best cheap/free scores 1.1
This is a sticky topic.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    #4741
    Re: best cheap/free scores 1.1
    Speaking of scores, here's a photo of two laptops I have fixed from some of my posts in this exact thread.
    Left: HP Pavilion DV7-1214ea, from post #4737
    Right: Acer Aspire 5740G-333G25Mn, mentioned in post #4152.
    How I fixed them:
    DV7-1214ea: AMD NB needed reflow, this time it actually worked. (I went through 4-5 units that failed to come back to life, this is the first). Have repasted it, swapped in a Turion ZM-82 and added some pennies under the GPU heatsink as the board has slightly warped around the GPU area (since the NB and GPU are pretty close to eachother), and it runs quite cool for a S1G2 machine (much cooler than my now defunct Acer 5536G)
    Acer 5740G: ghetto fixed it by programming an old 775 mobo (Gigabyte 945GZM-S2) BIOS chip with the EC BIOS (using this tool) and then soldering the dead 775 mobo's reprogrammed & repurposed SPI chip onto the Acer mobo.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      master hoarder
      • May 2008
      • 12175
      #4742
      best cheap/free scores 1.1 - ESS Essentials ESS-6060-RED office chair
      About a month ago, I found a cool-looking office chair thrown out for trash pickup in my neighborhood.
      It’s an ESS Essentials model ESS-6060-RED. It was immaculately clean and even smelled like it came from a clean house (actually, there was a strong air freshener or some kind of leather cleaner smell on the chair, but it wasn’t unpleasant in any way.)
      Only one problem, though: one of the caster wheels was broken off. And it wasn’t the actual caster wheel that was broken, but rather its seat/hole in the plastic base of the chair. Didn’t seem like anything drastic that couldn’t be fixed, though.
      Since the plastic pieces that held the caster were all still attached in base (but just pushed/bent in), I thought it would be best to glue them back in their proper position. I started looking for any marks on the base to see what kind of plastic it was made of. It didn’t say, unfortunately. I was hoping that it would be ABS or other similar plastic that lends itself well to solvent-based glues (like PVC glue, for example.) Since I couldn’t tell what plastic it was, the easiest way to know was to put a big dab of glue on the plastic somewhere, wait a minute or two, and then rub it with a small screw driver. If the glue dissolves the plastic into a gooey substance, it’s suitable. However, I wasn’t lucky with this one. The plastic base didn’t react to PVC glue or Acetone. If I had to guess, it’s probably PBT.
      Thus, I figured the best thing then would be to just glue the broken plastic pieces in there just to hold the shape of the hole for the caster shaft, and then support the back of those plastic pieces with a filler material. I proceeded to gluing the plastic pieces with contact cement. While contact cement is not very strong in applications like this, it does at least stick well to all materials. Once it cured and the plastic pieces were in place, I filled the holes behind them with regular general purpose house silicone and inserted wood pieces as material filler. The result was this:
      https://www.badcaps.net/forum/attach...1&d=1607578612
      It may not be that pretty, but it should hold. And it won’t be visible, since it’s on the bottom side of the base. However, I took it a step further and painted with some black latex paint.
      There, now it’s done!
      After the paint dried, I put the casters back on and tested the chair. Everything worked well. However, I noticed that all of the casters have quite a bit of play room in the holes in the plastic base. Now, I’m no expert when it comes to office chair… but to me, this seemed like the loose caster shafts could do more damage over time if left as-is. So I added a few layers of clear packaging tape on the metal shaft of each caster. This made the casters fit a lot more snugly into the base. Rolling the chair around feels a lot sturdier too.
      So I think that completes this repair. A $150 chair (actually currently more like $125 at Wallmart and Amazon) saved from the trash and fixed with zero parts wasted.
      And here it is:
      Now for those interested… here is the BACK STORY (skip reading if you don’t care to know how I found it.)
      Just like the PS3 I found a few years ago, I was basically on my way to the grocery store (on my bike) and saw this chair thrown out in front of a house. I stopped and inspected it from up close, since it looked pretty good and very clean. Noted that one of the caster wheels was broken off and sitting on the cushion of the chair (very thoughtful of the owner to do that - thank you! ) But since I was on my bike, there really wasn’t a way to take it with me, obviously. I just noted which street it was on and continued on my route. Later that day, I thought about picking it up. But then I thought, why not leave it for someone else who might need it more?
