Vizio M261VP blinking power light.
  • reabbott
    • Jul 2012
    • 10
    A friend of mine brought me this TV, saying it wont display anything on the screen. Rightly enough, when i turn it on, i get nothing, no flash of light, no OSD menus. The only thing i did notice is that the power light blinks on and off for around 30 seconds and then stays off. Does anyone have access to a service manual for this model ? Before i look deeper into the PCB im just wondering if this is a known defect, firmware update etc. might save me some time.
    I took a quick look inside for any obvious visual flaws on the PCB, but nothing stands out, all caps are flush, no residue or marks around the base of any components.
    This is the PCB part. Seems as though everything is combined into this one board.
    http://www.shopjimmy.com/vizo-3626-0...for-m261vp.htm
    Thanks in advance, any help is appreciated.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Vizio M261VP blinking power light.
    Well, that's the main board. There should be a power board as well. You want to check the caps and the output voltages of that power board. Posting a picture here would help others help you with this problem as well.
    • reabbott
      • Jul 2012
      • 10
      This is the mainboard and the power board. The DC input is visible at the bottom right section of the PCB. :/
        If you connect a source and flick through inputs can you hear audio?
          There should be another small board for the LED backlights (it may be part of T-CON). Can we see the pictures of the whole back side of the TV?
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Is the power supply working ok giving correct voltage under load?
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              We really need a good clear picture of YOUR boards
              please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
              Examples of what is needed
              https://www.badcaps.net/forum/attach...1&d=1290283049
              https://www.badcaps.net/forum/attach...7&d=1280167246
              It will be useful if you can say a bit about yourself - skills tools etc. Do you have a multimeter.
              • rduckert
                • Aug 2012
                • 3
                has anyone had any success with this Vizio M261vp Issue?
                thanks
                  We have not seen the pictures we requested yet, we cannot guess what you have since we do not have the TV in front of us to troubleshoot the problems.
                  • rduckert
                    • Aug 2012
                    • 3
                    I emailed tech support at Vizio. they suggested I unplug it and hold the power button for 30 seconds. Doing this, it came back to life - sort of.
                    the sound is back, the controls work, change channels, adjust volume, etc. It has no picture. At a sharp angle, you can see the image is there but has no back lighting.
                    That's where I am so far.
                    RED
                    • gearsdon
                      • Aug 2013
                      • 1
                      I have the same model M261VP. The tv just wouldn't turn on one day and shows no signs of life. Could anyone point me in the right direction?
                      Attached is a picture of the board.
                        gearsdon: power supply board pictures? all the boards pictures?
                        • ecking767
                          • Oct 2009
                          • 492
                          The power supply is external, A/C to DC adapter, LED driver is on the main board
                            OK, thanks, I see the LED connector on the top right of the board.
                            There are many voltage regalator and switch power supplies ( the round inductors I.E. 100, 220, 4R7, 2R2 labels on top) on that main board. There are at least two fuses close to the DC input jack. The Adapter is putting out voltage?
                            http://assets.shopjimmy.com/media/ca...2600820150.jpg
                            Try
                            • GARTYJAC
                              • Aug 2014
                              • 1
                              Has anyone had any found any success for this yet?
                              • Indycanard
                                • Oct 2011
                                • 13
                                I also have this same model with the exact same symptom. When I press the power button, the power light flashes for 30 seconds, then the set turns off. For a short period of time, multiple power cycles would eventually turn the set on, but that doesn't work anymore. The screen stays dark, and I don't see any image on the screen.
                                Instead of starting a new thread, has anyone (or even the original poster) figured out what is causing this?
                                What I have done so far:
                                1/ Did the full power cycle reset (pull plug, hold in power button etc) - No fix
                                2/ Removed the main board and inspected for obvious damage (swollen caps, blown components etc). Reseated all connectors - Nothing found.
                                3/ Discharged all capacitors, then in circuit tested them using a "Blue ESR" tester. - All caps appear good.
                                4/ Checked the external power supply - Voltage checked good.
                                From reading this thread, I don't see what could be the cause of the flashing power light (except the obvious power issue). A schematic would help me trace the problem, but google has let me down. Does anyone have any other suggestions of where I should concentrate my attention?
                                • Tvbob
                                  tvbob
                                  • 204
                                  In my case components in the power supply that powers the led back light shorted.They lit 4, 21 led series circuits, requiring about 63v dc each. 84 led's total. I hacked the led strip to run off the tv sets 19v dc power supply.
                                  • Indycanard
                                    • Oct 2011
                                    • 13
                                    Thanks for the added information.
                                    My Vizio was able to turn on successfully a number of times last night during my testing. I did not do anything specifically to cause the set to turn on, except obviously plug it in and push the power button. I was in the process of measuring the voltages on the various components.
                                    What I found was this:
                                    U8: The power mosfet component mentioned previously as 540N had a voltage at the upper mounting tab and clipped center pin of 19.30V when the set did NOT turn on (just flashing power light)
                                    When the set did turn on, the voltage jumped to a bit over 60V an both locations. I forgot to write the exact value down.
                                    I wasn't able to figure out where the +60V originates from, but I suspect that is why my set isn't turning on correctly ( 60V not being generated somewhere on the main board for the LED power circuit).
                                    I still don't know why the power light is flashing (feedback that the power circuit failed?).
                                    I did tear the set apart and inspect the plug on the LED array. It looked ok, and not in need of repair. The main board end of the LED ribbon cable had one tracer that was damaged for the last 1/8". I slightly trimmed the end and reseated in the connector.
                                    Still no good.
                                    • What?
                                      Vizio SV422XVT blinking amber/white power light
                                      by What?
                                      Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
                                      Problem:
                                      I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
                                      Power Board:
                                      I am getting 5v only. I have unplugged...
                                      04-27-2020, 06:21 PM
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • x_orange90_x
                                      Vizio E550i-A0 no power, no standby light
                                      by x_orange90_x
                                      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                      11-20-2023, 09:49 AM
                                    • huzo
                                      HP 470 G5 blinking amber light no power
                                      by huzo
                                      The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                      So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                      I've tried flashing the bios...
                                      interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                      06-08-2023, 04:08 PM
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
