best cheap/free scores 1.1
This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #141
    Re: best cheap/free scores 1.1
    toshiba satellite a105.
    free with busted screen.pulled screen from a spill damaged compaq and transplanted it.
    iirc this can take a mobile dualcore.
    i have a few so upgrade time.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #142
      I got two IBM ThinkPad T40's, I was asked to fix them but when I told owner what was bad he told me to just scrap them...
      They are Pentium-M 1.5Ghz with 256MB DDR RAM, system supports max 2GB according to Google
      On both of them the 40GB IDE harddrive has bit the dust
      One of them has a busted keyboard, I spoke with the owner and he said it worked fine when he used it last, so thought it was strange
      The keys that are broken form a pattern on the keyboard, anyone get an idea? (already reseated connector on mobo)
      Code:
      67
       YU
       HJ
        NM
      I'm really happy for this, I've always wanted a laptop but never wanted to buy one, and I especially wanted a nice one like these, and not a crappy flimsy Acer plastic toy...
      • Wizard
        • Mar 2008
        • 2296
        #143
        Corroded thru or broken trace in the keyboard circuit (flex circuit). Replace keyboard.
        Note this is set up as grid with contacts at the crossing points.
        Cheers, Wizard
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          #144
          ifr 1200s service monitor.$50 at the hamfest last weekend.label said"some sort of funny scope"
          works fine and dead on calibration too.
          bunch of mullard 6ca7/el34 tubes.free from the trash barrel.all good.
          several 2m mobile rigs with simple problems.$5-10 ea.a friend who came along got a ft-5100 for $15.needs the crack in the 2m pa fixed(sav17).
          gateway 610xl "10 gallons of shit in 5 gallon bucket"all in one pc.$15
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Got a wireless Microsoft keyboard. Hooked it up and found a bunch of dead keys as well as other keys that typed three or four different letters in a row when pushed. I figured it had suffered a spill so I took it apart to clean the membrane thinking this would fix it. It was soda or coffee that was spilled in it and some of the traces are burnt black. I cleaned it anyway and tried it again. Only one key that was dead on the first test came back to life after the clean up. Time to put this thing back in the trash can... The USB wireless radio part seems to be good so it goes in my junk box.
            "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
            Mark Twain
            "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
            John Paul Jones
            There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
            Rod Serling
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i got a panasonic lumix lc-33 at goodwill for 35. it runs great, 3.2 mp, 3x optical zoom, movie mode with microphone. i love it...
              for free i got a new usb hub from fry's. free after rebate... my mom said she couldnt find the form at the provided likn so she ha them mail her a form... but free is free...
              also, i found a usb to parallel adapter cable for 99 cents last week at goodwill. the apc $30 one. i also found a silver/black one at a trinity mission outlet for 3.99 new in box a while back. good for using my canon bjc-70 laptop printer (i found that at goodwill for 8 bux last year) on my eee pc.
              i also found a boombox for 2.5bux ((yesterday was a goodwill half-off everything day). phillips unit, bass boost, cd player, tape deck, and needle-type radio. antenna screw loose (easy fix) and needs cleaned (was in a garage based on level of dirt). ill clean and fix it and give it to my world history teacher who killed his crappy durabrand one when he "touched the antenna and felt static, now the radio doesnt work". right now he is using an armband radio for joggers hooked up to a set of crappy computer speakers.
              keep the score reports coming!
              sigpic
              (Insert witty quote here)
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                ignore this... what was here was supposed to go on the eeeuser forum.
                sigpic
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  yay! i found more cheap scores!
                  heading to purdue surplus, i found hidden in a corner an asante fs5008c 10/100 8 port LAN hub. it has a clear blue plastic top and solid sheet meta l bottom... thick sheet metal to be exact. looking inside thogh the clear cover, i see no bad caps and 2 realtek control chips. right now im load testing it... it seems to be working well.
                  i already had a 16 port hub but i have no 5v 5 amp cord for it right now... the 2 amp one i had wasnt enough to keep it from constantly re-setting... under only 3 active inputs... this one had the wart with it so im covered.
                  also, i found a set of phillips aluminum earbuds for 99 cents. they sound rockin! and the body of the buds is solid aluminum, not plastic. looks good with the ipod i bought there a few months back.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    ok, so i didnt get as good of a deal on the hub. see this... but hey, an 8 port for 5 bux aint bad.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      another good deal 4 me:
                      at goodwill, i found an HP laserjet 1012 for 9.99. normally i wold pass due to toner costs because most are empty, but this one was labled by the original owner "not vista compatible". so was an hp inkjet sitting next to it. the cords had been laved with a dynamo labeler. i figured some office upgraded to vista and had to dump these because of compatibility.
                      i plugged it in, no errors. i bought it, took it home, hooked it up (and installed hplip toolbox).
                      i did a test print and it came out nice. hplip says it has 4 out of 4 bars of toner. nice.
                      good or bad deal?
                      sigpic
                      • washu
                        • Jul 2009
                        • 310
                        #151
                        The HP 1012 is Vista compatible, even 64 bit. I know because I own one. Someone was just too lazy and/or incompetent to check HP's website. Nice that you got a good deal out of it.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          yeah... im lovin it. 15ppm aint too bad i guess. since toner is 70 a shot (it had name-brand in it) and itwas mostly full, 'bout hom much would it have sold elsewhere (ebay,etc)?