      I was going to let it go, but I then remembered we had rain forecast for that day (later in the night.) Around 10 PM, just probably 10-20 minutes before it started raining, I went out to see if the chair was still there, since it was pretty close to where I live anyways. Surprisingly enough, it was! Perhaps the fact that it was on a quieter (inner) street that doesn’t see much through-traffic was the reason why. Seeing that the predicted weather forecast really was bringing rain (in fact, it was just starting to mist very lightly), I figured either I take it or it will get ruined by the rain and then probably the trash truck will crunch it for breakfast the following day.
      So I popped the trunk on my car and started fiddling and diddling. As I expected, fitting this thing in my econobox vehicle would be quite the challenge, if not impossible - I know, because my current desk chair is comparable in size, and I brought that with the trunk open and chair base sticking out. But when I tried that with this chair, the arm rests were slightly taller and just couldn’t get the seat part of the chair to fit in the trunk. It fit to a point, but was wobbly and looked unsafe. Sure the drive home is ~5 minutes on small local streets. And it was late, so there wasn’t any traffic. But in the end, the idea just didn’t look safe, so that was a no go. Luckily, I had remembered to bring my (former) work backpack with me, which had a few tools inside. I figured I could just take off the base and fit the seat in the trunk. I looked at the 4 bolts holding the base - they could be removed either with a 15 mm socket or 6(?) mm Allen wrench. Unfortunately, both of these were tools I had removed from my backpack when I cleaned it. The only thing left in it was a set of Torx. However, the bolts were a size that none of my Torx fit - either too small or too big. I then took out my trusty Harbor Freight 4-in-1 (really 6-in-1) screw driver and tried the small flat head side. It fit! I started removing the base bolts with a jolly smile. Two of the bolts were really tight, though. So I put a lot of pressure on the screw driver to make sure it doesn’t strip the Allen wrench head. Then I jokingly thought, What are the chances of Murphy’s law striking me here on the last bolt. Sure enough, this is EXACTLY what happened - head stripped on the last bolt (not much, but enough that my flat head screw driver could no longer engage it.)
      Now what?!
      I took the chair out of the trunk and started (depressingly) thinking. The sunken feeling of defeat made me want to put the bolts back in, leave the chair, and hope someone else takes it. But what the heck, I can be stubborn bastard too. I started trying things. I sat on the chair and pushed it all the way down. While at it, I also noticed it’s not as wide as my current desk chair. Then an idea came to my head that I can maybe, somehow, with a pinch of luck, fit it upside down on the passenger seat? (The rear seats were out of question, as the rear doors on my car don’t open as far as the front ones.) So I started fiddling with that and… almost had success. The chair did actually fit, but the arm rests were still a bit too wide (by just a few inches / cm ) for the passenger door to close
      At that point, the house owner came out to see what’s up (I guess all that goofing must have attracted some WTF attention. ) Of course, I greeted him and also asked if it’s OK to take the chair. Much to my surprise, he said, absolutely no problems! If you can find a better use for it, go for it. We then chatted a little more and he told me that he got this chair no more than 2 months ago. He barely put any use on it when one of the caster wheels broke from the plastic base. I’m not sure why he didn’t try to return it, as it probably would have been covered by warranty (perhaps an online order and needed to be shipped back? ) Either way, he said he already bought another chair, so it would be good to know if this one didn’t end up in the trash, as it was $150 when he bought it and still was new and clean (which I had already noted when I saw it earlier in the day. )
      So anyways, I thanked him and went back to finish goofing around with trying to get the passenger’s side door to close. It then occurred to me to try and move the passenger’s seat back just a bit. Sure enough, that did the trick - the door closed, just barely. I jumped in my car and drove off with a smile. When I got it home, taking it out of the car was a challenge again, due to pressing on the height lever by accident and the base stretching out, getting itself stuck inside my car (Murphy’s law strikes again! ) But now that I had tools, I took off the base and was finally able to get it out.
      And that was that.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Nice! Good to know I'm not the only one that will pick something out of the trash.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • brethin
          • Dec 2008
          • 1907
          I prefer the shorter version.
          I found this nice chair for free.
          • speter
            Been around the
            • 77
            I like the back story also, good reading on an otherwise boring day...
