The Indestructible iMac G5 - Full Poly Mod
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: The Indestructible iMac G5 - Full Poly Mod
    mine came in.
    it is the badcaps.net poly mod #3. it is a 17"
    the solder work was done by topcat and i attest it works great.
    how i got it will be secret unless topcat says how.
    Not a state secret, so I'll spill it... It was one of the donors. I ended up with 8 of these systems, so what better way to further test than to put a few out into the world. I gave 2 of them away, Larry got one, another friend of mine got the other one. I gave one to my wife, she loves it....loves it enough that she dumped her PC. Lets see, I have one in my home office, I have another in my shop office, one in the lab, another is reserved for my workroom addition when its finished, and I'll use another one out in the shop as well. These are the absolute best internet terminal/email machines. They're small, self-contained, and with the polies, should outlive all of us!
    FWIW, this post was made from the 20" shown above. I use the system all the time, its been solid as a rock.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      thanks topcat!
      yeah... macs are not too bad... i wpuld not pay full price for one, but this g5 kicks butt.
      sigpic
      (Insert witty quote here)
      • weirdlookinguy
        • Sep 2007
        • 1638
        Now I really want one!
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i gave up on trying to get leopard to work. dl dvd+r's are soooo expensive! and the compression trick to make it burn to a sl was a waste... it wouln't work in the stock drive (it did a usb dvd-rw dl fine but usb= no boot).
          so, i am installing ubuntu ppc 10.04 on it for sh!ts and giggles... maybe that will work better....
          sigpic
          • Rick_Hardslab
            • Jan 2011
            • 3
            Sorry to be grave digging but I'm really curious how the poly caps are holding up and also on your diagram you seemed to indicate that you replaced the 5 16v caps with 330uf but the originals were 1000uf, This is surprising that 1/3 the original value works.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              it's the ESR that matters, not so much the capacitance.
              i've seen this on a bunch of PC motherboards too.
              "low end version" of one board had 4x 16V 1200uF "classic electrolytic" VRM input caps (on 12V) while the more higher end / expensive version of the same board used 4x 16V 470uF polymers instead.
              that's 4800uF for the lytics and 1880uF for the polys.
              ESR on the polymers is still quite a bit lower than on the lytics though
              edit: while looking at the first post again i thought about something..
              do all those blue marked polys in the very first pic in post #1 necessarily have to be 6.3V ?
              as in: is the actual voltage they're on really that high?
              if not, one could also use 4V or maybe even 2.5V polys if the voltages are low enough.. but i kinda doubt it..
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                #27
                As long as there is enough capacitance to form an effective lowpass filter at the switching frequency, the board will work fine. This can be calculated, but there is no such calculator online and i'm too lazy to throw a spreadsheet now. The only reason why a lot of capacitance was traditionally used in CPU supplies was because they had high ESR and/or dissipation capability. As capacitors get better we need fewer of them.
                2.5v polys can be used on the CPU Vcore.
                A working TV? How boring!
                • Rick_Hardslab
                  • Jan 2011
                  • 3
                  #28
                  The bulk (twenty some) of the caps are 6.3v because they are floating on the 5v rail. You always want a cap to be rated to survive more voltage then you are trying to store in it, as overflow is quite destructive. The 5 16v caps are for the 12v rail.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    i've never seen one of those iMacs in person, so idk what voltage rails the caps are on.
                    was just a random thought (the lower voltage caps)..
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      All the test subjects are holding up well. My wife's never gets shut off, still cranking along fine.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        mine is rock solid. no complaints.
                        sigpic
                        • TheLaw
                          • Jan 2011
                          • 477
                          #32
                          Kinda want to buy a broken one off eBay now...What kind of power supply do you need? Is it proprietary bull---? or standard plugs?
                          See if I can get a Mac running for under $200?
                          EDIT: I see it is a proprietary. If I buy a dead PSU, is the problem usually bad caps or?
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            Its definitely proprietary. the iMac is an all-in-wonder system. Plug is the same as a regular 20-pin ATX, but an ATX PSU won't power one. You can get broken iMacs off ebay all day long for 200 or less. A good condition 17" imac in need of recapping averaged about 100 bucks last time I looked at them.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Toasty
                              • Jul 2007
                              • 4171
                              #34
                              Make sure you get one with ALL its parts. Many of these are "such-a-deal" with no hard drive, no drive carrier, no RAM, no keyboard, no mouse, no OS or discs, no Superdrive or bracket..... for $200!!! PLUS S/H of only $90!! . . . . Are you nutz?!?
                              Apple Keyboard $35-$50, mouse another $10-$12
                              Hard drive $25-$50
                              Drive carrier $15
                              RAM $22 each or $45 for 1 Gb (2 pcs 512)
                              Superdrive $100 new ... $20-$35 used/refurbished
                              Superdrive bracket $15
                              OS X 10.4 Tiger $10-$50
                              A complete system with -all- its parts from an -original owner- in the -original box- can be had off of Craigslist for $100-$150. You just have to pick up. I just got a 20" system like that for $110 but I had to drive 40 miles round trip...
                              Be careful and ask a lot of questions. Your looking for answers like "It was my dad's or mom's". Make sure the casing, stand and back cover are intact, no chips, cracks, or broken lock down clips. The screen should be perfect. No scratches no dead pixels.
                              Toast
                              veritas odium parit
                              • TheLaw
                                • Jan 2011
                                • 477
                                #35
                                Hmm....I wish I could just use the motherboard and hook up regular PC hardware to it which should still let me use Mac OS X. Ehh...Maybe I'll just try one of those lovely Optiplex mods. I need a cheap HTPC. >.<
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  you can install OSX on pretty much any modern x86 PC if you want to
                                  http://wiki.osx86project.org
                                  http://www.insanelymac.com/forum/ind...?showforum=178
                                  http://tonymacx86.blogspot.com/2010/...c-os-x-on.html
                                  • TheLaw
                                    • Jan 2011
                                    • 477
                                    #37
                                    I've always found the legality of those a bit sketchy, though I don't believe having closed software is cool either.
                                    • Scenic
                                      o.O
                                      • Sep 2007
                                      • 2642
                                      there are packages out there which use a retail OSX DVD (and encourage you to buy one ; they're pretty cheap).
                                      basically those installer packages consist of a loader for the retail DVD (including patches) and a bunch of kext's ("drivers" in mac-speak)..
                                      no need to download sketchy prebuilt .iso's via torrents or crap like that.. (iAtkos, Kalyway and whatever they're all called..)
                                      the last link in post #36 is actually about one of those loader-packages
                                      • ryogadan78
                                        iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                        by ryogadan78
                                        Hi guys, I need your help again.
                                        I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                        When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                        06-10-2025, 03:49 AM
                                      • Stephen
                                        iMac M1 DFU restore issue
                                        by Stephen
                                        iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                        this is the message it gives me with the error
                                        Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                        Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                        03-07-2025, 12:19 PM
                                      • Stephen
                                        iMac 27” 2020 Boot issue
                                        by Stephen
                                        Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                        08-16-2024, 09:32 AM
                                      • tommy97
                                        iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                        by tommy97
                                        we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                        Any ideas what might've...
                                        04-20-2024, 04:48 AM
                                      • CapLeaker
                                        Poly VVX-250 VOIP POE problem not booting fix
                                        by CapLeaker
                                        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                        11-25-2023, 10:46 AM
