Need Insignia NS-32D201NA14 Error Codes
  • geminidpr
    • Dec 2011
    • 41
    This insignia ns-32d201na14 LED T V uses the red power light in the front of the set to signal the error codes and it is flashing two times. Can someone please post the error codes or let me know what the two blinks indicates?
    Thanks.
  • geminidpr
    • Dec 2011
    • 41
    Re: Need Insignia NS-32D201NA14 Error Codes
    A shorted diode next to the 12 volt fuse on the t-con board was causing the two blink error code.
    • chris89
      • Jan 2015
      • 69
      • United states
      Dude it's hilarious yours went out too at the exact same time as mine... Same exact TV.
      Can you take a pic? I have no idea what the T-Con board is... I replaced the master board and power board and had the same issue...
        Just do the search using the tv model number and follow by the word t-con and you will see lots of hit for the t-con board.
        • chris89
          • Jan 2015
          • 69
          • United states
          I found the t-con board but as far as where the diode beside the 12v shorts is my question... Maybe just by eyeballing it, it will be obvious...
            Is that your T-CON board? Insignia tends to use more than one LCD panel supplier for the same model TV, same for other boards inside the same model.
            We need really good clear pictures of the board.
            • chris89
              • Jan 2015
              • 69
              • United states
              Nope that's what I found looking up the model's tv t-con board on google... I had the TV apart... see 2 boards power and master then below is a board with 3 ribbon connections board on the bottom edge in the center of the tv... I have no idea lmao
                The t-con will be under the metal shield, it will bet at either at top edge center or bottom edge center of the LCD panel.
                How about providing the picture of the whole back side of the TV?
                • michalk3777@gmail.com
                  Sharp Hisense - LC-65N7004U Error codes
                  by michalk3777@gmail.com
                  Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                  Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                  Regards,...
                  12-15-2024, 09:20 PM
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • sushilachuthan
                  APC UPS error P13
                  by sushilachuthan
                  one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                  the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                  The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                  We replaced the SCR with new device,, but the device is not power on as expected.
                  Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                  09-26-2025, 09:00 AM
                • mecha1166
                  QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                  by mecha1166
                  I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                  03-28-2024, 08:31 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