            Goshen NY, USA
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3266
              • Singapore
              #4746
              yea thats a really nice looking comfy chair. looks almost like a throne. the only thing is i dont like chairs with armrest as i prefer to spread my legs over the table sometimes when on the computer.
              yes i know it sounds weird, pervy and inappropriate for a man to be doing that but i swear its a comfortable position for me to sit in sometimes. also, when i put my legs up on the table, it stops my bad habit of constantly shaking my legs.
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                #4747
                Scored a DV6-2055EG today. Had bad screen, bad RAM sticks and missing BIOS info, but also had some goodies such as 320GB 7200RPM Hitachi HDD, as well as a C H U N K Y 9200mAh 3rd party (PowerY is the brand, they claim to use Panasonic cells) battery.
                Swapped in a new display, CPU, RAM, DVD drive, RAM and keyboard and now it's working fine.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  Was given a 55" Samsung 4k TV today. Works, but......their dumbshit kid threw a game controller at it and broke the screen.... WTF!!
                  Team : 49813
                  Join in!!
                  Team Stats
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    #4749
                    Can use PCB-s for spare parts or sell them.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                    • Hondaman
                      • Sep 2008
                      • 1092
                      A couple of days ago I grabbed a 50-inch TV from someone's trash (with no paperwork or remote) and put it in the trunk of my car (the owner was about 7 houses up the street from me). It turned out to be the Insignia NS-50DR620NA18, Best Buy's house brand. It is a 50-inch "ROKU TV" manufactured May, 2017.
                      When I plug it in, the red light comes on to indicate the unit is off. When I use the IR Blaster [remote] in my Samsung Galaxy S5 phone to turn the TV on, the red light is supposed to go off. It goes off, but gives two rapid blinks, then goes dark for 1 second before repeating the cycle of blinking and going off.
                      Based on this thread here at Badcaps, it might be the T-con board, I'll look into it after Christmas.
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        #4751
                        Not really much of a score but I got a new keyboard for the DV6-2055eg posted above. Its original KB was a Deutsch matte keyboard, and the new one is a matte Nederlands one. Near pristine condition (spacebar and a few keys have very very light usage marks) and also works perfectly.
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                        • speter
                          Been around the
                          • 77
                          That happened to me three times, my daughter has autism, and during a meltdown, she throws things. A 55 Visio smart tv, a Sharp Quattro 53( with 3D glasses), and a Samsung 55 inch.
                          Goshen NY, USA
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            I'm sure the cells are labeled Panasonic...
                            But if it's still good, extended batteries are indeed nice. My last three Dell latitudes (D630, E5530, E6430) all have been equipped with such. No regrets.
                            It happens. Heck, just playing some of my old Game Boy Advance games (Pokemon Emerald, in this case), I wanted to throw it a few times as well. The TV was free for a reason! :p
                            Last edited by ratdude747; 12-13-2020, 05:01 PM. Reason: RD needs to learn to spell...
                            sigpic
                            (Insert witty quote here)
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              I've always been a person that takes care of his stuff.....mainly because I always had to buy my stuff (toys) even as a kid.... A controller-throwing tantrum over a game is a pretty dumbfuck thing for a kid to do, let alone an adult!! Even if I paid for it, my mother would have beat my ass over something like that.
                              I'll scavenge the boards and the backlight LED strips out of it and pitch the rest.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • brethin
                                • Dec 2008
                                • 1907
                                Kids these days think they are privileged and don't care about anything but what they can get for free.
                                  • 31287
                                  put thick lexan over the front of the tv.
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    #4757
                                    Honestly, I wouldn't want to crack the battery open, but if there's one thing I can tell, is that it's as good as HP's genuine extended battery in terms of longevity - IIRC I used some battery time calculator, and got about 13 hours of usage - probably 6-7h realistic?
                                    Anyways, the company itself (Powery) seems to be originating from Germany, so at least that's a good thing, I guess. HWMonitor reports 8% wear. The only issue I have with this generation of HPs is the fact this DV6 doesn't show the time remaining when hovered over the battery icon. I haven't tried it on the DV5-1131EN I have to see if it reports anything.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                    • speter
                                      Been around the
                                      • 77
                                      That has been discussed... The only thing is how to hang it from the ceiling, or mount it to the TV
                                      Goshen NY, USA
                                        • 31287
                                        depends on the tv - if it has a large border around the screen then i'd put it on the front - maybe with double-sided foam to keep dust out.
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16959
                                          Had a walk-in drop off a box of laptops, some UPS's with dead batteries, and a dell poweredge sc1425 with a pair of 3.8GHz Irwindales.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
