Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
  • i440bx
    • Aug 2024
    • 11
    Hey there,
    I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
    The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
    It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
    As written above, I plugged in a new CMOS cell and checked the voltage (about 3.2V). During my research I found the chip the battery is connected to: nuvoton NPCE586HA0MX.
    The chip has a 0 ohm connection to the coin cell connector, but it can't save the settings without power.
    Do you have any idea where to look or can you point me in a direction where to look?
    Thanks,
    Robert​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    RTCRST#/SRTCRST# present with only cmos cell connected,no power attached?
    • i440bx
      • Aug 2024
      • 11
      I read about these pins/conncetions but i did not found a Datasheet of the nuvoton chip.
      Do you have this?
      • piernov
        • Jan 2016
        • 4439
        • France
        It's the southbridge that matters not the EC.
        • i440bx
          • Aug 2024
          • 11
          Ah! So I need to find the pins on the southbridge and check if they are connected to the CMOS cell? This is the right hint, because I suspected the Nuvoton chip to be faulty.
          Am I interpreting correctly that the CMOS setting is stored in the southbridge?​
          Edit:https://edc.intel.com/content/www/jp...s-and-signals/
          Edit2: https://www.mouser.com/datasheet/2/6...fVYC_ZVs6_wPgq
          • piernov
            • Jan 2016
            • 4439
            • France
            The actual BIOS settings are stored in the BIOS SPI ROM (a non-volatile memory), but the southbridge contains volatile registers (a long time ago some settings were actually stored there) that get cleared when the RTCRST# signal is triggered (i.e., goes to 0V) or the RTC power well is lost. The BIOS then detects a specific flag has been cleared and resets some of its settings during next boot.
            • i440bx
              • Aug 2024
              • 11
              Ahaaa! Thanks for explaining the process. So the problem is just to find the pins wich are probably​ pulled high or have a missing GND bridge.
              As I dont have a shematics you maybe can hint me how to find these pins or the traces that are conected to? The Board has some solderjumpers but unfortnatly HP did only wrote the reference but not a name to them.
              I know what is a SPI ROM At the ES Laptop its in a socket so I just need to find the right adapter/tool to read it.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Tracing the RTC circuit with multimeter and without schematic needs experience.
                There will be a diode(most likely 3 leg) near RTC cell. Check voltage on all legs with only cmos cell inserted.
                However, its not necessary the diode will be close by.In that case you need to put your multimeter in continuity mode aka diode mode
                and check continuity from RTC cell + side to where it beeps and further on.
                Needs patience and experience. Good luck.
                • i440bx
                  • Aug 2024
                  • 11
                  I do have experience in electronics and troubleshooting, but nowhere near as complex circuits as this “new-fangled” mainboard.
                  Thank you very much for the tip, because it's enough to at least start tracing the wires.
                  Am I right in assuming that the button cell pulls up the RTCRST#/SRTCRST# pin, reduced in voltage by a diode? If so, one of the solder jumpers should also have the button cell voltage or the reduced button cell voltage applied.
                  €dit: Correction: If the voltage of the button cell were applied to the solder jumper (and the opposite side has GND) I would not have the problem of the forgotten CMOS settings.
                  I may have to find a closed solder jumper that fulfills the above requirements.​
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    RTCRST/SRTCRST# is part of RTC circuit inside PCH. yes the voltage is supllied by +RTCVCC.
                    • RetroComputingGrotto
                      New Toy UNI-T UTi260B - What Settings?
                      by RetroComputingGrotto
                      I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                      After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                      I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                      09-02-2025, 08:36 AM
                    • questore
                      XPS 13 9370 CMOS battery voltage always low
                      by questore
                      Hi Everyone,
                      I have brought you a mistery item
                      This laptop have come with some strange faults.
                      1. CMOS battery was flat 0v
                      Symptoms:
                      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                      Amp drawing was stuck at 0.005 milliamps.
                      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                      After inverstigation RTCD1 diode had a low value...
                      09-30-2025, 05:47 AM
                    • i440bx
                      Shematics needed: HP Elitebook 820 G3
                      by i440bx
                      As the title say I need the shematics of the HP EB 820 G3 to find the signals RTCRST# and SRTCRST#.
                      A small guide or just a picture would also be sufficient.
                      Please read Here to get more infos:
                      https://www.badcaps.net/forum/troubl...spite-new-cell
                      Thanks,
                      Robert
                      08-20-2024, 08:34 AM
                    • magistertc
                      CMOS battery drains quickly
                      by magistertc
                      This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                      as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                      Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                      Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                      configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                      07-06-2024, 09:55 AM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
