New Toy UNI-T UTi260B - What Settings?
  • RetroComputingGrotto
    • Aug 2023
    • 120
    • Retro Computers (and fixing modern laptops too).
    I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
    After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
    I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal camera than can recommend what settings to change to get the best out of this device?
  • domix
    LG Air Conditioner AC unit bypass
    by domix
    i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
    Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
    how can i bypass this :/
    I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
    11-25-2025, 02:54 PM
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
  • i440bx
    Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
    by i440bx
    Hey there,
    I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
    The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
    It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
    As written above, I plugged in a new CMOS cell and checked...
    08-19-2024, 02:28 PM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • DrDos
    Unit runs but no speaker output kenwood KR-6030
    by DrDos
    I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
    09-14-2025, 09:57 PM
