MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output is within its nominal voltage range.
    NB670 also provides a 3.3V LDO, which can be used to power the external peripheries, such as the keyboard controller in the laptop computer. A 300kHz CLK is also available; its output can be used to drive an external charge pump, generating gate drive voltage for the load switches without reducing the main converter's efficiency.
    Full protection features include OCP, OVP, UVP and thermal shut down.
    The converter requires minimum number of external components and is available in QFN16 (3mmx3mm) package.
    NB670 NB670GQ Features
    • Wide 5V to 24V Operating Input Range
    • 3.3V Fixed Output Voltage
    • Built-in 3.3V, 100mA LDO with Switches
    • 6A Continuous Output Current
    • 9A Peak Output Current
    • 300kHZ CLK for External Charge Pump
    • Low RDS(ON) Internal Power MOSFETs
    • Proprietary Switching Loss Reduction Technique
    • Internal Soft Start
    • Output Discharge
    • 500kHZ Switching Frequency
    • OCP, OVP, UVP Protection and Thermal Shutdown
    • Latch off Reset via EN or Power Cycle
    Applications
    • Laptop Computer
    • Tablet PC
    • Networking Systems
    • Personal Video Recorders
    • Flat Panel Television and Monitors
    • Distributed Power Systems​
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • questore
    Looking for a DC-DC step down converter module to replace a 0.75v_ALW output and enable pin
    by questore
    Hello Everyone,
    I need your help, maybe you have know where to buy a replacement.
    I have a NM-D562 laptop motherboard that has a burned 0.75_ALW converter. (the layers and the pins also burned so i dont want to restore it but i need a replacement)
    I have checked with lab power supply output (0.77V) laptop works, so i need a DC-DC module that can do its job.
    According to schematic datasheet what i need on 0.75V_ALW:
    Vout=0.75V±37.5mV
    Vset=0.752V±1.46%
    Vref=0.6V
    TDC=4A
    OCP=9.5A TYP=10.5A MAX
    OVP=(1.15~1.25)*Vout
    UVP=(0.6~0.7)*Vout​...
    11-10-2025, 03:36 AM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
    Corsair CX750M [Model 75-002019] - burned output toroid inductor
    by momaka
    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
    09-19-2021, 08:44 PM
  • CoppellTVRepair
    Troubleshooting PFC with SPC1012T not raising output
    by CoppellTVRepair
    It has been a long while since I posted here to ask anything....hope you can help.
    I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
    I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
    03-09-2025, 10:38 PM
