Post your system.......
This is a sticky topic.
    Re: Post your system.......
    My oldish machine
    AMD phenom X4 955, 3,2GHz
    4GB memory (2x2GB)
    250GB Samsung (2,5" from my old laptop)
    500GB WD Caviar blue
    NVidia G-force GTX285 (1GB)
    MSI Mainboard (don't remember the model)
    DVD RW drive
    780W Power source
    After payday I'm going to buy some 128 GB SSD.
      Intel Pentium-D
      4gb ram
      NVidia gforce 210
      Intel motherboard
      Seagate 250gb 2.5 SATA
      Seagate 1000gb 3.5 SATA
      quantum Bigfoot 19.5gb 5.25 half height IDE
      Western Digital 80gb 3.5 IDE
      promise ultra66 IDE RAID card
      some no-name wireless card with a ralink chipset
      500 watt PSU, ripple tested
      Follow the white rabbit.
        Alright,I ended up scrapping the Chaintech board.
        Here's specs now:
        Asrock P4i45D+ (don't worry about caps,it uses Rubycon ZL caps)
        384MB RAM (yet I get 3 beeps,I'll replace the sticks though)
        Intel Celeron D 330 2.66GHz (socket 478)
        ATI Radeon 7000 32MB
        TSSTCorp SH-S182D DVD-ROM
        DeluX 400w PSU
        Delux MT375 case
        Seagate ST310211A HDD
        At this moment,because of the RAM I don't have any system installed.I mounted a Xbox to USB adapter in the case by the way,because after I get it running I will play MUGEN.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
          System I - Main System
          Case: Antec P160 Performanace Series/Intel C94227-001 I/O Backplate Panel
          Mainboard: Intel D945GTP/D945PLM Executive Series LGA775
          Processor: Intel Pentium D 930 3.0GHz Dual Core 4M Cache 800MHz FSB SL95X Presler
          Fan/Heatsink: ZeroTherm CF900
          Thermal Paste: Arctic Cooling MX-2
          Memory: Crucial Ballistix 4x1GB DDR2 400MHZ Non-ECC CL4 240-Pin DIMM
          Hard Drive: Seagate Barracuda 7200.12 ST31000528AS 1TB 32MB Cache SATA with Dual Trayless Caddy
          Graphics Card: BFG Nivida GeForce 9800GT
          Power Supply: OCZ Stealth X Stream 500W
          System II - Backup System
          Case: Kingwin ST-424-S/Intel C94227-001 I/O Backplate Panel
          Thermal Paste: Arctic Silver Ceramique 2
          Memory: Kingston KVR667D2N5/1G 4x1GB DDR2 667MHZ Non-ECC CL5 240-Pin DIMM
          Hard Drive: Maxtor DiamondMax 10 300GB 16MB Cache SATA with Dual Trayless Caddy
          Graphics Card: Powercolor ATI Radeon X800 GTO 16
          Power Supply: Corsair Enthusiast Series TX650 650W
            My system:
            Asus P5E X38 motherboard
            Intel Core 2 Quad Q6600 overclocked to 3.42Ghz
            4 Gig Ram Elpida pc2-6400U
            MSI x-fi soundcard
            Sony Optiarc Sata DVD+-RW
            PNY Geforce GTX 650.
            Generic Super Case
            1Tb Western Digital HD
              My current main system:
              Dell Inspiron 600m laptop (I keep going back to this one...)
              Pentium M 2.0GHz
              2.0GB RAM
              60GB Hitachi 7200rpm HDD
              14" matte LCD screen @ 1024x768
              19" IBM Thinkvision L200p @ 1600x1280 (primary monitor)
              Windoze Vista (ugh...)
              Current plans:
              - Get something more substantial
              - Failing that, find a way to adapt a faster desktop HDD to the system (using an external psu... I've a Maxtor DM Plus 9 120GB with awesomely loud seek that would be streets ahead of the drive in this system)
              DOS Box #1:
              Intel Pentium MMX @ 200MHz
              Tyan Trinity Socket 7 motherboard with VIA MVP3 chipset and 2MB L2 cache
              384MB PC133 SDRAM (running at PC66)
              3dfx Banshee 16MB AGP (gotta have that furious 128-bit VGA/VESA core!)
              VIA Tremor PCI sound card (for recording, I needed something with 96kHz record)
              Creative CT2230 Sound Blaster 16 sound card /w CT1747 OPL3
              Windows 98 SE
              10GB Fujitsu HDD
              Intel 100BaseTX PCI NIC
              This one is used for recording OPL3 music. Took me a while to figure out how to get both PCI and ISA sound cards working happily under Win98 but I did it. Looking to get a faster Socket 7 CPU though, since the MMX 200MHz can just barely keep up at 96kHz recording rate. The CT1747 integrated OPL3 chip is beyond compare: it has the fast, sharp envelopes of YMF289 but with a full 49.7kHz output rate, so it is very clean sounding with strong bass.
