CPU load-line calibration can improve stability
  • japlytic
    • Oct 2005
    • 2086
    On a system with a 2.13GHz Core 2 E6400 overclocked to 3.2GHz (800MHz FSB) on a Gigabyte GA-EP45-UD3R motherboard, it gave BSODs when playing the Sims 2 (intensive application), despite a large Zalman heatsink.
    Since I enabled "Load-Line Calibration", I have yet to see another BSOD.
    If you're overclocking, try enabling this option if you are having problems, even if you have a decent heatsink.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: CPU load-line calibration can improve stability
    Not recommended, can cause overshoot of VID and makes the VRM work much harder
    Better to just increase vcore untill it becomes stable, or simply step back on the OC
    http://www.anandtech.com/cpuchipsets...spx?i=3184&p=6
    • Colt45ws
      • Jan 2009
      • 174
      Yeah, I had that enabled on my GA-EX58-UD5 until I found that article. I read that and I went *lightbulb*; no wonder I can run Prime95 for days, but give it a varying load and expect a random hard lock. I had to bump the vcore setting up a bunch, but true loaded voltage is the same.
      I also discovered later how much heat affects voltage requirements on accident. It was running stable for days then it got up to about 30C in my room. Internal case temps hit 45C and it hard locked. Pulled vcore, instant crash booting. Bumped it two notches. So now my standard is at least one notch above stable to provide for temperature increases.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Even better than that for stability is to remove your spam garbage from your sig!! Now that I've removed it, the forum runs with more stability!!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • harp
          Metod for removing glued heatsink from fragile component
          by harp
          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
          06-23-2025, 02:01 PM
        • Ven
          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
          by Ven
          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
          07-08-2024, 09:32 AM
        • harp
          can fanless heatsink replace poor original on RX26PG2
          by harp
          I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
          06-25-2025, 10:56 AM
        • jaco2d
          Hisense calibration
          by jaco2d
          Hi i recently purchased a Hisense u7hqtuk TV, there is 2 different version of this set, the UK, Europe one and the America one, i have the UK and Europe version.
          I have searched for calibration for the TV but i can only find it for the America one which has 1000 nits, the version i have has got 600 nits so the calibration settings will not work.
          Has anyone got this TV and managed to get good picture setting for it or can anyone find a link to the calibration settings?
          The picture is good enough but if possible i would like to get the best possible picture settings for the...
          09-20-2023, 12:20 PM
        • draag de wereld
          ATTEN ST 8800 D calibration ?
          by draag de wereld
          I have an ATTEN ST 8800 D. I tried it out and I have a problem with this machine. When I get the machine at 500°C at 50% airspeed. My motherboards (I tried on several) barely heat up to 180°C. I know how to calibrate the machine, but it can't be a calibration of 300°. Anyone has the same problem with this machine. I know buying cheap is buying expensive but a 300° difference is a rip off.
          02-28-2025, 05:17 AM
