Which ESR Meter - On a budget
Re: Which ESR Meter - On a budget
The BlueESR would be the most trustworthy of the three.
But talk to RusMike here on this forum and see if he can sell you the ESRMicro at a good price.
The official page is here, but in russian (there's english manual link at the bottom) : http://www.radiodevices.ru/esr/esr4.htm -
It's a tested design, with history, made by a guy that knows what he's doing, tried and used by lots of people.
The other two are clones, might be good, might be bad, few people bought and reviewed them so I and other people can't guarantee they work well.
I personally own the ESRMicro and I like it, it works well, other people on this forum have that ESRMicro and RusMike is quite helpful so I have no problems recommending his meter.
I bought it for around 50$ but I don't know how much it would be for you, i bought mine months ago.Comment
The perfect ESR meter it should have a complete frequency range 100Hz-100 KHz, and high resolution at the minimum of 2.000 counts for the ESR measurements.
https://www.badcaps.net/forum/showthread.php?t=23638
On a budget ?
The ESR or LCR meters are tools that makes money for you.Comment
Sale set of the assembly.
Price without delivery-19$.
C/ESR meter
C-1...150000uF
ESR-0...10Ohm(resolution-0,001Ohm)
http://www.radiokot.ru/forum/viewtopic.php?f=18&t=76620
any of you guys saw china's latest offering
http://www.ebay.co.uk/itm/Transistor...item27ce36539e
whats your thoughtsComment
I built the meter featured on this http://electronics-diy.com/esr-meter.php page and although ive not had the opportunity to compare it to any other meter hands-on it seems to do a decent job and it was quite cheap to source parts for.Comment
Poor LCD resolution regarding ESR.any of you guys saw china's latest offering
mdoc which esr pictures are you referring to my post 12?
http://www.ebay.co.uk/itm/Capacitor-...item27cdecfdfeLast edited by vinceroger69; 01-06-2013, 03:20 PM.Comment
			by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
							Channel: General Capacitor Questions & Issues
			by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
			by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
			by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... -
			by expertreaderDell 5520 South peak 15 MB 213253-1 2TWTT$LA
Hi all, looking for some help to get started on troubleshooting without schematics
I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.- no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
 - most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
 - i have measured 16.5V available at the capacitor
1 Photo - Loading...
 - No more items.
