another watercooling disaster.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    told the customer the watercooling system he has is a pile of junk.
    he insisted we build a new box with it.after it pissed on his old hardware killing it.
    3 months later we are back with another leaking block.
    hey its on his dime!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: another watercooling disaster.
    http://en.wikipedia.org/wiki/P45_(tax))
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      its like audiophools.you can tell them why we dont do something or use a brand/type of part but its expensive and looks cool so i want it anyway.
      anyway the idiot tax will be paid via all the repairs this turd will need over time.
      • Wizard
        • Mar 2008
        • 2296
        Heh!
        Sounds like the water-cooling equipment is shoddy and always clamp all hoses. Very IMPORTANT to have airspace in the tank/tube for thermal expansion.
        For short period of time Apple sold G5 towers with water-cooling stuff and there was problems with it leaking.
        Cheers, Wizard
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          If I had a watercooling setup I would mount the motherboard and everything upside down (as in facing the ground, not upright) so if it did leak there would be a greater chance of it just dripping down instead of leaking crap all over the motherboard.
          • Toasty
            • Jul 2007
            • 4171
            JetDry in the coolant stops those nasty water spots...
            veritas odium parit
            • KeriJane
              Mac Enthusiast
              • Sep 2008
              • 681
              LOL...
              I came across a watercooling kit once.... it was on sale from $150 down to about $20.
              I looked it over and thought: "This looks like a really good way to ruin a computer AND the carpet!" No Thank You.
              Also, the radiator fan it had was louder than my whole system! I never did plug in the water pump which needed 120v run into the computer.
              Isn't that odd... You had to run a 12v wire OUT of the computer for the fan and a 120v wire INTO the computer for the pump. Plus figure out a way to turn the pump on and off with the computer.
              I sold it to someone from Ohio who loved it.
              Keri
              The More You Learn The Less You Know!
              • Krankshaft
                • Jan 2007
                • 2328
                I come from the school of common sense that electronics and liquid don't mix.
                Heatpipes sure the liquid in them is sealed in metal tubes. Not flimsy rubber with hose clamps. I use them on my comps but thats as far as I go.
                Heatpipes, big heatsinks, and fans for my cooling needs thanks.
                Water cooling is too much.
                As KC said just like audiophools who like their special caps and whatnot. I'd like to see them identify their favorite caps with a sound test. I'd love to see them not be able to identify the equipment that has "better caps" inside.
                Because all the cool guys use water cooling and say it's better I want it too.
                But then again to each his own. It doesn't make me feel any better to see others wasting money like that though.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Tell that guy to use mineral oil instead of water. At least it won't kill the system if it leaks again.
                  • Toasty
                    • Jul 2007
                    • 4171
                    There are several non-conductive coolants for this application. A few of them also have a UV component that simplifies leak detection. They all appear to have some type of corrosion inhibitor and an algaecide as part of the mixture.
                    The systems must first be flushed completely to remove any dirt and leftover water. I've also seen it said that a once a year fluid change is recommended. Just like maintaining your car. LOL
                    Toast
                    veritas odium parit
                    • KeriJane
                      Mac Enthusiast
                      • Sep 2008
                      • 681
                      This sounds like a great way to stimulate the Economy!
                      Let's mandate use of high-pressure liquid cooling systems on ALL computers, even Laptops.
                      Then, let's make sure that ONLY a government-approved coolant that stains anything it comes in contact with and also smells REALLY bad can be used. It should also be corrosive and toxic so as to ensure rapid leaking and massive damage to computer components, furnishings and hapless operators.
                      Just think of all the jobs that will be created!
                      Burn centers / poison control clinics
                      EPA
                      Carpet cleaners / stain removers
                      Fire departments
                      Computer repair specialists
                      Computer factories
                      All of the businesses involved with an anti-government revolt
                      Any ideas?
                      Maybe something like liquid sodium?
                      I saw a thing on TV once where they used liquid sodium to cool a nuclear reactor with disastrous results... maybe that would work?
                      Or maybe we should contact Fuhyjju as a vendor?
                      Happy 4th of July!
                      Keri
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Given the way PSU's are going toward exceeding the rating of 115v sockets (and breakers) we'll soon need 'hybrid PSU's' with a fuel tank and a kick starter.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          give it 2 wheels and you have the worlds first moped/supercomputer combo:
                          YOU can:
                          find the exact value of pi while taking cherry pie home
                          shoot and edit the next lame racing movie, all at the same time
                          crash and crash at the same time (survival only possible with both data and head protection )
                          better stop...
                          sigpic
                          (Insert witty quote here)
                          • acstech
                            GrumpyModerator
                            • Jul 2007
                            • 1432
                            Originally posted by KeriJane
                            Any ideas?
