LG Service menu android app
  • notallbad
    • Oct 2012
    • 1190
    I had been using wave audio files to play via the headphone jack to an ir led but had difficulty getting the InStop file to light the led, no sign of life when viewing the led through the camera app on my mobile phone.
    Anyway, came across this free android app called IR Wave Plus that can utilise a homemade audio jack to ir led lead.
    Not limited to just LG either!
    A few settings require adjustment but the app itself is rather straightforward.
    In settings ensure the slider bar is set to maximum and Force volume to 100% for audio ir blaster is ticked.
    You can add a remote of your choice from a list and use without any further changes or if you want to change/add codes of your choice simply export the .irplus file extension file, rename it to a .txt file, edit the file in an editor of your choice, save the file then rename the .txt back to .irplus and import back into the selected remote. Found this very useful as the lg service remote only had service_m, instart and ezadjust so found pronto code for instop and added to the file in the same file format as the existing.
    Of course, just buying an LG service remote is cheap enough and easier to use but will only be limited to Lg brand, have one on order from Aliexpress for about £3 so shall see how it performs.
  • notallbad
    • Oct 2012
    • 1190
    Bought this, works a treat!
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • DutchDIY
      Philips 60PFL8708S/12 Android Upgrade Kit Issue (Pictures Inside)
      by DutchDIY
      Happy Holidays everyone!
      Here I have a 60PFL8708s/12 that I am trying to revive by installing the 996597007730 Android upgrade kit;
      The kit has been installed and I have followed the instructions to the letter, however upon powering on the tv with the USB stick and the files needed on there, instead of seeing 'Update in progress' all I am seeing is a black screen (backlight is fine). Also before turning on the tv, the white LED on the bottom of the tv is flashing around 60 times, before it going solid (standby mode), then I wake the tv with...
      12-24-2022, 08:23 PM
    • cstout
      DeLonghi AC Remote only accepts 3V
      by cstout
      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
      I can't find any schematics...
      06-03-2024, 03:53 PM