              Caps used: Rubycon MBZ (yuck, these were from a recap I did a long time ago), Panasonic, Sanyo (IIRC)
              DOS Box #2:
              Intel 486DX/2 50MHz (actually a 66MHz chip, but it's run on a 25MHz bus so...)
              Alaris Cougar motherboard with 512KB L2 cache installed
              16MB RAM
              Diamond Stealth 24 VLB Video (S3 805... anybody remember those?) with 1MB
              Creative CT1770 Sound Blaster 16 SCSI with YMF262 OPL3 and 8x Apple SCSI CD-ROM drive (broken tray cover but the drive still works... who cares, just don't look into it while it is reading)
              Conner CFA-540A 540MB and Western Digital AC2700 680MB IDE Hard Drives (both make a very appealing racket when they are busy)
              Windows 95 Pre-OSR1 (glitchy sure, but lightning FAST)
              Intel Pro 10BaseT ISA NIC
              This is my personal favorite DOS computer. It actually has a very cool IBM 486BL/4 onboard but I discovered that an Intel 486DX/2's FPU was much better at what I was trying to do, so I (with some reluctance) switched over to that. This machine plays the games that run too fast on the 'main' DOS rig, plus it has a very nice SB16 SCSI sound card.
              Caps used: Sanyo OS-CON (original), huge nichicon VX axials and various Panasonic and Chemi-Con KY's on CT1770 sound card (the VXs give it a very deep throat!)
              The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
              I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
                My home rig:
                Intel i3-2100
                Asus P8H67 motherboard
                2x 4GB Corsair Vengeance DDR3
                XFX Radeon 6850
                Corsair Force 3 120GB SSD
                Western Digital 2TB hard drive
                My work rig:
                Intel Core2Duo E7400
                Asus P5KC motherboard
                2x 2GB DDR2
                nVidia GeForce 8500GT
                750GB Samsung hard drive
                soon to be upgraded to:
                Intel i3-3240
                Asus P8H61-I mini-ITX motherboard
                2x 2GB DDR3
                Asus R9 270
                  I have about 20 systems around stored in closets and such but might as well list the most commonly used ones.
                  Main desktop. Only things I bought for it were a Arctic Freezer 7 Pro, memory card reader and the Dell monitor. Only about $30 of stuff into it.
                  2.4 GHz Core 2 Quad Q6600
                  6 GB DDR2 mix-n-match ram
                  500 GB WD Blue hard drive
                  Radeon HD 4850 reference card
                  Asus P5N32E-SLI motherboard
                  20" Acer 1680x1050 dumpster find monitor as primary
                  19" Dell 1440x900 secondary
                  Windows 7 Home Premium.
                  Laptop. Got it for $220 but with 2 gigs of ram instead of 6. Couldn't find anything faster for the price.
                  Thinkpad T410
                  2.4 GHz Core i5 520M
                  6 GB DDR3
                  160 GB hard drive. Planning on replacing it with either a 1 TB drive or a 256 gig SSD in the future. I have about 70 gigs of programs and 30 gigs of pictures, Photoshop, Illustrator and InDesign files for school so not much space left.
                  nVidia Quadro NVS3100M
                  1440x900 display
                  IRC Server. Not very well spec'd but it uses about 30 megs of ram average since it only runs UnrealIRCd.
                  Some Sony VAIO
                  1 GHz AMD Athlon 4 (yes, 4.).
                  128 MB ram
                  10 GB hard drive
                  ATI Rage M1
                  1024x768 display
                  Debian 7.
                    AMD rig:
                    ASUS M2V-TVM-GB (Olidata OEM)
                    1GB DDR2-667 RAM (960MB usable)
                    AMD Sempron 3400+ 1.80GHz (AM2 socket)
                    1TB Samsung HD103SI HDD
                    Windows 7 Ultimate
                    S3G Chrome9 HC IGP,64MB shared video (from the RAM)
                    Intel rig:
                    ASUS P4P800-VM (one sticker reads "P4P800-VM/GB/TSYS/SI",but that's not true at all,as it's a normal P4P800-VM)
                    896MB RAM DDR400 (aiming at getting 1GB RAM on it)
                    2.4GHz Intel Celeron D 320 (Prescott core)
                    10GB HDD
                    Windows 7 Ultimate (trimmed down to fit)
                    ATI Radeon 7000 video card (yet I'll try replacing it with either another ATI card with composite or a nVidia with composite,as the 32MB it has is just not enough for Aero)
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                      Diamond Max 9s seem to last forever! It's only the 8s that suck worse than Windows 8!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                        I built my Gaming PC
                        AMD FX 6200 CPU 6x 3.8ghz O.C. to 4.4ghz
                        Asus Crosshair V formula Z
                        MSI R7870 HAWK Radeon HD 7870 GHz Edition 2GB video
                        CORSAIR Enthusiast Series TX750M 750W PS
                        8gb Gskill Trident X DDR3 2400 (CL10-12-12-31)
                        Seagate Barracuda ST1000DM003 1TB Hybrid drive
                        AZZA Solano 1000R Red Case
                        CORSAIR Hydro Series H80i High Performance Liquid CPU Cooler
                          Good seeing these kinds of builds! PC gaming is pretty much extinct these days, devastated by the consoles.
