivered by wednesday so they are on top of the list.
          I just looked around some forums and found an old datasheet for Roederstein EK series
            • 31283
            i saw that, but people esr testing the siemens caps found them reading much lower - i mean seriously better spec!
            • rewease
              • Sep 2010
              • 8
              Maybe they are not the same after all. Also Z in the datasheet is measured at just 10 kHz.
              • rewease
                • Sep 2010
                • 8
                Just replaced the caps with Nippon KY and tested the old ones with my chinese component tester.
                They all measure around 500 to 600 uF and 150 to 200 mOhms ESR. Didn't solve the issue but had to start somewhere.
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  Trying to make out date codes on several ICs, it looks like that board dates to early or mid 1982. Back then it was still common to spec ESR instead of impedance, and at 10KHz or 20KHz instead of 100KHz.
                  PeteS in CA
                  • rewease
                    • Sep 2010
                    • 8
                    Yes the machine was made in 1982. I'm impressed with those Siemens caps. Other caps with Bakelite housing (Roedersteins) were also fine and went back in for lack of replacements. Found a Frako NO 10µ/63V that aged way worse measuring 140 Ohms ESR.
                    • Olkus
                      • Aug 2023
                      • 11
                      • Poland
                      Frako's are usually bad, they can make problems.
                      • PedroGG90
                        siemens sitop 24 vdc Smps outputs higher voltage 33 vdc
                        by PedroGG90
                        Hi everybody.
                        I have two 3 phase 400 vac smps siemens sitop 24 vdc giving red light overload and higher output 33 vdc.
                        The switching is controlled from micro controller.
                        Is it micro controller or transformer ? Or else pls ,?...
                        Badcaps Electronics Repair Forum & Schematic Search
                        02-09-2024, 05:20 AM
                      • dkneyle
                        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                        by dkneyle
                        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                        02-01-2022, 02:08 AM
                      • shamsudeen
                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                        by shamsudeen
                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                        07-19-2025, 07:14 AM
                      • abhishekkumar1902
                        Huntkey HK340-72FP SMPS shut on load above 2 amps
                        by abhishekkumar1902
                        I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                        I have checked the following:
                        1. All output caps are OK, and all output rails read correct voltages at no load
                        2. All output diodes are OK
                        3. NTC is ok
                        4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                        5. No short in main switching MOSFET
                        6. All other components...
                        12-18-2022, 09:52 AM
                      • madan1
                        Mackie Th15 SMPS low Vout
                        by madan1
                        I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                        It is basically a smps with amp and some dsp.
                        The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                        Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                        By the way, the ferrite core of L10 is broken,...
                        02-16-2025, 04:15 PM
