Computer fan noise and maintenance
  • Fizzycapola
    • Oct 2006
    • 423
    I thought I'd ask. Fan noise, degradation in increasing audiable levels through
    their lifetimes aswell as the electrical disturbances they can cause. As an
    electronics and engineering novice maybe someone could help me in a better
    maintenance regime than my current one of hoping for the best.
    So I have these questions:
    How can PC fans be maintained? (bearings, lubrication, cleaning off dust & particulates)
    How can PC fans be prevented from causing electrical interference?
    The fans I use are double ball bearing & sleeve bearing. Connected to 12v
    rail and onboard connectors.
    Excerpt from an offsite link, link provided by willawake
    Fan control output
    The pulse width modulated output of the fan controller lacks noise suppresser, which should better be used if you use poor DC fan. Switching current to an inductive load generates sevier high voltage noise.
    A snubber of 100nF to 1uF MLCC with 100Ω in series will be enough.
    It added one snubber of MLCC of 1u/16V and 100Ω each between Vfan and GND pins of fan connectors.
    Rubycon Rubycon Rubycon
  • davmax
    • Dec 2005
    • 899
    Re: Computer fan noise and maintenance
    How can PC fans be maintained? (bearings, lubrication, cleaning off dust & particulates).
    I have had long life with fans by using a fairly stiff paint brush to remove the dust on blades and body. Compressed air is useful but a dirt film often remains. I believe some use water to remove this film, there is an obvious need to ensure the bearings do not remain wet. For lubrication I use a synthetic oil 10-50 grade, it is thin and will not gum up or evaporate. Oil is applied by removing the circular sticker on the non moving side, gaining access to the bearing. About two small drops is the limit. I use a micro oiler with a hyperdermic needle diameter oiling tube.
    What interference is the concern? Degraded computer performance or radiated radio interference?
    Fans may generate pulses but in general these are removed in computers. Those connected to the motherboard and the power supply leads encounter filtering. eg fans creating noise on the twelve volt output of the power supply will not affect components down stream due to electrolytic cap filtering and possibly switching power sources down stream (that contain considerable filtering).
    It would be nice to have examples of fan noise impact that has been eperienced and identified.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      the ideal way would be to use quality fans like these ones and preferably not get them dusty in the first place by using dust filters.
      i have had mixed experience with using oil on small fans, sometimes the noise is gone but starts up again later. perhaps my oil is no good?
      funny how a fan can be working without noise for a long period of time like a server on 24/7. then you shut it down and oops a noise starts.
      • Fizzycapola
        • Oct 2006
        • 423
        At the moment I use 2 x Silent Eagle 1000RPM. 1 x Akasa Ultra Quiet 1800RPM intake. 1 x 120mm Akasa Ultra Quiet 1400RPM outlet.
        Silent Eagle
        Akasa Fans
        Theres no immediate issue with the fans. I was just curious to how expertly
        maintain them better.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I use mist oil, like used in industrial compressed air systems to lubricate the equipment that runs from the air...
          • davmax
            • Dec 2005
            • 899
            How long does mist oil last? I have found a need to be cautious about oil that can evaporate. I have seen CRC used and this soon evaporates.
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              funny this fan lube subject came up.
              temporarily fixed a bad fan in a hurco bmc40 by feeding it a drop of way lube.
              got funny looks from the operator but it will run long enough to get a new high quality fan.
              • linuxguru
                • Apr 2005
                • 1564
                Slightly tangential, but I found that the Thai or Chinese-made NMB KL3110-series fans are great, inexpensive replacements for PSU fans.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  The fans I've used it on still all work just fine... (and they did not before)
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    I recently refurbished ;-) an AC Silent TC fan by adding a bit of motor oil solved in some WD40. The fan dos not move easily. It stoped instantly, if pulled by hand. After lubrication it behaved like a new one. The WD40 will fore shure evaporet fast, but the 10w40 motor oil will probably last for decades. If not, the onwer has to by a new one. I dos it out of curiosity, it was not the main problem i had to fix.
