Donkey Kong Junior arcade DMA controller choice
  • japlytic
    • Oct 2005
    • 2086
    This is about a component in a computer system being a DMA controller.
    Interestingly in a circuit diagram for the Nintendo arcade game Donkey Kong Junior from 1982, even though it has a second-source Zilog Z80 compatible CPU, the DMA controller is an Intel type (8257) instead of a Zilog type.
    My theory is that at the time, even though there was domestic second source manufacture for the 8257 but not (possibly) for the Zilog type DMA controller and that Nintendo (and a number of others) wanted to be loyal to their country by trying to only source components from Japanese manufacturers.
    • 31281
    Re: Donkey Kong Junior arcade DMA controller choice
    it was about price and quantity
      I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
      Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
      https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
      I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
      08-03-2024, 02:54 PM
    • GKdays
      Single capacitor replacement on arcade pcb
      by GKdays
      I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
      10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
      I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to...
      08-09-2022, 05:21 AM
    • redbaron1007
      Arcade PSU blown resistor ID
      by redbaron1007
      I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
      01-06-2023, 04:13 PM
    • edugimeno
      Diagnose real-vintage Strong-Hammer arcade machine
      by edugimeno
      Hi there!
      My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
      I am attaching several pictures of the machine.
      It basically has 2 sides, left side has
      • 2 x 220->12+24v transformers
      • 2 relays (1 moves motor UP, other moves motor DOWN)
      • IGF and breakers for safety
      Right side is shown on pictures. It has 3 boards ( top-down)
      • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
      02-29-2024, 11:05 AM
    • Stefo
      Help Understanding Darlington IC
      by Stefo
      Have a question above my understanding. (see attached pic and datasheet). Attempting to repair a pcb with a burnt out Darlington Transistor IC. I have identified all pins except for nos. 11 & 12 (Output 7 &8). I removed what is left of the IC, but could not find any traces as to where these pins might have been connected. Bad choice of words, there is no trace of any circuit trace for either pin. In the surrounding circuits i cannot find any without a verified connection to other components. My question is it possible these two pins are just hanging out there with no connection, nothing...
      01-11-2024, 09:14 PM
