Sanyo DP46840
  • simplytrini
    • Jul 2011
    • 73
    Sanyo DP46840
    Hi all, hope all is well. I am wondering if anyone here has had success in fixing this model Sanyo. I am having an issue where the the green led turns on but i cannot get the high voltage for the backlights working, the screen is black and I can turn the tv on/off with the remote and power switch but that is about it. the power supply has: 5v, 15v, 12v & 3.3v. however the HV circuit for the backlight is dead. also I know the inverter board works tried it on another set ant it worked. Any thoughts would be great. Thanks
  • simplytrini
    • Jul 2011
    • 73
    Re: Sanyo DP46840
    Also can anyone tell me where i can get a service manual for this set. Thanks again
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: Sanyo DP46840
      Doesnt look like its been on the forums before.
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      Have you tried electrotanya for the sm
      Please can you update your profile with country and voltage.
      • simplytrini
        • Jul 2011
        • 73
        Re: Sanyo DP46840
        Here are a couple pictures of the powersupply and Main board. Any further thought would be much appreciated. Thank you!
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Re: Sanyo DP46840
          First you should check the resistance of the back-light inverter transformer secondary, which is on the bottom left of the PSU.
          1. Can you take a picture of the whole underside of the PSU? Then I can show you where to measure for resistance on the transformer.
          If the transformer secondary(s) is/are open circuit, then you will have to get a new PSU or get a new TV.
          2. Take a bright light or a bright flashlight and shine it at the screen from close-up. Can you see an image on the screen? (TV should plugged into video source) If there is an image, your back-lights are dead. If there isn't an image, then something else must be wrong.
          -Ben
          Muh-soggy-knee
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Re: Sanyo DP46840
            Middle picture is ok but not great there is a small cap in the middle right looks marked on top but probably just shadow? The other two pics have too much flash & shadow. Please try again in natural light if possible. Try and get all the board in the picture. Please also do a close up of the power board at the back of the big transformer - looks a bit odd may need resoldering but cant tell from the pic.
            Can you test the secondary winding resistance on the same big rectangular transformer in middle pic. (With set off for 10 mins)
            When the set is on can you see a faint image of what should be on - perhaps use a pc as source so you know what to expect - try a torch.
            • kevinm34232
              • May 2012
              • 1884
              Re: Sanyo DP46840
              (wrong thread)
              • kevinm34232
                • May 2012
                • 1884
                Re: Sanyo DP46840
                I have this model TV too, it clicks on and the green LED lights up then clicks off a few seconds later, no backlight comes on. Have 120vac at bridge rectifier, 158vdc and filter caps. Not sure what to look for after that, and don't have a service manual... Could this be bad caps, nothing looks bad visually???
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Re: Sanyo DP46840
                  With it all connected up test the low dc out voltages on the connector.
                  It says on the board what they should be. Could be caps look for a small one on the primary side 50v 47uf or 68uf
                  • kevinm34232
                    • May 2012
                    • 1884
                    Re: Sanyo DP46840
                    Before it clicks off, all voltages are good at connector.
                    • kc8adu
                      • Nov 2003
                      • 8829
                      • U.S.A!
                      Re: Sanyo DP46840
                      got +24 at the inverter?
                      • kevinm34232
                        • May 2012
                        • 1884
                        Re: Sanyo DP46840
                        Checking off connector on power board that goes to inverter lableled 24v, I get 24.8v when switched on, grounded to chassis, clicks off and voltage drops away.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Re: Sanyo DP46840
                          OK I just wanna fix 1 TV and I'll be happy. All voltages look good Ive followed the path thru the power supply, at the secondary side diodes I have 2 x 24v for the inverter, and a 5v and a 12v. It clicks on for about 5 seconds then clicks off, there is no backlight even though the invereter is getting 24v. What can I look for next?
                            Re: Sanyo DP46840
                            There should be a pin on the inverter board connector labeled with BL_ON, see if you have >3Vdc at that pin. For the backlights to come on, it needs 24Vdc from power supply and BL_ON (the signal is generated by the main board routed from the main board through to the power supply board and out to the Inverter board).
                            • kevinm34232
                              • May 2012
                              • 1884
                              Re: Sanyo DP46840
                              Yes Sir there are 2 wires from the main board, bringing 2.9v volts to the inverter board before it clicks off.
                                Re: Sanyo DP46840
                                Kevin, your TV does not use the same power supply setup as the original poster, his TV uses Power supply/Backlights inverter board combination.
                                Your TV has separated power supply and Backlights inverter board.
                                This will really confuse people when we try to answer the questions since they do not have the same chassis even though it has the same model number.
                                It may be better to start new post indicating the same model number with notes indicating separated PS/INVERTER boards.
                                We will need good clear pictures of all the boards (both sides of the board) so we can see how TV is wired up.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Re: Sanyo DP46840
                                  Here's a couple pics. I have a question, was checking voltage on the Power IC, I have 160vdc on pins 7 and 8, pins 5 ha 16.8vdc on standby, when I turn TV on it drops to about 13.6vdc. Is this normal?
                                    Re: Sanyo DP46840
                                    Power IC on which board, I assumed the power baord, location and pictures, P/N? Not enough info to go by.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      Re: Sanyo DP46840
                                      On power board primary side right in center of board A6051M SK071 04BP.
                                        Re: Sanyo DP46840
                                        Please see the picture if that is the one you are indicating, if it is, that IC is for 5VDC Standby power supply, which is working since yoy can turn the TV on and off.
                                        • cj_reha
                                          Mystery 80s Sanyo cap - perhaps polymer?
                                          by cj_reha
                                          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                          01-06-2023, 09:24 AM
                                        • Srdjan01
                                          IPhone 12 ProMax - Thoughts of (not so young) apprentice
                                          by Srdjan01
                                          Hi guys.
                                          I'm working on my first board reballing.
                                          It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                                          Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                                          I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                                          03-17-2025, 02:49 AM
                                        • toddw65
                                          Sanyo DP5834 - Gray Screen
                                          by toddw65
                                          Hey All,
                                          I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                                          Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                                          Thanks,...
                                          10-31-2024, 10:37 AM
                                        • zomi
                                          Manual cof bonding success rate ?/ feedback wanted
                                          by zomi
                                          Just wanted to get some feedback,
                                          whats peoples' success rate with cof bonding repairs.....
                                          09-23-2024, 12:45 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
