fried power supply
  • kaniki
    • 514
    fried power supply
    i had a friend bring their PC over. they said that they had a slight power surge or something, not really sure but something happened with the power, then all the sudden their PC would not turn back on. I checked it and found the power supply dead, replaced it and all was good again.. luckily nothing else fried. I am not sure if this thing frying is what effected the power or if it was something else, all i know is the bottom of the wires were partly melted, the one cap closest to the aluminum heatsink right by the orange power wires was a little off center and the board was black under it and by the side like it was burnt. when i tried to wipe the dust off to see what kind it was, it started cracking like brittle old plastic. on the side of the cap it looked like a VR(M), but was kinda melted so hard to say for sure. All i could think was, "dang, she is lucky that she did not fry anything else".
    forgot to add, the fan was good and still worked too so was not overheated because of that and really no build up from dust either. I never cleaned it out. the way you see it is the way it came out.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: fried power supply
    gutless wonder.
    total trash. looks like a-power, leadman, or powmax. i'm sure many can attest to s***ty that unit is. it is probably too light for a paperweight/doorstop.
    4 diodes. no x caps. fake y caps. crappy primaries. not enough caps on the secondary. only one PI coil. bad heatsinks. fake choke. thin wire. crappy fan. probably wimpy crap on the heatsinks, maybe even two diodes bolted on. must i say more?
    not even close to being worthy of a recap needs it... remove the nichicon cap(s), desolder the switch and plug, cut out the wire, desolder the one PI coil, and trash the rest.
    sigpic
    (Insert witty quote here)
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      It was a Nichicon VR, only rated for 85 degrees C.
      Shouldn't be used in a PSU.
      Looks like maybe the solder for the +12v wires grounded on the casing.
      Mann-Made Global Warming.
      - Dr Seuss
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        so i guess we have a new unit for target practice!
        sigpic
        • c_hegge
          • Sep 2009
          • 5219
          I pulled a PSU with similar-looking heat damage to that out of a customer's PC at work. It was a "TT" branded deer PSU. It took the motherboard with it when it failed.
          https://www.badcaps.net/forum/showpo...9&postcount=46
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It looks almost strange
            The coil is totally roasted but the caps have not started to bulge?
            Must have been some severe heat there...
            Probably the position of the fan makes it not blow any air over the secondary side due to the admittedly really impressive heatsinks (the only thing impressive about this unit and it turns out to be it's demise, lol :P)
            Perhaps the primaries are fake then, if it indeed failed after a power surge...
            As said before, not worth a repair but could be interesting to do an autospy on it to see how much they cheated
              • 31015
              nice junk,
              i doubt there was a power surge,
              more likely the psu blew and glitched the power in the house.
              i'v seen loads of stuff fail that can make lights flick.
              • everell
                • Jan 2009
                • 1514
                Looks like a 600 watt power supply bought on sale for $19.95..........looks like the 12 volt wires are damaged the most, probably the source of the problem. The 5 volt and 3.3 volt wires also look burnt.......maybe as the 12 volt rail was going down, the regulator tried to keep it up causing the power supply to cross-load and make the 5 volt and 3.3 volt lines overheat.......which would explain why the coil is burnt so badly. If the 12 volt line went down first, the fan (powered by the 12 volt rail) would have been off. So lots of heat. Wire damage, pc board damage, and several components fried. Looks like good target practice to me!
                I don't think it is a PowMax. They go POW, catch fire, burn, smoke, and do lots of damage to everything including mobo.
                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Originally posted by stj
                  nice junk,
                  Agree.
                  Power surge would have fried input stage of PSU or maybe middle.
                  This one is fried at output stage.
                  - Dr Seuss
                  • kaniki
                    • 514
                    it was a 450w powertek power supply. it had a good run. it has been used in the pc since the big blackout of 2003 if i remember right. so 7 years is not all that bad. at the time it was put in, the owner did not have a lot of cash so got a cheapo put in it. well, at the time they were also running a 350 or 450MHz or something like that processor. Old g-force 2 card if i remember right maybe half gig ram at most. and maybe a 20 gig power supply. so not a real great system from the start. i figured, system was not worth much so no real harm in putting a cheapo power supply in it. Since then they have upgraded parts here and there for the little money that they have. now they have a 2.2 gig processor, 768 ram and a 40 gig hard drive. that is not too bad. just happy that it did not take anything else out.
                    • kaniki
                      • 514
                      also all the caps that i looked at in there.. they were all just just about all 85 degree caps.. im not sure if i saw any 105 ones in there
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        almost looks like someone recapped this one before... with good brand caps but totally wrong series..
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          That's a Leadman/Powmax - you can tell by the "LP" markings on the main and 5vsb transformers. The style of the heatsinks is also very common for Leadman/Powmax.
                          It's a cheap PSU regardless. I wonder why the power surge made it blow. Seems like it should have went by itself long time ago.
                          By the way, what's the date code on the Nichicon caps? I doubt Leadman/Powmax would buy new Nichicon caps to use in their PSUs. Perhaps it's been recapped like Scenic suggested.
                          • seanc
                            • Nov 2008
                            • 1319
                            nice junk,
                            Seconded.
                            I have a PC running as a NAS on a UPS.
                            I came in to find the UPS screaming and the NAS off.
                            Thought 'ugh, the UPS has died', plugged it into the wall, the power light would flash on then nothing. Replaced the PSU, put the UPS back in and all is OK (for now).
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Looks like the same leadman as the chiefmax 650w in the jg bargain basement psu roundup that fried at 184 watts.
                              http://www.jonnyguru.com/modules.php...=Story&reid=71
                              That big section that is cut out actually use to be there, before jg did reviews on his own site, he did them for some other site. He tested a demon 680W which was another one of these leadmans but it had that large chunk that was missing in this unit, the only thing that was on it was the silkscreening labeling it as being made by leadman (which as you can see is visible to the consumer, especially with a 120mm fan, maybe there was a reason they cut that part out )
                              • kaniki
                                • 514
                                as for it being recapped, as far as i was aware, it was supposed to be brand new when i bought it.. as for the caps.. the 3300 10v one up front is a 105 degree nichi with date code h9902 series PW(M).. the 2 extra large caps are both 85 and all the caps that are something like 10mm high, those are half 85 and the other half are 105 degree caps.. 2 largest are GEE brand, all, if not just about all of the rest are nichicons.. i still had it sitting here so looked it up..
                                as for when it blew.. i just said that there was a power thing going on.. i never said that it caused the power supply to fry.. it may be the poser supply frying that caused the power flux.. dont really know though..
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                  by sam_sam_sam
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
                                • CMCM
                                  Russound CA4 Power Supply Repair
                                  by CMCM
                                  Hello Everybody,
                                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                  The outputs marked 12v and 20v are all measuring only 1v.
                                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                  The capacitors physically look clean (no bludgesor leaks) and...
                                  07-03-2025, 01:12 PM
