New to me PC, CPU Choice?
  • SluggerB
    • Aug 2020
    • 747
    • US
    I'm building a "new to me" PC. The board is an Asrock 970M Pro 3. Her is the CPU support list.
    https://www.asrock.com/mb/AMD/970M%20Pro3/#CPU
    I want to get the fastest 8 thread 95W CPU I can for the thing. It looks like that's the Vishera 8310 (https://en.wikipedia.org/wiki/List_o...icroprocessors). But looking on eBay that seems to be a harder to come by CPU and a little over $110. The Vishera 8300 is a smidge slower, but more readily available and cheaper at around $75. Which should I choose?
    If I go for a 125W CPU like the 8350 or 8370 I will need a new power supply, is the increase in speed worth the $$ in extra hardware?
    Also I need a cooler for it, any reccomendation for something affordable. I will not be overclocking.
  • dragos2009
    • Mar 2013
    • 110
    • Romania
    Re: New to me PC, CPU Choice?
    what dodgy af psu do you have that can't run a 125w cpu ? and tbh even the extra little mhz boost would benefit as these dinosaur design fx are not good at all at single core performance cause they have a really low instruction per clock capability vs intel haswell gen which was their main rival and obliterated them in single core and ipc performance in games intel runned far away from amd fx
    • RJARRRPCGP
      • Jul 2004
      • 6304
      So, you couldn't even get a Pinnacle Ridge (second-gen Ryzen) or a Summit Ridge (first-gen Ryzen) build? (socket AM4) (socket AM4 is the first to use DDR4, while Intel did, since Skylake (Skylake was launched in 2015) )
      FYI, back in the FX era, pretty much only Asus made motherboards worth a thing! You will be lucky to get ones from others that are OK-ish.
      For socket FM2/FM2+: (also before Ryzen)
      I have to admit that I have an FX-architecture-based Athlon X4, which is pretty much an FX with 2 modules. (Kaveri, which is the code name for the 860K) (possibly the same for the ones with the APUs, which are A8xxx)
      (Richland was the one before Kaveri, which is AMD's version of P4, LOL!) (Richland was identified by A68xx series for APUs) and (7xx for the Athlons)
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • SluggerB
        • Aug 2020
        • 747
        • US
        Well, "could" is a notional concept
        I got about 1/2 the hardware for this upgrade build for free. My current PC is an Athlon X2 with 16GB ram, they new one will have 32GB and a new CPU, so while I get this isn't going to be cutting edge it should be a lot better then what I currently have. I could just put my current CPU in the build but I would like to "upgrade" if I can.
        So back to my original question is the 8310 worth then $30 more than the 8300, and what heatsink should I get?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I never saw the 8310s. For heatsinks, I would give this a try, as CoolerMaster heatsinks can be difficult to install:
          https://www.newegg.com/noctua-nh-d15...quicklink=true
          Arc A770 16 GB
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Waste of time honestly. Only reason I still run something on that platform is I got an FX8320, 16GB of RAM, and a MB with 8 SATA ports and ton of PCI-E ports for more SATA cards... for free.
            BTW the darn thing uses 300-400W at idle. Albeit with 16 hard drives. But most of them are 5400rpm/5900rpm.
            I can send you a free 1155 board if you want. Just pay shipping. Yes it's an old platform too but at least useful... If you want it PM me.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Heck, I've still got lga771/775 systems in my 'active pool'....and no plans to replace them
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                what purpose do these 'active pool' systems do?
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  For instance, the most heavily used system I own; office machine....doing functions of probably 90% of systems out there....lots of browsing, media playing, lots of other weird tasks...zero gaming. Dual LGA771. Any other questions?
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    how much are you paying for this whole thing? Maybe we can find a better deal. Noses 1155 board is a good idea. sandy/ivy bridge chips beat the crap out of those FX's
                      • 31050
                      dont forget to run any intel bios through ME Cleaner.
                      https://github.com/corna/me_cleaner/...cleaner-status
                      • SluggerB
                        • Aug 2020
                        • 747
                        • US
                        I got the motherboard and RAM for free. I am moving my existing HDD's, Power Supply, and video card over since they meet my needs just fine. The only $$ I've spent is for a new case since it's a mATX board and I wanted a pretty white one.