                          <--- Badcaps.net Founder
                          Badcaps.net Services:
                          Motherboard Repair Services
                          http://folding.stanford.edu/
                          Team : 49813
                          Join in!!
                          Team Stats
                            Not really, I know many who still do (and make fun of my personal workstation builds), thanks to Steam (love them or hate them). They're also morons when it comes to good hardware build quality (the only reason a couple have decent PSU's is that I traded/sold them to them).
                            sigpic
                            (Insert witty quote here)
                              Compared to what it used to be, PC gaming is dead. There was a time when any friday or saturday night in any town, you could find a local LAN or two, or three......public and private. Try that today.
                              Team : 49813
                              Join in!!
                              Team Stats
                                And the Asus ROG motherboards often use FP CAP polymer caps.
                                I expect the new builds to be more consistently reliable than early 2000s motherboards.
                                Arc A770 16 GB
                                  Mine has undergone a few changes, so I'll post it again.
                                  Antec Three Hundred Two Case
                                  Seasonic S12II-Bronze 520W Power Supply
                                  MSI 970A-G46 Motherboard (Socket AM3+)
                                  AMD FX-8350 8-core 4 GHz CPU
                                  Cooler Master Hyper 212 Plus CPU Cooler
                                  12 GB RAM (1x 4GB stick of cheap Kingston RAM, 2x 4GB sticks of cheap Mushkin RAM)
                                  Samsung 840 Series 120GB SSD (OS and programs)
                                  Seagate Barracuda 7200.9 120GB hard drive (backup of /home)
                                  Toshiba MQ01ABD050 500GB hard drive (data that I don't care about too much)
                                  WD WD2500JS-60MHB1 250GB hard drive (nothing, at the moment)
                                  Pioneer BDR-209DBK BD-RE/DVD+-RW/CD-RW drive
                                  ASUS DRW-24B1ST DVD-RAM/+-RW/CD-RW drive
                                  Generic zillion-in-one card reader
                                  Generic PCIe parallel port card
                                  MSI (AMD) Radeon HD 7770 video card
                                  HooToo PCIe USB 3.0 controller (I can't even remember why I put that in...)
                                  3Com 3C905-TX PCI NIC ("Made in USA", it says)
                                  Homemade cardboard air deflectors (to make sure the CPU VRM gets enough cooling)
                                  Delta AFB1212GHE-CF00 case fan (wired to 5 volts)
                                  Outside of the computer...
                                  ASUS VB198T-P 19" 1280x1024 (not widescreen!) LCD monitor (connected with DVI)
                                  Das Keyboard "Professional Model S" (Cherry MX blue switches)
                                  "Genius" PS/2 mouse
                                  Cheap Cyber Acoustics speakers that were on sale at Wal-Mart (they sound okay)
                                  Tripp Lite SMART1500LCDT UPS (runs the computer and the networking equipment for 30-40 minutes)
                                  Tripp Lite ISOBAR4ULTRA surge protector (the UPS is plugged into that)
                                    my systems POST's fine thank you. /joke
                                      Don't need to... due to faster interenet speeds, there isn't as much of a need to horse your rig around for a wired LAN/wifi connection... High speed internet killed the LAN party but not the PC gaming platform (which is far from dead).
                                      sigpic
                                        I have to agree with you here. I build far less of these high end gaming systems now than I did 5 years ago and sell more systems now than I did then. Most of the time the customer says something like "No I don't need a high end gaming PC because I have a Xbox, Playstation or WII I just need something for light gaming and internet / office use."
                                          Some changes on my old Intel rig made me to write it again:
                                          ASUS P4P800-VM w/ Supermicro P4SPA+ BIOS
                                          1GB RAM
                                          80GB SATA WDC Caviar SE
                                          400W DeluX PSU
                                          Intel Celeron D 2.66GHz 330 (socket 478)
                                          no case
                                          Windows 7 x86
                                          Another upgrade I might do to it is change Windows 7 to either a older version of Windows 8,before they removed the Start Menu,or either Windows Server 2008.(the Vista based version,R2 is based on Windows 7 x64)
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          16GB DDR3-1600
                                          Delux MG760 case
