Multimeter cables suggest
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, please what king of test leads do you use for probing small IC on notebook?
    I am thinking of soldering a needle to one of cable.
    ...the quieter you become the more you are able to hear...
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: Multimeter cables suggest
    I use the Fluke Tl190 probes with replacement springloaded tips, took a few pictures for you.
    If i remember correctly Pomona also has these probes.
      • 31248
      scope probes are small already,
      for meters i use a dremel to grind the probes to a VERY sharp point!!!
      • ank
        • Apr 2014
        • 8
        • Cyprus
        Getting a point sharp probe, either buying one or grinding one may not be much trouble. What am interested in is how do you prevent your probes from wandering on the wrong pin or track or even worse shorting one on those hair style smd pins? Or do you all have surgeon precision handling?
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          It takes good eyes and a steady hand. There's no doubt about that.
            • 31248
            indeed, no other way.
            you can put sleeving on the probe so only the last few mm are exposed - but it wont stop you putting it between pins instead of on them!
            • ank
              • Apr 2014
              • 8
              • Cyprus
              well, seems, sadly, I am getting old.
              • fpliuzzi
                • Nov 2012
                • 15
                I also find that it's getting more difficult to probe some of the microscopically sized components that are found on some PCBs.
                I had a couple of 2mm tip jacks in my parts drawer so I shortened two sewing needles and soldered them to the leads of the tip jacks (my tip jacks look more like capacitors in the photo below). Most of the exposed needle is covered with tough translucent teflon sleeving and the tip jack itself is covered with heat-shrink sleeving.
                When I slip these sharp adapters onto my DMM probe tips I find that I can probe some extremely tiny circuit locations.
                The part that I like the best about them is that they are quick to install onto any set of standard probes from my various meters and that they are so sharp that they seem to 'stick' to any soft solder that they come in contact with. They have virtually no tendency to slide around.
                These also come in handy if I need to probe through the insulation of a wire or through some shrink sleeving. The hole that they leave is so small that it's virtually self-healing.
                Of course, I only use these adapters when probing low power circuits.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Nice mod fpliuzzi!
                  • fpliuzzi
                    • Nov 2012
                    • 15
                    Originally posted by momaka
                    Nice mod fpliuzzi!
                    Thanks momaka. I really do find them quite useful on my test bench.
                    • ymichael
                      • Jun 2014
                      • 4
                      • Israel
                      Consider these. I bought few and they are good quality.
                      http://www.ebay.com/itm/Hard-pin-SMT...item4acbbcbe28
                      Hard pin SMT IC SMD Multimeter Test PEN Probes Cable 4MM BANANA PLUG Repair Tool
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        thanks @ymichael
                        • JASTECH
                          • Jul 2014
                          • 27
                          • U.S.A.
                          I use Oldaker & Fluke silicone leads. Now sense Fluke owns Pamona you can save money on the badge. Here is a good starter set for you, I like being able to change implements on at least one or two sets, then the rest are specific use leads. They all work good on my Fluke 45 Dual and Keithley 2000 which are very accurate, so don't spare the folding money on the leads.
                          http://www.ebay.com/itm/Pomona-Elect...item35bbb49e48
                          • corrize
                            Small and robust multimeter probes
                            by corrize
                            Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
                            05-13-2023, 02:36 PM
                          • mikey5791
                            Help repair Panasonic fridge not cooling
                            by mikey5791
                            Hi all forum members,
                            Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                            After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                            07-16-2025, 02:01 AM
                          • rutgerv
                            Acer Swift 3 SF314-42 not powering up
                            by rutgerv
                            Dear all,
                            For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                            The issue with the Acer laptop is the following:
                            It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                            08-02-2024, 06:59 AM
                          • trex66
                            Craftsman 82345 Multimeter broke!
                            by trex66
                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                            03-04-2025, 04:26 PM
                          • Sofian75
                            Things not to do with a multimeter?
                            by Sofian75
                            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                            I fixed some of them and some I ve made things worse by blowing components.
                            Every time while taking measurements with my multimeter.
                            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                            So my question is are there things I should not do with my multimeter?
                            Or measurements I should do only with the charger and battery unplugged?...
                            06-27-2024, 05:13 AM
