Hard Drive DOS testing software for different brands is there any good out there
    • Jul 2011
    • 6070
    I use to have a way to test hard drives on old computer system but with the newer computer system this is all most impossible to do anymore
    What do you use any more
    Because most of them any more want to used while you are boot up to windows operating system this not what I am looking for I am looking for is a complete running on DOS environment I have found this type of software for me works the best ( I could be wrong with this idea and if I am please correct my way of thinking please post website links for better testing software that is FREE )
    Because I not only want to test hard drives I want to wipe them clean with zero and one
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Hard Drive DOS testing software for different brands is there any good out there
    Linux with `smartctl` to check SMART status and `badblocks` in read/write mode to stress it and make sure there are no additional damaged sectors that the drive hasn't found yet.
    To see drive performance HDTune on Windows still seems like the most expressive solution.
      • Jul 2011
      • 6070
      How easy is it to setup a computer that run with Linux operating system with `smartctl` On it
      I do not have any experience with this operating system
      I know about it and have read a lot about it
      What I do not know is how to setup
      Where to go to get the software
      How do to make the installation disk
      How to do the installation setup
      I have I forgot anything else
        • 31291
        it's easier than windows,
        but smartctl may be on livedisks that boot from a usb-stick
        i'll check later.
        • diif
          • Feb 2014
          • 6978
          • England
          I use a Hiren USB or CD with all the hard drive tools on it.
          I also have HD Sentinel installed on my Windows PC I do recovery with. I use a Magic Bridge 2 for connecting drives.
          • R_J
            • Jun 2012
            • 9624
            I also use Hirens boot cd or Hirens boot dvd, Also Seatools for dos (seagate utility) checks most mfg. hard drives. There are lots of other usefull utilities on the cd's
            • noppa
              • 41
              With MHDD you can check any disk in seconds, look at SMART data, and
              then decide to go further and scan it to see if its surface is ok.
              You need a true IDE interface (modify BIOS from RAID/AHCI) to work correctly.
              https://hddguru.com/software/2005.10.02-MHDD/
              There's a boot image on hddguru but you can find in hiren's CD/DVD as well,
              it's not updated from years but it's still awesome.
              A more modern DOS software is HDAT2, that supports IDE/RAID/AHCI
              https://www.hdat2.com/
              Usually it's on hiren's CD/DVD too, but not updated.
              For data recovery there's DMDE
              https://dmde.com/download.html
              There's a console version for DOS that works fine and can actually
              see NTFS filesystem (and others too).
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3266
                • Singapore
                i tried minixp on hiren's boot cd for testing hard drives using victoria hd tester but the problem is that the os, minixp doesnt support hard drives bigger than 2tb.
                does mhdd and hdat2 work properly with 3tb hard drives or larger? note: if it detects a 3tb hard drive as 750gb thats a dead giveaway it doesnt work.
                  • 31291
                  you will need a Linux based setup if your using sata or 4k cluster drives i suspect.
                  • noppa
                    • 41
                    latest HDAT2 version is few months old so should not
                    have any problem with newer drives, and with sata/pata/raid/ahci/4k stuff.
                    Take a look a the last drive of the list in this picture :
                    https://www.hdat2.com/preview/picture01.jpg
                    I can't test MHDD at the moment with HD larger that 2TB since I don't have
                    any at the moment and I can't move.
                    You can make a test with MHDD by disabling the HD in BIOS, MHDD should
                    detect it anyway bypassing BIOS.
                    Did you use the latest version of VICTORIA for windows?
                    the version you find in hiren's CD is quite old.
                    Newer version can be found here
                    https://files.hddguru.com/download/S...For%20Windows/
                    and they work fine with recent hard drive and SSD
                    • cook
                      Good brands of run capacitor for house heat hump
                      by cook
                      Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                      Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                      09-13-2024, 12:53 PM
                    • federalhouse
                      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                      by federalhouse
                      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                      **Background:**
                      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                      **What I've Tried So Far:**
                      1. I accessed
                      08-01-2024, 07:03 PM
                    • CDNBrewer
                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                      by CDNBrewer
                      Hello Everyone,
                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                      Symptoms:
                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                      • I swapped the Left and Right surround
                      08-05-2025, 09:29 PM
                    • ash91
                      Hp pavilion 15 not detect hard drive
                      by ash91
                      Hello gentelmen .... this is my first post and sorry for my bad english,
                      so my proplem is my laptop keep losing hard drive even if i but the
                      hard disk in the cady (the box that can replace the dvd rom with hard disk)
                      when i turn the laptop on the massage that said no boot media found pop on
                      the hard disk is fine and to be sure i try another hard
                      i also update my bios to the last update
                      the 5 volt is present on the hard connector on the motherboard
                      the dvd rom work fine when i but a windows dvd in it
                      also when i boot from flash...
                      06-07-2023, 01:45 PM
                      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                      by momaka
                      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                      Macron Power Technology Co. LTD.
                      Let’s look at the PSU itself.
                      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                      06-02-2021, 10:05 PM