                            Methanol / Butanol mix. They're both corrosive, flammable, very toxic, the Butanol smells bad, and they'll probably leave a stain. Plus they both absorb water out of the air, so after it leaks it will eventually become conductive. Put in some UV green dye and you're done.
                            A man convinced against his will is of the same opinion still.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Why don't we just go all the way with boiling water or sulfuric acid?
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                because boiling water doesnt cool anything, duh.
                                it has to at least appear to work
                                sigpic
                                • KeriJane
                                  Mac Enthusiast
                                  • Sep 2008
                                  • 681
                                  Hi Ratdude!
                                  Ummmm....
                                  Boiling water DOES cool something. That's why it's boiling! It's cooling the pot or heater thing or whatever is providing the heat and preventing it from getting hotter than 212℉.
                                  All we have to do in order to cool a computer with boiling water is:
                                  a- Design a computer that operates at over 212℉
                                  or
                                  b- Design a Cooling System that operates at high vacuum so that the water boils at maybe room temperature.
                                  But it's not corrosive or stinky or stain-y enough for the proposed Stimulus Computer.
                                  Happy (Achoo!) 4th of July,
                                  Keri
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    How about large banks of diesel powered Peltier Coolers?
                                    Diesel generator goes in the back yard.
                                    Optional window mount brackets for Apt dwellers.
                                    . . We could sell blue LED fans for the radiator fan on the engine.
                                    For the economy minded, a USB powered swamp cooler that retrofits into the back panel fan mount.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      How about liquid nitrogen instead of water?
                                      No wait! - That's safe...
                                      - Dr Seuss
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        or gasoline. when it heats up, it expands into a gas. mix in ethanol (say e85) to dissolve plastic pumps and fittings. when it shorts the board, then you have a compaq campfire.
                                        sigpic
                                        • bussincaps
                                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                          by bussincaps
                                          Hello All,
                                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                          08-03-2023, 12:57 PM
                                        • nobbnobb1
                                          DIY NAS Service Life (Hardware)
                                          by nobbnobb1
                                          So I'm probably a decade behind on this, but my current NAS is a low power machine I built in 2009. It was originally running Windows Home Server, then eventually I migrated to Windows 10 using Storage Spaces for my drive expandability and redundancy. Despite being slow for W10, I love the familiarity and functionality so I never bothered getting into NAS specific OS.
                                          Hardware wise, it's got 4x drives but the hardware is all super low draw, so the Antec EarthWatts EA380D power supply is barely above ambient. This PSU is apparently known for capacitor issues but when I went in to...
                                          09-25-2023, 04:35 PM
                                        • vbogoev
                                          GYSMI 160p welder transistors shorted
                                          by vbogoev
                                          Here I have GYSMI 160p welder with no output. Otherwise the machine is starting, the fan is spinning, but the output is zero... I disassembled the welder and found the problem. 3 out of 6 transistors are shorted, and 3 pairs of 4 resistors are burned... There's also 1 burned "ultra fast diod" on another board that is connected to the transformer. My question is how can I identify these burned resistors, I have no idea what value they should be, also I am not able to find any image of the board over the internet... The other part numbers are clearly visible, so I...
                                          08-31-2023, 03:53 PM
                                        • courtcircuit
                                          Onkyo TX-NR801e No sound
                                          by courtcircuit
                                          Hello
                                          Got his monster in a waste.
                                          It was probably dropped there due to the fact that no sound gets out, nor speakers, nor headphone
                                          Everything seems to work. Just have to clean the volume encoder, but the remote is fully controling it.
                                          Relays are closing (it looks like from a first look into the beast) that there are a lot of them.
                                          When I switch it from standby to live, they react, I can hear a little static noise in the headphone. the same when switchin it off.
                                          Ive seen that a lot of similar devieces from onkyo suffers from...
                                          08-18-2023, 10:32 AM
                                        • N²x²N
                                          ASROCK K7VT4A PRO repair
                                          by N²x²N
                                          Hello!
                                          I bought this board but isn't powering on. Seller told me it was fine and stable.
                                          Got it for a dime but it supports NX models.
                                          Ths cpu it came with works fine and the 2gb are error free (2x1gb).
                                          https://www.asrock.com/mb/VIA/K7VT4A%20PRO/#BIOS
                                          I inspected the board many times and no component gets crazy hot, not even lukewarm; no traces are cut or damaged.
                                          Battery is fine on its circuit.
                                          The ASM1117 outputs 3.5V instead of the usual 3.3x I saw in many other boards.
                                          https://pdf1.alldatasheet.com/datasheet-pdf/vi...
                                          05-11-2023, 05:09 PM
