MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
This topic has been answered.
  • slimmy182
    • Apr 2021
    • 119
    • italy
    Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
    Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
    Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
    C81DC PP3V8_AON_VDDMAIN
    And
    Q5800
    What should I test as next step?
    Thank you very much!
  • Answer selected by slimmy182 at 02-06-2024, 02:14 PM.
    mon2
    • 14545
    That is a hard short so it should glow like a Christmas tree.
    You do not need to solder the ground wire but ok if want to do this. We actually use normal meter probes and pulse the injection by touching for a sec and remove the probe. Dial up 3A if possible and touch the rail with this missing voltage with the red probe. This action should cause the hot spot on the board to be visible under the thermal camera.
    • slimmy182
      • Apr 2021
      • 119
      • italy
      Unfortunately I have not a power supply to sort out the short. Any suggest how to proceed?
      • slimmy182
        • Apr 2021
        • 119
        • italy
        News: Now I got 30V10A Power Supply. If this could help
        • mon2
          • 14545
          Carefully measure the voltage to ground of PPBUS_AON @ F5200 - check both sides of this fuse with the power adapter connected.
          • slimmy182
            • Apr 2021
            • 119
            • italy
            Originally posted by mon2
            Cvoltage to ground of PPBUS_AON @ F5200
            5.65V both sides
            • mon2
              • 14545
              What is the voltage to ground of PP3V8_AON ?
              • slimmy182
                • Apr 2021
                • 119
                • italy
                C5887
                1 PP3V8_AON_VDDMAIN 0.19V. This line has no resistence to ground, shorted, 0 Ohms
                2 GND​
                • mon2
                  • 14545
                  Can you confirm the meter scale? Or share a pic of the meter face. If truly 0 ohms, you have a shorted component on this rail which will require the use of your power supply Suggest to dial up 0v8 -> confirm with your meter that it is indeed under 1 volt.
                  Then with no power to the board; apply this 0v8 power injection onto this rail. No battery, etc. but just this new fangled power supply you have. The current should spike due to the ultra low resistance and someone will heat up. Who is it? Hope it is a tantalum capacitor and split that puppy open. Watch for the smoke and/or heat signature. Use IPA (alcohol) if you need to and check where it evaporates the fastest.
                  • slimmy182
                    • Apr 2021
                    • 119
                    • italy
                    Can you confirm the meter scale?.
                    here is my pic!
                    That would be the first time using a power supply to sort out a short, can't wait to start!
                    I need to solder the negative pole to the ground on the logic board, while the positive pole goes to the component related to the track I want to investigate, right? Do you have any advice on which component to choose? I'll make sure not to exceed 0v8 by checking with a multimeter. How many Amperes should I use? Fortunately, I have a phone with a FLIR camera; I'll try that, and if it doesn't work, I'll use IPA (alcohol)."
                    • mon2
                      • 14545
                      Shift the meter to 20k ohms and measure again to check the resistance to ground.
                      • slimmy182
                        • Apr 2021
                        • 119
                        • italy
                        Zero ohms. Also checked in 200k and 2000k, still 0
                        • mon2
                          • 14545
                          • slimmy182
                            • Apr 2021
                            • 119
                            • italy
                            It should, and it happened!
                            It was C81DC , the same that was getting hot in my first post. Replaced and now the Mac is working pretty good
                            Thanks a lot
                            mon2 for your valuable support, as always. I'm truly glad to have resolved this issue and learned to use a new tool. I owe you a beer anytime!"
                            • mon2
                              • 14545
                              Awesome! Well done. Will settle for one of your tasty pizzas. Ironically purchased a number of imported pasta sauces (Arrabbiata, basil) from Italy along with Italian spices from a local gourmet store last night. Junior loved it and dove into the stash right away. May invest into a wood fired oven one day.
                              • slimmy182
                                • Apr 2021
                                • 119
                                • italy
                                the perfect pizza secret is the oven with stone base and good waterfoe the doug! But above All, italian love of course. If tou have any special whishes let me know, and i'll be happy ship it to you.
                                • Aeisens
                                  Samsung UE50RU7170 not booting /no picture
                                  by Aeisens
                                  Dear all,
                                  My issue is the following:
                                  Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                                  I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                                  Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                                  Question 1: Where should I start to...
                                  06-24-2025, 03:07 PM
                                • Daniel Kubica
                                  Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                                  by Daniel Kubica
                                  I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                                  I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                                  06-14-2025, 09:24 AM
                                • sylvain_92
                                  iMac 2009 A1312 2009 not booting - 3rd led not on
                                  by sylvain_92
                                  I am trying to repair my iMac A1312 late 2009 intel i5.
                                  First of all it was booting but no screen on internal lcd but working with external one,
                                  I tried:
                                  - another screen and led power board (booting no screen - same as before)
                                  - another mxm graphic card (not booting missing 3rd led)
                                  * screen and mxm gpu tested are 100% working on another A1312 iMac.
                                  I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
                                  The main...
                                  12-23-2022, 03:36 PM
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                  🛠 Original Issue
                                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • Adogabriel100
                                  where to get trusted CD3217. Problem with A2337 Macbook Air
                                  by Adogabriel100
                                  Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                  The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                  09-06-2024, 12:06 PM
