Post your system.......
This is a sticky topic.
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Re: Post your system.......
My current system:
i7 2600K @ 4.2Ghz (Corsair H80 for cooling)
16GB DDR3 1333
Radeon R9 290X 4GB (reference)
MSI P67A-GD65
OCZ Vertex 3 120GB SSD
HDDs: Samsung HD204UI 2TB, Samsung HD642JJ 640GB, WDC WD5000AAKX-001CA0 500GB
USB HDDs: Seagate ST2000DL003-9VT166 2TB, Seagate ST3500418AS 500 GB
Corsair TX850 V2 850W PSU (Seasonic)
Antec Nine Hundred case
OS: Windows 7 Ultimate x64Comment
It's good friends, good fun, software piracy, and usual rude things...
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
thats the lazyass version of gaming...............anyone too lazy to bring a system to LAN, especially as small and light as they are today (LCD versus CRT, and todays light cases) was never a real gamer to begin with. Theres a lot more to a LANfest than gaming, and those too lazy to do it will never understand...sigpic
(Insert witty quote here)Comment
We had a few of those that would connect to the LAN. The place we usually LAN'd had a T1. Quake1 would play great over it. We'd play online every now and then.....but it was always lame. Gaming is more for the friendship, camaraderie, and getting out of the house.....sitting at home, wtf is with youth today?!<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
make that a pentium D and your dead on!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
My main system has 1GB RAM (DDR2) too and it runs fast.That system though uses the K8M890 chipset and has Socket AM2.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
It won't be fast by my standards. Fast to me means 10 sec or less boot up time from a cold start (ie, not from standby or sleep) and programs all opening nearly instantly (with the exception of some larger games maybe). The only way you get that on 7 is on a core i3 with an SSD.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Not related to the things above,I've weirdly and successfully got the board to POST with a Supermicro P4SPA+/P4SPE BIOS,which itself is Award,while the original P4P800-VM BIOS was AMI.The trick was to find a board that had the same Super I/O(Winbond W83627),CPU Socket (there are some boards that use LGA775 and i865,but mine is S478 and i865) and the same onboard NIC (Intel PRO 10/100)Last edited by Dan81; 06-17-2014, 05:13 AM.Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
Not related to the things above,I've weirdly and successfully got the board to POST with a Supermicro P4SPA+/P4SPE BIOS,which itself is Award,while the original P4P800-VM BIOS was AMI.The trick was to find a board that had the same Super I/O(Winbond W83627),CPU Socket (there are some boards that use LGA775 and i865,but mine is S478 and i865) and the same onboard NIC (Intel PRO 10/100)"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Strangely,I could also get to work the DFI Lanparty PRO875 BIOS.That one POSTs but freezes after CPU Brand Name,and what's funny is that from 1GB RAM it sees just 1MB!(1024K)Last edited by Dan81; 06-17-2014, 07:28 AM.Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
It was particularly funny when we were playing Counter-Strike and everyone would eventually look back and see where the person(s) from the opposing teams were. This was as bad as "cheating" would get (unlike nowadays). Then someone from the other team would eventaully notice. The usual conversation then was:
- "Hey motherf***s, were you looking at my screen again?"
- "who? me??? no way!".
Eventaully some bullying and friendly pucnhes were inevitable, followed by the LAN cafe's owner yelling at us. We never got kicked out for that, though.
Fun times.
ok now post a pic of your setup. I go second......
perhaps i should consider cable management. perhaps usual that a tech's office server cabinet is looking good but no energy left for the home system.....anyway please note that there are wood chocks shoved underneath the desk shelf to guarantee perfect burning. there is also the new main computer/networking piece of furniture which i made in about an hour using wood salvaged from the office which houses the zyxel switch and router and yes acts as a barmissing is the sofa chair which i sit on and sometimes fall asleep while browsing the net in the early hours.....
Swapped the Q6600 with a QX6700.
Specs as it stands:
3.2 GHz Core 2 Extreme QX6700, stock is 2.66 GHz
6 GB DDR2-800
500 GB WD Blue HDD
nSpire 650W Power Supply, actually a Channel Well design that's also shared with a thermaltake.
Radeon HD 4850 reference card
Freezer 7 Pro heatsink\fan
Antec P180 case.
Also took a picture of the inside of the system while I was at it, one that reflects what video card I've actually had for the last year or so.
Agreed.
I myself have been using my secondary computer a little bit more lately (after I switched the big 21" CRT monitor with a 17" CRT since it's summer and it's hot).
That system has:
- MSI MS-7191 socket 939 motherboard - almost fully recapped (de-Teapo'ed, at least).
- AMD Athlon 64 3000+, stock cooler and CPU fan
- 1 GB DDR PC3200 RAM
- 500 GB half-dying HDD
- MSI GeForce 7600 GS with 256 MB VRAM
- 250W HiPro DL-P2507FWP in a decade-old shell from a gutless PSU.
- Some random dark-gray mATX case I found on the curb before trash day.
Total cost of the system was under $15. The motherboard is really the only item I had to buy. Everything else was random discarded junk I found.
I still prefer my HP Pavilion 8756c (Pentium-3 based) PC. Has a real amplifier IC for the audio output. Also great during this time of the year when it's 80+ F in my room.Last edited by momaka; 07-24-2014, 01:57 PM.Comment
Might as well jump in on the action - at least for the sake of it.
PC: Scarab ~~ [ Click for full detailed list - (SpecList_Scarab.txt)]
Most of the parts are either purchased used or carryovers from my original desktop back in 1998 or so such as the sound card and mouse while others are just older hardware overclocked to hell and back. The fan guard on the back is salvaged from an old dead rosewill power supply which is inset rather than extended outwards lie your typical fangrill. This way it sits inside of the hole rather than above it to fit flush with the face.
For those that gawk at the monitor... I'm still waiting for a 19" monitor that gets better resolution than my CRT which is 2560x1920@56hz. The mouse there are none nowadays with the two-buttons in place of the wheel which I like so.. been using that so long the bottom is worn smooth. Had to replace the leftbutton actuator once, the cord twice, and the middle buttons membrane once over time. The keyboard... I hope one day to find a mechanical keyboard using that layout whereas there is no gap between the home-pad and the arrowkeys. I used to have one with ALPS switches till that got stolen from me.Last edited by chozo4; 07-29-2014, 06:20 PM.Even crap caps can be useful... such as blank rounds for prop gunfights.Comment
The start menu was always there in earlier versions of windows 8. The only difference is the actual API to bring it up was unlinked from the 'orb' that used to be there so wasn't actually accessable by normal end users. There are programs that re-link it to that api as the start menu code still existed in its' entiity at the time until 8.1 if I recall. There is also the alternative "startIsBack" that brings the familiar startmenu back in its' original form through remaking it for 8.1+.
http://startisback.com/#home-tab
Last edited by chozo4; 07-29-2014, 06:14 PM.Even crap caps can be useful... such as blank rounds for prop gunfights.Comment
by canadaboy25Hey guys,
I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
I rebooted...-
by SMDFleahttps://winraid.level1techs.com/t/wi...uncement/38021
The win-raid forums are closing at the end of this year,its a sad time for all who have used the site to gain knowledge from some of the really talented members there.
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by tbalint3Hello All,
I am trying to repair an old Abit ST6-R motherboard.
The symptoms are the following:
I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...3 Photos -
by canadaboy25Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...-
- Loading...
