Replacing ATX connector - tips tricks experience or help?
  • RuKK
    • Feb 2005
    • 34
    Hey guys, I just picked up a tyan tiger MP really cheap with a fried ATX connector. Nothing else wrong with the board. What do you think about replacing it? Can I just take a solder sucker and my iron and pull that thing out of there and plug a salvaged one off another board in? Any tips for removing it from the other board without wrecking it? Even look feasable? Here's a couple pics:
    http://www.shawnmann.com/images/forums/P5110003.JPG
    http://www.shawnmann.com/images/forums/P5110004.JPG
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    I've replaced a lot of those. The trusty solder sucker has always worked fine on them. The trick is reflowing the solder using a good hot iron, making sure it melts through all layers, then using the solder sucker and pulling all the solder out.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • AK0R
      • Mar 2005
      • 204
      Are you sure there's nothing else wrong with the board? All of the damage to that connector is on the four +5VDC lines. Something pulled *A LOT* of current through that connector; there's a better than good chance that anything connected to +5 sustained damage.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        it has some hermei caps that should go.
        hmmm a tyan S2460......quite a few posts on the net about the same issue.
        use a high quality psu if you get it working again
        • MD Willington
          • Sep 2004
          • 702
          That's a nice ESD mat [/sarcasm...
          Ya'll think us folk from the country's real funny-like, dontcha?
          The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            not to mention fire hazard
            • RuKK
              • Feb 2005
              • 34
              Re: Replacing ATX connector - tips tricks experience or help?
              Hey, not my pics :P Its not like he was powering the board on or anything on the carpet. Anyway.. so I finally received the board, only to discover that *SOMEBODY* had already taken a crack at replacing the ATX connector. The whole area is a mess.. I got a pretty decent close up pic of it, and blah. So I'm asking for your help.
              Some of the pins are fine, but in others I guess whoever did it used too low wattage a iron or something, and burnt right through the thin green layer around the pins, down to what appears to be a layer of copper. The solder then flowed onto that as well as the rings around the holes.. I assume grounding out these pins. I need ideas on fixing this. I got some of the pins unsoldered with this crappy solder sucker, but I need some wick for the others, which is why it looks like a bit of a mess right now.
              I realize I may not be able to fix all, or even any of these pins, in which case, is there the possibility of completely avoiding the atx connector, and wiring the psu directly into the vregs? Where exactly would I run all those lines? I can provide as much info as possible, high resolution pictures of every square inch of the board, and multimeter readings. I've got 5 or 6 dead boards and about as many dead psus to scavange parts off of, I just want to get this thing running again. Any help at all would be VERY much appreciated. Pic of connector in its current state below. Thank you VERY much for the help guys
              http://rukk.stfu.ca/pictars/s2460atx.jpg
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i dont see damage that would render the board unrepairable.
                you just need a good hot iron and a way to clear the holes.
                i would fix that in about 10 minutes.
                • RuKK
                  • Feb 2005
                  • 34
                  I guess my picture isnt good enough.. See the light green area of the PCB around the atx connector? Well, in some places, very very close to the pins, the green has been burned through to copper which is just underneath it. My guess would be I dont want to connect the pins to the copper, which will happen if I solder there without somehow isolating the copper..
                  • bushytails
                    Moderator
                    • Dec 2004
                    • 217
                    Post a post-desoldering picture.
                    --Randy
                    • RuKK
                      • Feb 2005
                      • 34
                      Will do as soon as I get some wick. This solder sucker just isnt going to do the job and I'm scared of hurting the board more.
                      • RuKK
                        • Feb 2005
                        • 34
                        Hey, worst case, if the ATX connector is totally shot and unrepairable.. Is there any way of hooking the various rails of the psu directly into the vregs and making the board work?
                        • yanz
                          • Nov 2004
                          • 910
                          yes, that is doable...
                          http://www.ocforums.com/showthread.php?t=58333
                          that is the example of connecting the 5V psu straight to the vrm. (5v is always regulated by psu, iirc ).
                          days are so short when you actually do something..
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            just clean it up and be careful soldering the new connector.
                            no big deal.
                            • RuKK
                              • Feb 2005
                              • 34
                              Ok, I did just that. Cleaned up and installed a new connector *very* careful of the exposed copper bits. I dont have a heatsink or memory to test with right now, but the fans spin now! I checked over the vregs with a mulitmeter, and I've got a question.. Everything looks normal but 4 vregs (2 per cpu). Here, I'll use a picture to demonstrate. The vregs circled in green measure 5.12v, which is what I would expect. The red circled vregs measure 0.012v.. which is a little odd. Maybe its because I dont have cpus in the board? I'm pretty sure I have a 12v rail working because the fan connectors and a small vreg over by the memory show 11.98v just fine.. If anybody else with a s2460 could check and tell me what these are supposed to be, I would be very grateful.. and here, without further adieu, the picture:
                              • RuKK
                                • Feb 2005
                                • 34
                                Nevermind that last post. Got the board to post with defective, unregistered ram and a generic 300w.. wow. Anyway, the vregs which are outlined in red in the previous picture output vcore. So I'll feed the 5v ones some nice clean power direct from the psu
                                • 5mall5nail5
                                  Help identifying connector for ASUS 4090 Strix RGB LED connector
                                  by 5mall5nail5
                                  Hi All -
                                  I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                  Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                  05-04-2025, 07:47 AM
                                • michhak
                                  Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                                  by michhak
                                  Hi guys,
                                  i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                                  It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                                  11-17-2021, 05:45 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • bussincaps
                                  MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                  by bussincaps
                                  Hello All,
                                  tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                  Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                  eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                  Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                  I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                  08-03-2023, 12:57 PM
