2m/70c Radio battery eliminator build
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Well, this timeline is going to be full of holes here. Make sure you format the right SD card kids! Anyway...
    So, the battery from my old dual band radio finally quit. I decided to build a battery eliminator.
    The case is about 1 1/2" x 3" x 1/2" OD, so space is a bit tight, but not horrible.
    Here's what it looks like gutted and my first attempt at a ground bus installed. (Hint, tin coated steel doesn't stick to silicone very well.)
    Next, the picture of my first (Failed) attempt.
    Why it no work? battery dead? 5.5v? WTF
    Doh! I that read wrong. Thats a 6v regulator, not 8v
    Well, lets try switchmode then!
    It Verks! *pop* ...are you shitting me? It committed suicide. LED is out.
    Round 2?
    Round 2 Verks!
    Into the case it goes. I had the whole assembly process photographed, but oops.
    Still Verks!
    Well, glamour (shame?) shots then.
    I forgot the nylon nut and bolt.... Crap. I may fix that one day.
    DC 20v test. Looks good.
    AC 20v test. Also good.
    Let me shoehorn in some firmware fuckery proof here.
    IN: AC ~9v-30v/DC +/-10v-35v OUT:7.6vDC
    Not a bad little eliminator.
    Follow the white rabbit.
    • 31159
    Re: 2m/70c Radio battery eliminator build
    nice - a UV5R, (or is it the 8W model??)
    that is a bad idea - the regulator will cook when you transmit 5W.
    i would put the regulation at the other end of the cable with a heatsink on it.
    then use the battery shell for extra filtering - inductors,caps etc.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Its the BF-F8HP. Ive been stress-testing it all day QSLing with the KC7SNO and WU7G/R (2m,70c respectively) repeaters and managed to catch some skip from Denver. My filtering is good enough it seems, and being a 3 amp regulator she gets a bit toasty, but nothing extreme.
      • desert-rat
        • Mar 2014
        • 4103
        162.55 is the nat. wether sev. As I remember 144 . Mhz is 2 meter ham .
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          ^ Yep. It can receive down into those bands. xmit, no. I was using it as a recive test. Interesting thing about the 775, its sponsored partly by the NWS, and they run nets on it.
          The daily weather net is at 6:45 am (local) on the 146.775 repeater.
          http://www.shywyarc.net/repeaters_and_nets_affix.html
            • 31159
            if you program it with CHIRP you can extend the frequency range a fair bit
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              So, i just wanted to post an update. I got the MFG's battery eliminator, and surprise surprise, it's an older design, same spec, with less filtering and no AC bridge. And a fuse.
              Glory shot
              Houston we have a problem. Why is the cord coming out the bottom? Well that won't sit in a cup holder!
              Houston, another problem. Dead short on the input! Diode pushed into the heatsink. Easy fix. Also, Focus you FAK!
              ChengX caps. This is actually probably one of the better applications for these caps....
              Board overview. These is why i say old design. Single layer board, that chip was designed to be a simple retrofit with minimal redesign of the board from a linear regulator according to the datasheet, and it switches at a paltry 52Khz, compared to the 1Mhz in the one i built.
              The underside shows much room for improvement...
              Now for the reason i got this. It looks a hell of a lot better than a lighter plug to banana plugs, then a set of roach clips hooked onto them.
              I personally don't care, but my boss very well might while im opertaing a company truck. Though, with how the inverter is wired in......
              So, thats my excuse for getting it. Being able to see how close my design was compared to one built by the maker of the radio, was just a nice extra.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                how long did that battery last before it became unusable and ripe for becoming a battery eliminator cartridge?
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  ^ About half a year and a couple seconds in my morning coffee...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Couldn't find another way to get your daily lithium dose?
                    Hmm... I might be forced to get a cheapie radio, curious about the battery management on these devices and how long the cells last before they become unusable.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      ^ Well, the Yaesu i have is good for 300 cycles, and its far from a cheapy radio.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Crap, I was about to ask how many cells it was, but at 7.6V it must be 2-cell, answered own question.
                        Why? At that point, it starts separating the cheapie and the better designed battery packs/systems... I also suspect there's no internal SMPS inside the HTs to boost voltage and thus power output/range goes down as battery runs down too (at the expense of noise generated by the SMPS?)
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          ^ Current draw increases.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Interesting, so there is a boosting regulator in it for when the battery drains down...?
                              • 31159
                              well, the UV82 battery is 7.2v Lithium-Ion and the charger is a slow charge at something between 8 and 10.5v i dont have it to hand to check.
                              the battery has internal protection and the charger has a chip in it - i can pull the exact details from another pc later.
                              i should also have the UV5r schematics.
                              i'm pretty sure there is no boost, just direct battery for the transmit circuit, and a regulator before the digital stuff.
                                • 31159
                                btw, if you buy a radio, the UV82 is the one to get.
                                better speaker than the others and double PTT buttons that you individually assign!!
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Interesting. So I need to get a radio with published schematics!!!
                                    • 31159
                                    not much in them, they use digital direct conversion and modulation.
                                    if you expect a bunch of cans and coils your not going to find them!!!
                                    that's how they got them so cheap, they are almost software based.
                                      • 31159
                                      your gonna like this!!
                                      http://radioaficion.com/cms/category/china-radio/
                                      • shelby5041
                                        clock radio / radio lifespan?
                                        by shelby5041
                                        hi
                                        ive got a modern digital clock radio approx 15yrs old
                                        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                        it uses very little power just a few watts i would imagine that may have something...
                                        09-14-2024, 03:30 AM
                                      • UserXP
                                        Vintage SONY Digital Clock Radio ICF-C12W no audio
                                        by UserXP
                                        Dear all,
                                        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                        My question is, do you know of this brand of capacitors and how bad are...
                                        07-21-2025, 08:35 AM
                                      • praveenramavath
                                        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                        by praveenramavath
                                        Hello All,
                                        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                        https://www.hifivision.com/threads/m...-screen.98243/
                                        Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                        04-26-2025, 09:08 AM
                                        HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                        09-12-2024, 02:00 PM
                                      • Omron
                                        Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                        by Omron
                                        Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                        My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                        - Tried to unplug radio and plug it back in into power,
                                        - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                        - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                        05-23-2024, 01:27 PM
