Adding new RAM
  • stevo1210
    • Oct 2006
    • 4156
    Adding new RAM
    I was at the computer store today and the guy there said that to add RAM we should pull our whole god damn systems to bits and lay the motherboard flat on a surface because apparently adding RAM inside a PC bends the board and can severely damage it.
    I have added RAM to systems without prying them to bits for years and I haven't had a failure yet... but i dunno... what do you guys think?
    Please don't tell me that this is true otherwise I'll spend hours taking a system apart just to add a RAM stick...
    Right now, the only thing that requires me to pull a system to bits is changing a CPU because it requires alot of force.
  • washu
    • Jul 2009
    • 310
    Re: Adding new RAM
    I've been putting RAM in PCs since the days of individual DIP chips and I have never taken a MB out just for that. Never had a board die from it either. As long as the correct MB support standoffs are in place there is no issue.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Adding new RAM
      rule#1001 about life:
      some people are fucktards. they often end up as managers, designers, and "experts".
      rule #1002: those in rule #1001 are not to be trusted, listened to, or considered knowledgeable in their given field. their advice often is worse than that of the drunk guy passed out by the dumpster-YES, THAT one!
      sigpic
      (Insert witty quote here)
      • weirdlookinguy
        • Sep 2007
        • 1638
        Re: Adding new RAM
        You heard this from a computer shop. The shop is a business and businesses by nature exist to make money. Spreading bullshit about how a long and complex procedure is needed (for which they can charge a fat wad of $$$$$ for) is in their best interests.
        Besides, I think the forces needed to pull a motherboard out of a case have much more potential to fuck something up than flexing it for a split second while you pop RAM in.
        • AudioCraZ
          • Sep 2009
          • 147
          Re: Adding new RAM
          I have seen where there are bolt and standoffs on one side of the ram slots, but not the other, and the board will flex a bit when you put new ram in. In super rare occasions, this can damage the board..... I honestly have never seen it happen, but enough flex can do damage.
          In all honesty, if you are worried about breaking a board when putting in ram, just find a piece of plastic that is about the same thickness as the gap between the board and the mobo tray. put it under the corners (not under contact leads, don't want to bend them together) to support the board when you put in ram.
          Should you pull a mobo to install ram? No, never. Yeah, if you already have the board out, go ahead and install the ram, but never pull a board just to install ram, not needed.
          • NxB
            • Feb 2009
            • 1595
            Re: Adding new RAM
            It is easier to seat the ram when the board is out of the case but I'd never pull it out just for the ram. You can crack some solder joints if your really careless or trying to hammer it in.
            The store guy is stupid.
              • 31091
              Re: Adding new RAM
              probably tried to sell you an anti-static wrist strap too!
              • ant3202
                • Jun 2006
                • 275
                • Singapore
                Re: Adding new RAM
                it is just fine, if you are careful.
                i had performed upgrading frequently with the board in the case.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • BOSCHNJAK
                  by BOSCHNJAK
                  ABOUT ME INTRODUCTION FILE
                  2
                  024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                  2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                  2022 BEV, PROJECT ?
                  2021 BEV, PROJECT ?
                  2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                  2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                  12-28-2023, 02:09 PM
                • NecroFlex
                  Adding/unlocking CPU support for an HP EliteOne 800 G2 AIO
                  by NecroFlex
                  I bought a used HP EliteOne 800 G2 All in One PC, that has an i5 6500 in it with BIOS updates going into 2023. The Chipset in the AIO is a Q170, so in theory it should support 7th gen.
                  HP site only shows a few 6th gen supported, when i inserted an i7 7700k (dead mem. A channel, but would be good in the AIO since i can just put a single 16GB stick in there) with the newest 2.60 bios, the AIO powered on and beeped/flashed an error code for the RAM (3 long 2 short) in the first ram slot and in the other slot it powered on, restarted and then stayed on a blank screen.
                  I'm...
                  02-22-2024, 11:56 AM
                  MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                  The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                  Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                  10-23-2024, 03:23 AM
                • Benass
                  GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
                  by Benass
                  This will be a headscratcher. I don't know how to break it down to a readable topic.
                  Im troubleshooting Rx5700 GPU. Core voltage missing.
                  I have schematics and Boardview.
                  I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
                  • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition.
                  10-11-2024, 01:58 PM
