Dell BIOS
  • gustie
    • Dec 2008
    • 76
    Dell BIOS
    has anyone here bothered hacking DELL bios's? my g/f's PC is dell and its really dumbed down!
    its out of warranty so id like to maybe replace it with a standard intel bios...
    easy?? or not?
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
  • stevo1210
    • Oct 2006
    • 4156
    Re: Dell BIOS
    Providing that the motherboard from the Dell system is the exact same as an aftermarket one (say Intel in this case), then yes you probably could just reflash it with the BIOS from the aftermarket manufacturer. But I dunno if Dell may have improvised any locks into reflashing the BIOS with a different one other than a Dell BIOS. What model is the Dell system you are trying to hack?
    I know that I have successfully reflashed an ECS BIOS onto an ECS based motherboard that was installed inside a system built by Micro center, when they had some "Power spec PC" (or something like that) BIOS installed on it.
    Thanks.
    • gustie
      • Dec 2008
      • 76
      Re: Dell BIOS
      its only a P4 thing
      dell dimension 3000
      thanks
      TICTAC 619XT Bios
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Dell BIOS
        If:
        All chips on the boards are the same: *same chipset, sound, LAN, etc...
        and
        The BIOS chip supports the BIOS code you want to flash..
        and
        There is no security chip..
        Then it should work.
        I have seen cases (or rather one case but several times) where the BIOS chip used by the OEM fit in the same socket but was not the same as (or compatible with) the chip used on the manufacturers 'manufacturer branded' motherboards.
        Because of that if you wanted to use the manufacturer's BIOS you would have to replace the BIOS chip itself.
        I don't remember specific numbers but this will get the point across.
        Boards were identical except BIOS chip.
        Manufacturer's BIOS used a 2 Mb BIOS chip.
        OEM used same BIOS chip socket but used a 1 Mb BIOS Chip.
        So: Manufacturer's BIOS wasn't compatible with OEM's chip.
        There are a couple of companies around that will burn you a custom BIOS chip.
        Also some that will sell replacement chips for either/or manufacturer's or OEM's BIOS.
        Only helps if BIOS chip is the socket type or you are brave enough to solder in a pre-programmed BIOS chip.
        Prices for these things has come down because more companies are doing it now but usually I think you are still better off just replacing the board.
        Mann-Made Global Warming.
        - Dr Seuss
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Re: Dell BIOS
          I have the Dell Optilpex GX 180, PIII, 1 Gig, and the Dell Dimension 4550, P4, 2.4 Gig. While I have found retail boards that are similar they are not exactly the same for these things. My feeling is that you would be getting into a whole big nest of snakes, and worms trying to reflash the BIOS using the flash utility for the similar retail board. A Dell BIOS is dumb, and you can't do much to over clock these PC's but at least they work. Well they work most of the time on a good day. I'd love to upgrade my 4550 to a board that supports SATA, and a Duo-core CPU. I don't think that Dell will be of any help in this area as all they want me to do is buy a new one with Vista "Windows ME II" preinstalled. I'll just have to gut this case, and do some test fits with retail boards down at my friends PC shop. I also have a Saws-All. I can make things work if I have too.
          Mark Twain
          John Paul Jones
          Rod Serling
          • bgavin
            • Jan 2007
            • 1355
            Re: Dell BIOS
            It might be worth your time to grab a copy of MODBIN6 or whatever current flavor of bios editor is out there.
            I use this tool to customize the bios settings for client machines that I build. If Dell has "dumbed down" their bios, there is a good chance all they did was disable the display of hidden features. You can easily turn this on with MODBIN.
            Note this program ONLY runs under DOS, so you will need a FAT32 disk, and MSDOS6.x operating system. I have not had much luck with it running in a RAMDISK either. I keep a VMware DOS machine available for doing DOS work. Works a treat.
            • jpdoe
              • May 2007
              • 237
              Re: Dell BIOS
              Hi, bgavin
              Did modbin6 gave you any trouble? (as in resulting in a no boot motherboard at some point?)
              TIA
              • gustie
                • Dec 2008
                • 76
                Re: Dell BIOS
                thanks
                DOS scares me hahah
                but cheers for the info - i think ill leave it incase i render her DELL useless lol
                TICTAC 619XT Bios
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • Sathsul
                  Dell Latitude 5431 issues with dumping bios
                  by Sathsul
                  So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                  The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                  However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                  10-28-2025, 07:49 AM