                    • tazwegion
                      • Jun 2006
                      • 444
                      I used some suspension dampener oil from my R/C Tamiya Hornet kit... the fan is still going strong & silent
                      Sometimes... replacement fans can be hard to source, @ least re-oiling a fan can buy you some additional time
                      Viva LA Retro!
                      • Tom41
                        • Oct 2005
                        • 338
                        • England
                        One time when a fan in my server PSU started grinding, I took the label off and put a couple of drops of oil on the bearing. Started it up again, perfectly 'silent' again. Although it may need oiling again in the near future, it's beginning to rattle...
                        You know there's something wrong when you open your PC and it has vented Rubycons...
                        • Fizzycapola
                          • Oct 2006
                          • 423
                          Ok I "topped" up the oil in one of my fans to experiment. I won't say what I used though but you can imagine. Lets just say it grows in Italy, working good!
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            • USA, Unsure of Planet
                            Did you toss in some minced garlic?
                            PeteS in CA
                            • Shroomie
                              • Apr 2006
                              • 356
                              Careful Pete, you'll make my Delta 120mm exhaust hungry...it's already grinding a bit, so I'll have to oil it soon. Guess it's done fine so far, seeing as I pulled it out of a 1999-vintage HP Netserver (dual P3) that got knocked off by a power surge...
                              I'll try these suggestions, thanks guys! I'll let you know how it goes.
                              You know there's something wrong when you open up a PSU and are glad to find Teapos.
                              Why I don't buy cheap cases!
                              • bgavin
                                • Jan 2007
                                • 1355
                                While at IBM, I learned that dust is the cause of most machine wear, and oil attracts dust. We got longer life from components such as fan bearings by keeping them free of dust and oil.
                                Replace your fans on regular intervals, same as brake pads or tires. Fans are just service parts, like car parts.
                                I rotate my clients' hard drives every 3 years, and (thanks to Badcaps.net) have started rotating power supplies on 3 year intervals.
                                I have great luck with Panaflo fans. They have a sealed, oil filled bearing and run very quiet. I have yet to have one make noise or fail. I run the 80mm U12 series on Alpha CPU heatsinks and get an 8~11C delta.
                                The fans that die most frequently for me are Antec 80mm case fans.
                                • gdement
                                  • Jan 2007
                                  • 690
                                  The replacement need depends a lot on the quality of the fan. I guess in some large-scale situations it's easier to replace the fans on a regular schedule. Another approach (but maybe not worthwhile on a large scale) is to keep tabs on the fan speed and CPU temperature. You can replace the fan once you notice it slowing down, and clean the dust if the CPU temperature has risen. Tracking the temperature saved my sister's computer - it turned out the PSU fan was dead, that thing was baking and yet even the PSU survived.
                                  I agree with linuxguru that NMB seems to make good fans. If I'm not mistaken, I believe that's the brand of 92mm fans in my 1998 HP Kayak. They're loud but they've been that way since I got the machine a few years ago, I think it's just in their nature.
                                  My oldest good fan is a small 40x20 (maybe 50x20, not sure) CPU fan which I took from a 1997 Packard Bell. I'm using it on a different Pentium machine. It's by far the most impressive life I've seen from such a small fan. Branded PC's seem to have reliable fans in them to save the manufacturer from service calls.
                                  • tazwegion
                                    • Jun 2006
                                    • 444
                                    I'm curious has anyone tried a dry lubricant like graphite powder (or the superior) Molybdenum disulfide powder (Chemical symbol=MoS2) to lubricate these case fans?
                                    Viva LA Retro!
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      or astroglide
                                      • bgavin
                                        • Jan 2007
                                        • 1355
                                        Isn't Astroglide used when mycoxastickin?
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • stvhop
                                          HP1955L Buzzing noise & interference
                                          by stvhop
                                          Hello, This is my first post so please forgive me if I miss out some vital info.
                                          I have a problem with my HP1955L monitor from 2005.
                                          The first thing to say is that it is still basically working, ie the picture is fine.
                                          However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                          The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                          11-07-2020, 07:13 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • b-slayer
                                          Asus Strix-G15-G513RM fans don't work
                                          by b-slayer
                                          Hi everyone,
                                          I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                          The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                          (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                          (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                          ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                          09-04-2025, 04:58 AM
