HP 15-cw0994na - Battery issues and choice of new one?
  • wyga
    • Dec 2020
    • 16
    • United Kingdom
    So there is this laptop HP 15-cw0994na with battery issue.
    It goes to 100% charge, but take the charger out and give it top 5 minutes, it will cut off power. Won't start at this point from the battery itself.
    After plugging charger in, can be started as usual and begins to charge again from 0%.
    So pretty much dead battery right? Laptop is also 4 years old, I don't see anything out of place on board. Just old dusty laptop.
    So I have started looking for the replacement batteries.
    Original battery from this specific 15-cw0994na model is HT03XL L11421-421 HSTNN-LB8M. Rated 11.55V 3470mAh
    And I've been trying to match the same one but it's a bit difficult to find. They vary pretty much with capacity and voltages 11.34V 3440mAh / 11.4V 3600mAh / 11.55V 3470mAh / 14.00V 3600mAh. Where most popular from what I've seen were 11.34V / 11.4V / 14.00V but not the 11.55V.
    If I will find exact match it's either old untested battery taken from dead laptop or unbranded chinese replacement.
    There is however pulled & tested grade a batteries rated 11.34V and they claim it fits 15-CW...
    Now I am lacking here a little bit of knowledge.
    Could you throw some light on the differences here?
    I understand it is different laptop models, different voltages such and such but out curiosity I've been wondering what If I would like to fit HT03XL 11.34V instead of HT03XL 11.55V. Difference is rather minor but will we impact the device functionality, will it be prone to overcharge or is it rather difference in voltage due to its capacity?
    On the other hand if there is HT03XL battery rated 11.4V 3600mAh and similar HT03XL rather 11.55V 3470mAh something doesn't add up.
    So if anyone care to elaborate I would really appreciate.
    EDIT: I think I've done a mistake while writing down the different voltages & capacities... I thought 11.4V was rated 3600mAh but seems to be 3420mAh...
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-cw0994na - Battery issues and choice of new one?
    0.1 or 0.2V difference wont make much difference. mAH should be equivalent or higher(thats the storage capacity of battery cells). But dont go for third party chinese battery-they are crap. Battery will swell within 3-6 months of usage. Get hp original battery.
    • wyga
      • Dec 2020
      • 16
      • United Kingdom
      Thanks a lot.
      I do not trust those Chinese battery replacements at all so I wasn't thinking about it.
      So far that genuine, pulled 11.34V | 3440mAh seems to be from most trustworthy source comparing to other ones. I know the company itself, they are in fact testing those batteries, this one is Grade A with over 90% charge remaining and definitely it will be genuine one.
      Difference here between original fitted battery rating is 0.21V and 30mAh lower.
      If I am not mistaken there should be actually overcharge protection on battery itself, doesn't it?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        yes
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • mkdj
          ASUS X571 no power : battery issue?
          by mkdj
          Mark and model: ASUS X571
          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
          Tests already made:
          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
          - I have removed...
          07-14-2025, 09:16 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
          09-14-2023, 11:10 PM
        • DaLZy
          Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
          by DaLZy
          I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the...
          01-27-2025, 12:38 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
