My Asus P6T CMOS settings now always wiped out when unplugged!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: My Asus P6T CMOS settings now always wiped out when unplugged!
    Originally posted by Uranium-235
    Check that pin on the very edge
    On my Deluxe, no signs of shit solder joints. It looks safe to say that the bizarro problem is being caused by the XFX Radeon RX 580.
    Because of not expecting that bizarro thing to be related to the video card, I just went ahead with getting another motherboard from a seller on eBay, which don't look scummy, thank the Lord. IIRC, they're from Hollister, California.
    I've actually had better luck so far than with 3B Tech back in January, 2013, for the Asus Maximus II Gene motherboard, (socket 775) which the first time, received one that failed to boot and then I saw bad socket pins! At least, none of that type of bullplop, AFAIK. But 3B Tech saved my bacon! On February 11, 2013, I finally received a Maximus II Gene that's OK, hooray! (On February 11, 2013, wondering if 3B Tech just sent me back the same motherboard in the same condition, I went ahead anyway!) There was a long moment of silence and thus, it looked like the money of the time, was going down the toilet!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • i440bx
      Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
      by i440bx
      Hey there,
      I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
      The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
      It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
      As written above, I plugged in a new CMOS cell and checked...
      08-19-2024, 02:28 PM
    • RetroComputingGrotto
      New Toy UNI-T UTi260B - What Settings?
      by RetroComputingGrotto
      I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
      After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
      I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
      09-02-2025, 08:36 AM
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • Genghis_Khan
      ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
      by Genghis_Khan
      I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
      Issue summary:
      Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
      However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
      11-11-2025, 11:51 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
