Software Fakeout!
  • Neo2_000
    • Apr 2005
    • 180
    Software Fakeout!
    Just recapped a 601bs4 socket 370 Azza last night.
    Hooked up the original Hard Drive (XP) and all was cooel!
    But when I shut down, it would go through all the motions but then restart - Doh! What had i done wrong?
    I rang the owner and explained the outcome only to be told, "Oh Yeah, it has always done that"!
    Well! Thanks for letting me know.
    I then substituted a hardware agnostic Windows 98 hard drive and booted in safe mode to avoid new hardware detection. Shutdown worked fine.
    A quick searchon the net revaled the culprit .... Roxio Software!
    There was an update patch on there site which specifically resolves this very issue!
  • Rainbow
    • Aug 2005
    • 1371
    Re: Software Fakeout!
    That's why I always use my hard drive for testing.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      reminds me when i recapped a guys computer and then started it to be greeted with a "this program needs to be shut down". Yeah "it always does that" he said. Whew!
      but yes i am getting more annoyed with misbehaving software. recently we had the apc powerchute 6 problem (yes i should have known) where it made the mailserver look like it had serious virus infection but there was no virus to be found. turned out to be a certificate for the java part of the software expiring. powerchute was also a goddam problem to install on linux. in the end installed apcupsd which installed without issue once i had found an older version which was noted to work on rhel4
      need a new antivirus for corporate and work laptop use. i am done with symantec and mcafee. any recommendations?
      • Fatal0E
        • Jan 2004
        • 252
        seen several times on windows xp when you go to shut down it just reboots
        it reboots because its set to automatically reboot on a crash, if you turn off the setting you get a blue screen, was caused by old logitech software being installed. remove the software and it solved the problem.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          seen in acrobat 7.0.0 the microsoft explorer 4.0 scroll mouse when it scrolls to the top of the document generates continuous system beeps. requires 3 adobe updates to be applied and all is well.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            for a real test i use knoppix.it is a live distro(boots and runs entirely from a cd)
            dont need a hd.
            http://www.linuxiso.org/distro.php?distro=44
            • Rainbow
              • Aug 2005
              • 1371
              I use HDD with Windows 98SE - it does not need to be reinstalled for each board (unlike XP...). First I boot DOS mode and use GoldMemory to test memory, then run Duke Nukem 3D and leave the demo running for a while (it easily crashes after a while if something is bad ). Then I run Windows, let it install all the hardware and run Prime95 for a while. Next I boot from Slax live CD - it oopses or segfaults during boot if something bad (found bad CPU this way last time - Pentium 100 - crashes at 100MHz but runs fine at 90MHz).
              • Fatal0E
                • Jan 2004
                • 252
                www.ultimatebootcd.com
                • axlmastr
                  • Aug 2005
                  • 158
                  @willawake
                  I know what you mean! I went with Grisoft AVG Network Ed. on my corporate and personal LANs. The licenses are cheaper and the software works great on any OS. Less resource hogging and no lock-ups, BSoD etc... I've always stayed away from McAfee, but gave up Symantec after 2003 Edition. Too many problems if you weren't at least using XP. I'm not a believer in the "latest is the greatest". Look at what we see in these mobos and their components. Same goes for programming code. I've tried Panda & TrendMicro too and they work better than the mainstream crap! I've used the free edition of AVG on numerous machines for over a year now and have not had one incident. Give the free edition a try it sold me! Techsupport was great too, by the way, when I needed help on the remote admin from the server to the clients package setup.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    thanks axlmastr, i will check it out. what are you using for firewalls?
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      it is so common to find corrupted os on a badcaps victim i dont ever trust a load that was in use on the bad caps.too many glitches caused by file corruption.
                      • Moogol
                        • Nov 2005
                        If you're sick of McAfee and Symantec I'd suggest you try Kaspersky; someone did a test of virus scanners at Overclockers.com and this one came out on top as far as finding and eliminating threats.
                        Dunno about resource hogging, etc., but at least for detection and removal it exceeds the competition.
                        • arneson
                          • Sep 2005
                          • 1267
                          Grisoft's AVG has always been my choice.
                          Steven Gibs impressed me many years ago with his security concerns.
                          Jim
                          • ash91
                            Hp pavilion 15 not detect hard drive
                            by ash91
                            Hello gentelmen .... this is my first post and sorry for my bad english,
                            so my proplem is my laptop keep losing hard drive even if i but the
                            hard disk in the cady (the box that can replace the dvd rom with hard disk)
                            when i turn the laptop on the massage that said no boot media found pop on
                            the hard disk is fine and to be sure i try another hard
                            i also update my bios to the last update
                            the 5 volt is present on the hard connector on the motherboard
                            the dvd rom work fine when i but a windows dvd in it
                            also when i boot from flash...
                            06-07-2023, 01:45 PM
                          • NeedsPractice
                            Best Overall Amazing Back Up Setup? 1K-4K Budget! Software + Hardware? Help!
                            by NeedsPractice
                            I remember a lot of people before when my hard drive failed told me that I could do a couple of amazing things with backing up data. What stuck out is two things...
                            1. Software that will backup your data live via a cloud solution or over the internet without having a corporate cloud product.
                            2. Get a storage tower with hard drives and load them up.
                            What I mean is there software out there that you can install on your computer. You tell it which data you want backed up. Lets say your main PC with (2) hard drives and (8) hard drives connected to it via a tower....
                            06-23-2023, 05:26 PM
                            Hard Drive DOS testing software for different brands is there any good out there
                            I use to have a way to test hard drives on old computer system but with the newer computer system this is all most impossible to do anymore
                            What do you use any more
                            Because most of them any more want to used while you are boot up to windows operating system this not what I am looking for I am looking for is a complete running on DOS environment I have found this type of software for me works the best ( I could be wrong with this idea and if I am please correct my way of thinking please post website links for better testing software that is FREE )
                            Because...
                            03-15-2020, 06:59 AM
                          • odie34
                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                            by odie34
                            I am a hobbyist (not a professional) so please be gentle...
                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                            02-18-2024, 09:11 AM
                          • BMCappelletti
                            iMac fan ramps up after shutting down. Software? SMC? FET?
                            by BMCappelletti
                            Hi everyone.
                            There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
                            In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
                            It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
                            At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC...
                            01-17-2025, 08:11 AM
