Panasonic TH-42PZ77U SC board repair 7 blinks
  • johnboy1313
    • Nov 2012
    • 1959
    Using the thread below and the attached .pdf for troubleshooting 7 blinks, I've determined that it appears that I need to either repair or replace my SC board. I would like to try to repair this board if possible.
    https://www.badcaps.net/forum/showthread.php?t=21700
    With everything connected, the screen flashes briefly at startup and then the LED blinks 7 times. With the SU and SD disconnected, the LED blinks 6 times once, then 7 times over and over. With the SU connected and the SD disconnected, the top of the screen flashes and the LED blinks 6 times once, then 7 times over and over. With the SD connected and the SU disconnected, the bottom of the screen flashes and the LED blinks 6 times once, then 7 times over and over. With SC2 and SC20 disconnected the unit powers on and off with the remote. According to the attached .pdf file, this means the SC board is at fault.
    What do I do now?
  • DavidOH
    • May 2012
    • 105
    Re: Panasonic TH-42PZ77U SC board repair 7 blinks
    I would say unless you can find an obvious problem on the board your looking at replacing it. After a quick search it looks like about $100. I did see one on sale for $65.
    • johnboy1313
      • Nov 2012
      • 1959
      I see repair services being offered on eBay. I figured I would check here and see if anyone knew anything about it.
      • drpj23
        • May 2012
        • 528
        Is there a short between the two prongs on the SC board?
          7 blinks is caused, sometimes, by chassis detect failure. Is there a connector SC50 on the SC anywhere? If so, connect the two pins. This should disable the chassis detect and run the PDP.
          • johnboy1313
            • Nov 2012
            • 1959
            I'll get back to you tonight.
            • johnboy1313
              • Nov 2012
              • 1959
              I searched the board and don't see an SC50 connector.
                How about a picture?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Yeah, after all this time, you'd think I woulda snapped a picture by now. I'll get one this afternoon.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    This will have to do until I can get home.
                    http://www.shopjimmy.com/panasonic-t...u-sc-board.htm
                    • rayrod81
                      • Oct 2010
                      • 205
                      The common failure on this board is one or more of the FETs in one of the two long rows of FETs. I will have to look up the part number. Keep in mind that after you do the repair there is a firmware upgrade that needs to be applied to keep this problem from recurring.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Firmware, ugh!! I have no idea about upgrading the firmware on these sets. The only one I ever did was on a Samsung with a USB port, super easy. I don't suppose this is as easy, or is it the kind where you have to have a jig?
                          On Pannys, it is usually possible via the SD card slot.
                          I forgot I have repaired the TH-42PZ70BA which had a shorted fet on the SC. I never applied the firmware update though...
                          • rayrod81
                            • Oct 2010
                            • 205
                            The part number is B1DFKM000002 or 5N2307. Here is thread from AVS Forum with some info for you. http://www.avsforum.com/t/1001318/ma...#post_17876879
                              Yes, mine was the same fet.
                              I miss this very over-engineered chassis. The newer ones aren't as nice.
                              And on mine, the left hand one was also bad like on the AVS Forum thread. Wonder if it's just a coincidence or if that one fails the most. If the gate drive is closest to that one (I believe the gate drives are all common), it will turn on first slightly, so briefly have to take all the load, leading to higher power dissipation.
                                BTW, you can briefly run the TV with that fet disconnected, just cut both of the visible leads. There are 6 in parallel so running with 5 briefly is OK. You need to replace the part, but it will verify if there are any other problems with the rest of the TV.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Great, thank you guys. I'll report back.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    rayrod, thanks for that link. In the post the OP mentions pulling a leg of each transistor to detect a short. I've never actully used the diode test on my meter. What exactly am I looking for when testing a transistor for a short?
                                      Zero or very close to zero (<20)
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        Following the directions on the link provided by rayrod, I pulled one leg of each transistor in the first group. I didn't find any shorts, but I did find evidence that something might not be right. I apologize for the following. My kids are using the computer and for some reason I can only attach one pic to a reply at a time
                                        With the DMM set to diode, I put the red on the lifted leg and the black on the other leg. If I switched it, I got an open circuit. Testing all seven (all of which are the same part number) like this I got
                                        1 = 1427
                                        2 = 1427
                                        3 = 640
                                        4 = 1427
                                        5 = 1427
                                        6 = open
                                        7 = open
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • Biruslapio
                                          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                          by Biruslapio
                                          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                          02-16-2021, 09:44 PM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
