Using the thread below and the attached .pdf for troubleshooting 7 blinks, I've determined that it appears that I need to either repair or replace my SC board. I would like to try to repair this board if possible.
https://www.badcaps.net/forum/showthread.php?t=21700
With everything connected, the screen flashes briefly at startup and then the LED blinks 7 times. With the SU and SD disconnected, the LED blinks 6 times once, then 7 times over and over. With the SU connected and the SD disconnected, the top of the screen flashes and the LED blinks 6 times once, then 7 times over and over. With the SD connected and the SU disconnected, the bottom of the screen flashes and the LED blinks 6 times once, then 7 times over and over. With SC2 and SC20 disconnected the unit powers on and off with the remote. According to the attached .pdf file, this means the SC board is at fault.
What do I do now?
What do I do now?
