Heatsink cement?
  • Retrorockit
    • Feb 2020
    • 105
    Heatsink cement?
    I had been using Arctic Silver 2 part heatsink cement. But 1 part set up in the tube and I can't seem to find it anymore. What do you guys recommend for this. Dell doesn't put heatsinks on their VRM and I find they help when overclocking these things.
    I've been told not to use Superglue because the vapors when heated can screw up the lasers in optical drives.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Heatsink cement?
    Superglue also fails with heat. I use this stuff https://www.aliexpress.com/item/1005002615667957.html it dries hard but with a slight bit of flex.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I've used JB weld for decades. Transfers heat nicely and the sink will never come off!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Retrorockit
        • Feb 2020
        • 105
        JBW sounds interesting. But I harvest my expensive Enzotech copper heatsinks from my old projects. I think the JBW would win that arguement.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          I've used JB Quick for this, including copper heatsinks to MOSFET cases.
          If/when you need to save them, a quick blast from the torch expands the heatsink and breaks the bond.
          Do this in a somewhat "controlled" manner, obviously...
          Then scrape the residue from the heatsink, preferably when still warm.
          Obviously, anything you remove the heatsink from in this manner will be damaged.
          Now if there's a need for something more thermally conductive, use equal parts of JBQ resin & hardener, and half as much Arctic Alumina.
          So 1 part JBQ resin, 1 part JBQ hardener, and 1/2 part AA.
          It doesn't seem like it would work, but I've used it for GPU RAM sinks & NVME SSD cooling.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
            • 31131
            you can buy stuff designed for the job.
            the best - but expensive is zinc loaded epoxy.
            much cheaper is thermal rtv - you can get that on ali-express.
            it's usually gray.
            • Retrorockit
              • Feb 2020
              • 105
              I started looking around at Digi Key lots of choices there. Newegg was a waste of time.
              • harp
                Metod for removing glued heatsink from fragile component
                by harp
                I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                06-23-2025, 02:01 PM
              • Ven
                Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                by Ven
                I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                07-08-2024, 09:32 AM
              • harp
                can fanless heatsink replace poor original on RX26PG2
                by harp
                I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                06-25-2025, 10:56 AM
              • PowellSkier
                Cement resistor swap in Harman Kardon AVR
                by PowellSkier
                Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                06-04-2024, 06:41 PM
              • nobbnobb1
                Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
                by nobbnobb1
                I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
                There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
                09-08-2022, 09:58 PM
