This stinks! lol
  • RJARRRPCGP
    • Jul 2004
    • 6304
    This stinks! lol
    And taking a long time to find the culprit. Priceless.
    http://www.doc.ic.ac.uk/~jab00/mouse/
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: This stinks! lol
    EEEEWWW! Beats my dead gnat.
    sigpicThe Sky Is Falling
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      hahahaha
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Never had one in any of my PC's....but it always annoyed me to no end to have a PC with the case off if it wasn't being serviced....and it annoyed me more for the IO shield to be missing. Stupid is as stupid does.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Thats rank lol, our cat brings dead mice in we found a small nest behind the cooker lol
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Never buy used ATX motherboards that come without the back plate?
            Not sure what to do about the ones acquired for free then...
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Did you see that screw? lol
              Arc A770 16 GB
              • dmill89
                • Dec 2011
                • 2534
                Unless the board has a really obscure IO layout you can usually find the back plates cheap (<$10) on eBay.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  I found a mummified mouse in the back of a stove once. Fortunately it was on the roadside for the rubbish, and not in my house!
                  -David VanHorn
                  • petehall347
                    • Jan 2015
                    • 4427
                    this is an amp i rebuilt a while back ... the mice had moved in big style ..
                    i have after pics somewhere
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4981
                      • New Zealand
                      I can just smell it...
                      -David VanHorn
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Actually have you looked at all the newer motherboards, there's like one special one for every one built out there now. The first ATX designs were very close to each other, but as companies started adding HDMI and eSATA ports with 5.1 sound, they've massively diverged from each other, basically requiring obtaining one from the original manufacturer.
                        I remember the days when ATX first came out, cases came with a few IO shields that covered many motherboards. But ever since serial and parallel ports stopped showing up on motherboards, there's like a unique shield for every board out there, so they stopped supplying shields as they knew they'd be tossed and why bother adding to the cost of the case.
                        At least VGA can be used with the serial port DB9 cutout, but even VGA is going the way of the dodo on new motherboards, likewise PS2 ports... and who knows where all the USB ports are scattered around the rear plate...
                        (and still, getting a motherboard worth $1 or less, buying an io shield that costs $10 is hard to stomach!)
