iMac fan ramps up after shutting down. Software? SMC? FET?
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    Hi everyone.
    There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
    In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
    It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
    At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC or mosfet issue, and testing the fans with a control software would confirm that. If the fan speed is able to be controlled using software, it's a SMC issue. If it does not, it's a mosfet issue. In my case I see no difference when setting the fan speed to min or max, so I believe it would be a mosfet issue. Or driver issue?
    Is anyone here 100% sure on what's the issue on these cases and can confirm the mosfet is the one in my case? If so, what's the correct component to replace on a 820-3302-A board?
    Thank you.
  • Stephen
    iMac 27” 2020 Boot issue
    by Stephen
    Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
    08-16-2024, 09:32 AM
  • Cuboy
    HP probook 4510s mosfet issue
    by Cuboy
    I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
    I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
    I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
    03-16-2024, 10:29 AM
  • Stephen
    iMac M1 DFU restore issue
    by Stephen
    iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
    this is the message it gives me with the error
    Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
    Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
    03-07-2025, 12:19 PM
  • ebyte64
    Lenovo IdeaPad 330 laptop mosfet issue
    by ebyte64
    Good day everyone.
    I have been scratching my head with a Lenovo laptop I got in today.
    The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
    Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
    Would anyone...
    06-27-2023, 10:19 AM
  • mat2k
    iMac 2017 PSU - shorted PFC mosfet
    by mat2k
    I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
    There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
    03-13-2025, 11:31 AM