                          also, i read that remanufactured toner is good but refilled is not. they say refilled has worn rollers. re-manufactured has all that fixed. they are incredibly cheap so i wonder if you save anything. true?
                          now 4 pics:
                          the price:
                          the test page:
                          not too shabby?
                          sigpic
                          • KeriJane
                            Mac Enthusiast
                            • Sep 2008
                            • 681
                            Hi Ratdude
                            Not Shabby at all.
                            Having a Laser Printer around is a great idea. You can cut way back on your inkjet refills that way.
                            One little issue: Power consumption. Most go to sleep pretty quickly nowdays but they can dim the lights when they start up.
                            HP makes some really great Laser printers. I don't know if yours is one of their finest but it's probably OK if it works at all.
                            I used to know someone that used HP color LaserJets for in-house printing. They had big Gallon jugs of Toner and did it themselves. Presumably the cartridges / rollers / drums and magic Laser Printer smoke help up for awhile.
                            Have Fun,
                            Keri
                            The More You Learn The Less You Know!
                            • washu
                              • Jul 2009
                              • 310
                              #154
                              Both my 1012 and 1018 use only 4 watts when idling so power usage isn't bad. That was measured with an inline power meter. The 1012 is usually hard off so it's only the 1018 idling. They do go over 400 when heating up, but that's not for long unless you are printing a lot.
                              I guess I don't print much as both are on their original toners. The standard ones are rated for 2k pages.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                i got 2 nvidia 5\geforce fx 5500 128mb pci vid cards. they had 4 avaiable. 2 had for caps:
                                1 poly
                                1 16v 1000uf panny
                                3 sam young 10v 1000uf
                                the oyher 2
                                1 poly
                                2 sacon fz 1000uf 16v (one spot had holes for 2 cap sizes)
                                2sacon fz 1000uf 6.3v
                                i took one of each since one of the sam youngs had a fan that was all slow and stuck. they have a dvi (ang/dig) and s-video out.
                                i paid 5 bucks for both cards. they also had 5 zillion pci express cards, but i needed none.
                                You need to make the Sacon FZ -> GO AWAY.
                                Just search them. You'll see.
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  good or bad deal?
                                  No.
                                  Not good or bad, -> EXCELLENT!
                                  - Dr Seuss
                                  • NxB
                                    • Feb 2009
                                    • 1595
                                    #157
                                    I don't like inkjet printers. I've used my laserjet 4050 N for a while. Before that I had a laserjet 4. I'm still on my original toner on the 4050 and toners are cheap anyway.
                                    I don't think I've ever actually bought a printer, all free.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      dont worry,that card aint in use no more... the sam young one i still use in my dell l933r but the other had a dead fan. i know sacon fz's are explosives. i was going to swipe both of the sam young ones but one had an obviously dead fan. the sacon one did too, but i did not know at the time.
                                      and the original x800xl card to start the thread has yet to be used... oddly, i found out it has a agp to pci-e chip in it. i wish i had a mobo and psu (need to order the hypermicro special...) that liked it. my socket a board hated it... i might be getting another one soon... maybe some luck there.
                                      its so stupid that the printer was labeled "not vista compatible". too bad i removed the masking tape label before i took pics... what a dumbass.
                                      sigpic
                                      • Player2
                                        • Aug 2009
                                        • 98
                                        I snagged a Sony 24" CRT (2006) from the curb on trash day a couple days ago. Just needs a new flyback and a little bit of Magic Eraser to clean it up.
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          went to goodwill, found stuff
                                          hit 3 stores
                                          first one, i found for 5 dollars a swiss gear dvd player bag. it was a perfect fit for my eee pc. it was in good shape and was studier and roomier than my old one. no damages to it.
                                          second store had a surprise: another ti 83 plus. it was 5 dollars, needed the battery connectors cleaned. popped in batteries, and it stated right up like a new one would. a bit beat up but easily passable. 10 for the broken one was a ripoff!
                                          last store, i found a handspring visor prism for 25 bux. they have very nice screens and a motorola dragonball 33mhz cpu.
                                          it had no base, so ill buy it a usb cord instead (they run 10-12 bux for a new belkin one).
                                          it was broken, though. the cradle connector was broken off as was a screw mount.
                                          but, the connector had all the pads still attached (i had to bend a few back in shape), and since the stylus had a built-in screwdriver, i opened it and re-soldered the surface mount connector.
                                          the solder job went very well. you cant tell i did anything. ill have to get the cord to charge it, but i will be fine
                                          good or bad deals?
                                          sigpic
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