                        I could just swap my current CPU over and call it a day but if I can upgrade to a newer one for better performance for $75 I'm OK with that. My current CPU is a AMD Phenom II X4 945 3.0GHz Quad-Core. It's REALLY old. But the only "intensive" thing I do with this PC is host VM's and my current Phenom/16GB RAM does that just fine (for my needs) so I would imagine a newer CPU and double the RAM and Cores would make it even better. I do zero PC gaming it just doesn't interest me.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Take my board buy an i7 2600 on eBay for $65 and be happy
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            That would be a decent one as well. My home system is exactly that with 16gb RAM and a SSD; Optiplex 990SFF.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Yeah, that CPU is no slouch. Plenty of power for even modern games unless you're doing multi-monitor 4k 144hz or something haha. I mean, sure, compared to the latest i7 it's a joke but it's still enough for 95% of normal folks with normal use cases. i'm still using an i7-6700 for my main personal/work/gaming PC.
                              https://www.cpubenchmark.net/compare.../1vs3747vs2598
                              • SluggerB
                                • Aug 2020
                                • 747
                                • US
                                Would it be compatible with the RAM I got?
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  Just the usual PC3-10600.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    it's a biostar h61mgv3. kinda lowend board, only two ram slots. what do you plan to use the pc for?
                                    • SluggerB
                                      • Aug 2020
                                      • 747
                                      • US
                                      Hosting VM's, and I have 4 sticks of RAM so I would need 4 slots. Thanks for the offer though
                                      So back to my original question, 8300 for $75 or 8100 for $115? And links to a compatible heatsink? Thanks!
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        I'd go for the fx8350 myself.
                                          I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
                                          by sam_sam_sam
                                          Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
                                          https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
                                          I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
                                          08-03-2024, 02:54 PM
                                        • cloppy007
                                          [MSI KT3 Ultra ARU] Advice on capacitor choice
                                          by cloppy007
                                          I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
                                          The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
                                          There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
                                          I think I recall hearing that I don't have to use the same capacitance for in series...
                                          08-21-2023, 03:18 PM
                                        • japlytic
                                          Donkey Kong Junior arcade DMA controller choice
                                          by japlytic
                                          This is about a component in a computer system being a DMA controller.
                                          Interestingly in a circuit diagram for the Nintendo arcade game Donkey Kong Junior from 1982, even though it has a second-source Zilog Z80 compatible CPU, the DMA controller is an Intel type (8257) instead of a Zilog type.
                                          My theory is that at the time, even though there was domestic second source manufacture for the 8257 but not (possibly) for the Zilog type DMA controller and that Nintendo (and a number of others) wanted to be loyal to their country by trying to only source components from Japanese ...
                                          12-01-2022, 01:39 AM
                                        • wyga
                                          HP 15-cw0994na - Battery issues and choice of new one?
                                          by wyga
                                          So there is this laptop HP 15-cw0994na with battery issue.
                                          It goes to 100% charge, but take the charger out and give it top 5 minutes, it will cut off power. Won't start at this point from the battery itself.
                                          After plugging charger in, can be started as usual and begins to charge again from 0%.
                                          So pretty much dead battery right? Laptop is also 4 years old, I don't see anything out of place on board. Just old dusty laptop.
                                          So I have started looking for the replacement batteries.
                                          Original battery from this specific 15-cw0994na model is HT03XL...
                                          02-23-2022, 08:48 AM
                                        • notallbad
                                          LG Service menu android app
                                          by notallbad
                                          I had been using wave audio files to play via the headphone jack to an ir led but had difficulty getting the InStop file to light the led, no sign of life when viewing the led through the camera app on my mobile phone.
                                          Anyway, came across this free android app called IR Wave Plus that can utilise a homemade audio jack to ir led lead.
                                          Not limited to just LG either!
                                          A few settings require adjustment but the app itself is rather straightforward.
                                          In settings ensure the slider bar is set to maximum and Force volume to 100% for audio ir blaster is ticked.
                                          10-23-2024, 04:54 PM
