Caching HDD with SSD
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Well for those people who don't have 4TB SSDs, wonder if anyone has gone the cache route?
    Well, what I'd like to do - I have a 4TB disk array (RAID5) and would like to add an SSD cache to speed up operations.
    Don't worry about the implementation - though I am using Linux LVM and planning on using LVM's built-in disk cache functionality, but again don't worry about it. Assume that I can suddenly add an SSD cache.
    What I wonder is how much of an improvement I'll see in multiple I/O consumers. The disk array is currently being accessed by multiple IO streams and is getting killed by this fact, as expected. I wonder how much of a SSD would cause an improvement in interactive performance or will it be mandatory that I have an SSD of the same size of my array to get any benefit? I'm worried about write performance as well, unfortunately this will be bottlenecked by the underlying HDD, perhaps I am forced to use writeback caching to improve performance?
    I'm hoping I can get away with a much smaller SSD than the 4T on the array. Also wonder how badly will the SSD get trashed in terms of write cycles/lifetime?
    Anyone using such a setup?
    • 31291
    Re: Caching HDD with SSD
    the ssd will probably die.
    the profesional method - that is now cheap on ebay,
    is to use a buffered raid card.
    these cards have a big ram/sim/dim on them backed by lithium batteries. (incase of a crash/power loss)
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      I'd imagine the SSD would last as long as an SSD in the same situation, depends on how much you write to it, though RAID may amplify writes a bit. However a 64G SSD is cheaper than 64GB DDR4 on a RAID card... not as fast but still much faster than mechanical HDDs...
        • 31291
        you dont need 64gig ram on the raid card, 4-16 is more than enough.
        the card only uses it as a buffer between the system and the spinning harddrives.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          I haven't been able to find any cheap ones that have more than 512MB RAM, and based on my datasets I think I do need at least about 4GB or so as that's the most commonly used datasets that should be cached... seen any? 16GB would be nice, and then 64GB SSDs are cheap now?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Well I implemented it when I did a server cleanup. Used a 180G SSD, there's quite a bit of stuff that sped up...
            ... and then everything went down hill. Yow.
            Turns out, after cleaning out a bad fan that was seized, the fan now vibrates horribly and causes one of the hard drives to error out making the cache system useless.
            %$#*(%Ing 40mm fans. I stuck a wire into it to shut up the stupid fan and disk speeds went back up to normal.
              • 31291
              what uses a 40mm fan? i'v not seen one in years.
              i used to replace them with 50mm - the smallest fan that actually moves more air than it heats!!
              • diif
                • Feb 2014
                • 6978
                • England
                Anything 1U, network switches mostly.
                • brethin
                  • Dec 2008
                  • 1907
                  Ssd makes a bad cache device, use a ram card.
                    • 31291
                    you could use a 50mm on a slanted plate to lower it's height.
                    or just use a centrifugal type like on laptops
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      No need, I have lifetime supply of Sunon Maglev 40mm fans.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8711
                        Cache system actually works fairly well now, when the underlying HDD is actually working properly. Cold misses suck as usual but once it warms up, ahh...
                        Granted that the cache:size ratio is fairly large since I targeted only the hot spots, better than 1:8 ratio for them. As long as I don't (frequently) touch the uncached portions...
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5045
                          • US
                          At one time they made hard drives with a SSD cache. They were called SSHD. They were total shit
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8711
                            Buy underspecced, expect a miracle, be disappointed...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8711
                              I have to say, the cache system is working very well. I allocated about 128GB to cache 800GB right now (rest of the 4T I don't cache), very nice, it covers up a lot if not almost all of the disk slowness, even during RAID scrub night. My disk array is horridly slow during biweekly maintenance night, it's still slow but the cache hides the latency -- I can actually do something with the computer during scrubbing now!
                              ...Which is kind of moot anyway, I explicitly set scrub night to be when I'm most likely not using the computer so the slowness is hidden away already...
                              • welp
                                PS5 Disk Tray issues.
                                by welp
                                I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                                Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                                Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                                So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                                With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                                12-19-2024, 02:04 PM
                              • DynaxSC
                                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                by DynaxSC
                                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                The behaviour is also really very strange, i.e.:
                                • The disk shows always up in BIOS - so it is recognized, so far so good
                                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                02-23-2025, 01:33 PM
                              • Stanley1843
                                Windows 11 disk no boot
                                by Stanley1843
                                I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                                I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                                DISM /Online /Cleanup-image /Restorehealth
                                The DISM.... command shows me the error 87.
                                sfc /scannow
                                chkdsk
                                bootrec /FixBoot
                                bootrec /ScanOs
                                bootrec /RebuildBcd
                                For some reason it writes(Total identified installations 0) like there no...
                                10-18-2025, 04:41 AM
                              • chth96
                                LG GCC-4521B cannot read any disk
                                by chth96
                                I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                                But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                                And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                                But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                                02-13-2024, 07:31 AM
                              • madura2010
                                DAY11AM6E0 hard disk drive and optical disk drive not detected
                                by madura2010
                                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                i checked the connectivity of ribbon=good communication with hard and motherboard
                                changed hard disk and checked=3f0 error persist
                                sata power=+5v available
                                Then checked data capacitors=all good
                                Then checked data lines path connectivity to pch=all good
                                reflashed...
                                03-12-2023, 09:09 AM
