Computer fan noise and maintenance
  • 999999999
    • Sep 2006
    • 774
    Re: Computer fan noise and maintenance
    ^ What a treadmilll uses could depend on the manufacturer and where it is used. If it is in a gear housing then it's probably 85W petroleum gear oil. That would work, but won't as readily soak into the porous bearing.
    Silicone oil is rarely used for lubrication except where petroleum oil would break down components or in an extremely high temperature environment where it better retains its viscosity.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #102
      Here it is.
      I think it is silicon based. What is your opinion?
      • 999999999
        • Sep 2006
        • 774
        ^ Based on (lack of) color it does look like it may be silicone based, but I can't read the text on the tube. Where is it used, which specific parts of the treadmill?
        I wouldn't use it on fans, but in an emergency it might keep one running.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          My favorite for fans is Tri-Flow, it's brought a lot of seized fans back to life too
          • Ed Herdman
            • Apr 2014
            • 31
            Ah, I wish I'd found this thread a while back when I was researching grease.
            So far, I have some of the ol' PTFE Super Lube for plastic gears, and plastic/metal lubrication, and some Wal*mart stuff - Supertech "Moly-Lithium" grease (which reportedly has very little Moly at all).
            What I'd like to know about are worm gears - it seems to me that these parts are likely to experience some wear that could be prevented with the moly-additive grease. I just put a little on the worm gear of a floppy drive, which I hope is best for the job. I've also got some worm gears for optical drives that I'd like to lubricate. In both cases I want to avoid using a too-heavy grease so that the drives don't seize (but that's probably not a major concern with worm gears after all).
            • mockingbird
              • Dec 2008
              • 5488
              #106
              For worm gears in optical drives, you're supposed to use lithium grease... I know this because there was discussion about it years ago with regards to certain xbox360 drives...
              • Ed Herdman
                • Apr 2014
                • 31
                There are a few potential wrinkles here:
                - Some worm gears are brass, some are something like brass-plated steel, others are steel or some other shiny metal...
                - There's also additives to consider...molybdenum is the most common one.
                In some cases the chemistry of things matter - but I haven't found any record of lithium, or lithium with molybdenum, causing problems in commonly used metal worm gears.
                The synthetic silicone stuff seems pretty good and versatile - it's just an open question (for me) as to whether it competes in this application, even with the PTFE additive.
                As an aside, the Wiki reports that there are some PTFE (Teflon, Syncolon) types being produced now which also have molybdenum for extra lubrication.
                This is really promising, too: "By current calculations, a switched-off molybdenum disulfide transistor would consume even as little as several hundred thousand times less energy than a silicon transistor." - R&D Mag
                • Logistics
                  • Apr 2007
                  • 721
                  I think there is a lack of concern in this thread as to the comparability of lubricants with non-ferrous metals. Transmission and gear oils are good because they are meant to protect and prolong use of non-ferrous metals, especially brass and other yellow metals. There is an exception however, as specs such as GL5 call for extreme pressure additives, which have the unfortunate effect of degrading yellow metals
                  To reiterate what I've posted, before I have always used Dexron III and never had to relube afterwards.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #109
                    What about this oil type? I bought it today for 2.5euros. Is it the suitable for fan bearings?
                      master hoarder
                      • May 2008
                      • 12175
                      #110
                      Looks like seweing machine oil type (unlikely that it is genuine "Singer" like the seweing machine brand, but anyways). If so, it will probably do fine. Sewing machine oil tends to be a bit more runny, but it doesn't dry and (at least IMO) it works fine.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Yup. I've un-stuck and lubed a few fans with sewing machine oil before. I usually use chainsaw lubricant, which is just a bit thicker, but that works fine too.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #112
                          Thanks a lot for the input!
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            Here's what I use.
                            Even those fans with that chunky, pasty, "gloppy" grease, salvaged from junked Deers (or cheap cases), run for years with this, after a full disassembly/clean/relube.
