IPhone 12 ProMax - Thoughts of (not so young) apprentice
  • Srdjan01
    • Jan 2025
    • 11
    • Serbia
    Hi guys.
    I'm working on my first board reballing.
    It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
    Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
    I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder on ics and sandwich pads components will fall off again when I start heating the boards. I decided to desolder ics and use higher temperature solder and that's where things go south.
    First I knock off small cap, which jump out of my tweezers to abbys and when I looked at boardview to find info for that cap I found out that much more components are missing, compared to a boardview.
    Questions:
    - Did I lose all that components when heating for separation and they mysteriously vanish or it is common thing to these boardview files are somewhat different?
    - How do I need to repopulate a board for it to work?
    - What do you think, was my idea about not using same solder unnecessary?​
  • Srdjan01
    • Jan 2025
    • 11
    • Serbia
    Let me answer to myself, if future someone have same dilemmas.
    - No I didn't lose all that missing components. In the schematics, some of components have "nostuff" comment. That basically means that component will not be present after assembly. These components are sometimes flagged as DNF (Do Not Fit), DNP (Do Not Populate), etc
    - Cross reference board view and schematic to see what is there.
    - I think that in the moment of solder melting temperature at sandwich pads are bit higher then contact points of IC at upper board. Even if temperatures are the same and solder underneath the IC is melted, surface tension will probably hold IC in it's place.
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • petemanuk
      BGA solder balls not connecting - help pls
      by petemanuk
      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
      11-16-2022, 05:21 AM
    • myth77
      UV solder mask - high temp resistent, recomendation?
      by myth77
      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
      Is there any solder mask...
      03-28-2022, 04:04 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • sircastor
      Solder not reflowing - what am I doing wrong?
      by sircastor
      I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
      For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
      03-03-2024, 02:44 AM
