went to purdue surplus, found out they have boatloads of gx240 units being scrapped... guess why:
BAD CAPS! they goit at leasty 500 of them, they sold me this for 10 bux:
dell optiplex gx240
proprietary mobo- has extra 2 pci extender
bad caps
socket 478 p4 williamette
case built well- handy clamshell design- if you have seen one they you know how cool it can be- mac like almost
no ram- 2 pc133 slots (1gb max i think- i have the ram)
no hd- missing a set of hd rails but next time im there ill snatch an extra set of another one
dvd rom/ cdrw drive
floppy drive
decent ventalation around hard drives- has a second dell-style fan header up front
more on the mobo: 4 usb 2.0 (2front, 2rear), 3com integrated lan, 1 agp 8x slot, 4 pci slots (1 has an extension, but not pci-x, 2 slots on expansion add-on), intgrated sound, good chipset heatsink
hipro 250w psu- atx, beefy SOB- extremely over-built, might do more than 250?
i have already removed the stock cpu heatsink mounts (broken), in the process i accidentally knocked off an oscon
grr... added to recap list
i have a suspected s478 prescott 2.8 ghz unit- ht? has 1mb L2. it came out of a beat up dimension 3000, i have a copper cooler from it that matches the duct on the cpu fan.
i asked for a quote from tc for caps. i also asked if he has s478 bracket hardware as my retainer form the 3000 bolted through the board onto the case, but this gx240 used disposable plastic clips. standard hardware will clar that up
also, i will give it a dell-edition (dell sound header present) sound blaster LIVE! card as an audio upgrade- pulled from another dell i had. i also have a modded asus radeon 9550 agp card w/ soldered in fan attached to heatsink.
i am considering adding my spare usb 2.0 card w/ 5-pin usb header and adding to that an internal card reader. it worked great on my presario 7000... might be good for this.
good deal?
dell optiplex gx240
bad caps
dvd rom/ cdrw drive
floppy drive
grr... added to recap listi have a suspected s478 prescott 2.8 ghz unit- ht? has 1mb L2. it came out of a beat up dimension 3000, i have a copper cooler from it that matches the duct on the cpu fan.
good deal?
