a new dell to play with
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: a new dell to play with
    im out of town right now so when i get back on sat. ill check.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      they all are 02 datecodes
      time to recap (if mom lets me that is)
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        still running fine.
        i decided to to dual boot it. ubuntu/xp. using the xp half right now, dual boot rules!
        cpu-z:
        http://valid.canardpc.com/show_oc.php?id=852105
        sigpic
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Morning RD! Using a Microsoft Product are we!...LOL Only kidding with you Mate. My Lappy is dual boot Linux mint/Xp Home. I love it too. I don't have Mint on my desktop as of yet because I'm working on a package of new add-on software to run under windows Xp. The stuff that I have been using is just to dang old. Now don't get pissed with me but I am going to offer you some good advice here, "If your Xp is legal that is." Do the upgrades to Sp2 and Sp3. Next do all the rest of the updates too. Its free so take all you can get and then some. After these updates Xp becomes Ok. You will still need to run and Antivirus, and a spyware blocker/scanner. If you go to the IT side of the update pages you can find ISO disk images of Sp2, and Sp3 for download. Do this and burn your disks. Unplug whatever it is that you use to get on the net, and install same. Next turn off automatic updates and change the way automatic updates reports to you to kill the nag screen about having the updates turned off. What ever you do, stay away from the software validation tools if you are not legal. Maybe you should look for these ISO files using ubuntu. I don't know if you can do it this way but its worth a try. The best way would be to use a PC for the SP downloads that is known to be all windows legal.
          Mark Twain
          John Paul Jones
          Rod Serling
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            #45
            i will warn you now that just because those hn/hm are not bulging you are not safe.
            i just recapped 3 260's that were very unstable.datecode iirc was h0428.
            they looked fine but were high esr.several were 5 ohms on the dick smith.
            whats really funny is they had me recap all the 260's in the plant but were going to toss 4 280's because they did not have spare ram on hand to upgrade them.
            they already had 1gb each.needless to say i picked them up for proper "disposal".
            even funnier is when i opened them up to inspect all 4 had my mark on the board and polys.i even told them it was sily to dump em over cheap ddr2 since they were already rebuilt.the higher ups wanted the machines standardised.i wont complain.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              hmm, thats EXACTLY what i did. has key on case. found the dell version of xp pro w/ sp3 slipstreamed on piratebay (has restore option but also can act like normal xp install without entering the key since it knows that you are installing on a dell), done, installed xp, installed drivers, installed apps:
              comodo av/free firewall
              openoffice
              google chrome
              mp11
              .net 3.5 (for ati catalyst)
              infra-recorder
              7-zip
              asus smart doctor (lets me oc the graphics, thank god i soldered in a fan for it)
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                ok, some questions for the poly-mod experts:
                since it is the mini-tower:
                idk if a poly mod is worthwhile; it only gets a little warm...
                nichicons:
                13x 6.3v 1500uf 8mm
                3x 16v 1800uf 10mm
                3x 6.3v 1800uf 8mm
                1x 10v 680uf 8mm
                the rest either have no vents or are rubycon mbz or sanyo wg/cg. i assume the nicicons w/ vents (hm) are the only ones that need to go.
                also, if i should poly mod it, what values should i use; i have never done a poly-mod.
                iirc poly= 1/2 uf of a lytic.
                sigpic
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Poly is optional.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    ok ill order caps then.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      oh dear... it has began to show bad caps symptoms. it once in a while locks up in bios, but a hard reboot cures it, only for it to happen once again at a random re-boot.
                      iirc, that is a definite bad caps symptom. better be ordering caps...
                      sigpic
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        My Dell is hanging from time to time too. I don't even want to look at the caps since I have a screwed up dual core Hp Compaq as soon as I can go pick it up. Would rather work on that one. Its programing/virus/ adware issues with the hp compaq. My brother say that with the Hp compaq I can run a system restore from the boot and restore the PC to like the day it was made from a backup partition on the HD. If that fails, my brother also has the Xp for it that he bought from Hp compaq for a PC that he sent back to them because it had issues. He then bought another Dell with windows vista. It had issues too until he switched out to Windows 7.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          you might have bad caps. i will see if a recap changes the issue.
                          sigpic
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            Well RatDude I took it apart for a good cleaning and its working better now. I just don't think a little dust was the issue with it. The unit wasn't perfectly clean but it wasn't anywhere near Ghetto Zone dirty. The caps all looked great too.
                            My wifes Dell was in the Ghetto Zone for sure. Its on the floor with the dogs and cats and has many fans to suck in all hair...ect. Yesterday I also went on a dig in my junk box and found it a brand new never used 80 pin IDE/PATA ribbon wire. The Optical drive errors on the read are all fixed now.
                            I have to go get that sick Hp Compaq soon. Its a 270 mile round trip to where its at in Del-Mar but its worth it. Its a dual core intel so it sould be faster than my old junkers are.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Del-Mar
                              Don't happen to know a 18ish year old kid there named Casey do ya?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Jones?
                                toot toot
                                - Dr Seuss
                                • Junk Parts
                                  Court Jester
                                  • Jun 2006
                                  • 8953
                                  The only people I know in Del-Mar is my cousin Polly and her husband Bobby. Sorry.
                                  Mark Twain
                                  John Paul Jones
                                  Rod Serling
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Originally posted by PCBONEZ
                                    Jones?
                                    toot toot
                                    Toot toot as in toy steam engines? We might be talking about the same guy here.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Wow never mind that
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Casey Jones is an old old song about a Train Engineer.
                                        Grateful Dead did a different one using the same name about a stoned guy driving a train.
                                        -part-
                                        Driving that train, high on cocaine,
                                        Casey Jones YOU BETTER, watch your speed.
                                        Trouble ahead, trouble behind,
                                        And you know that notion just crossed my mind.
                                        - Dr Seuss
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          kc, how do you desolder the vrm caps? the hs plate is in the way and idk how to SAFELY remove the playe
                                          i guess i could remove the cap if i angle the iron right... and desolder from the other side... since you recap them i'd assume you would have a secret to tell.
                                          sigpic
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