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                            • tronik25
                              • Dec 2013
                              • 15
                              Cleaning for the electronics/bearings-HPI Racing Nitro Car Cleaner.Does ok on plastics,its safe.
                              http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN287
                              Cleaning for the fan,plastics in general:Plexus.It cleans,polishes,& leaves a dry protective layer
                              http://www.plexusplasticcleaner.com/about.html
                              Lube for the shaft & main center piece(what holds the bearings):
                              Plexus if the main center piece is plastic.
                              LPS force 842 (dry moly)
                              http://www.lpslabs.com/product-details/570
                              Jet lube moly mist(dry moly)
                              http://www.jetlube.com/MOLY-MIST-Aerosol-P754C118.aspx
                              RZ-50(dry PTFE)
                              http://www.rz-50.com/
                              Bearing lube:
                              Acer racing SIN synthetic lube
                              http://www.acerracing.com/ball_beari...il-967-70.html
                              Boca LBT Lightning Lube high speed (viscosity of 1875/9CS)
                              http://www.bocabearings.com/bearing-...lightning-lube
                              Hedgehog Alchemy oil ultra light/low viscosity
                              http://www.hedgehog-studio.co.jp/product/772
                              I have not used most of these products but know many who have.Best ball bearings are silicon nitride(si3n4).Can most likely upgrade your fans bearings to them if you want.
                              • mockingbird
                                • Dec 2008
                                • 5488
                                #115
                                I wonder if RZ-50 can be used on laser printer drums instead of methuselah powder.
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Here's what Powmax uses:
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Sounds about right, actually. The same could probably be said of Ruilian Science.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #118
                                      I think Globe fans mix some of that with their oil too, cause they get stuck way too often.
                                      I just found a (nearly) empty bottle of motor oil (new) in the garbage room at the condo I live at for college. There's probably just a few grams worth of oil left in there... but good enough for a lifetime fan repair. Oh yeah, it's synthetic too. 5W30 or something like that IIRC.
                                      • krazykev64
                                        • Feb 2009
                                        • 49
                                        #119
                                        my system is nothing special. i use a Icute 750w modular PSU. This has a very quiet fan.
                                        in my case i have a pair of arctic cooling 120mm case fans. these are fitted using rubber mountings to stop the case vibrating. i also run them at 7 volts using an inline resister between the fan and board connectors. when it comes to cleaning them i use a half inch paintbrush with the bristles cut to half the length. i have never needed to lubricate them in the 5 years they have been in the case and they are still extremely quiet.
                                        My CPU fan is an Arctic Cooling Freezer Pro 7 Mk2. the 90mm fan is rubber mounted as standard and even at full speed the fan noise is acceptably quiet but at the lower settings which i tend to use the fan is hardly audible.
                                        if i ever need to lubricate a fan i use a special oil used to tune high speed multiplier fishing reels which spin at speeds in excess of 200.000rpm (yes you have read right) during tournament casting. the oil is called TG'S rocket fuel. you should be able to get it from most UK angling shops or ebay http://www.ebay.co.uk/itm/TGs-Rocket...-/130820196698.
                                        I use the red grade but red or tournament grade will do the job
                                        • Logistics
                                          • Apr 2007
                                          • 721
                                          Recently, picked up a Thermaltake A4021 for $5, and it was obvious the bearing was dry. Apparently, these were notorious for not lasting, very long at all. I chalk it up to inappropriate lubricant. I cleaned the bearing with alcohol and relubed it with Redline CV2, and it's flawless... and will probably last, forever.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • stvhop
                                            HP1955L Buzzing noise & interference
                                            by stvhop
                                            Hello, This is my first post so please forgive me if I miss out some vital info.
                                            I have a problem with my HP1955L monitor from 2005.
                                            The first thing to say is that it is still basically working, ie the picture is fine.
                                            However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                            The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                            11-07-2020, 07:13 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
