Changing voltages.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #41
    Re: Changing voltages.
    I count 4 coils next to the CPU, 4 caps total. Wouldn't that make it 4 phase?
    Markings on the caps? They're a bit weird and can almost be read either way. I believe one of them says E89H. That's not from one next to the CPU though. Only way I can make them out is to pull the board. Something I didn't really want to do right now.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      #42
      I believe the way it works is the VRM converts either 5V or 12V to whatever the CPU uses. Correct me if I'm wrong there. I thought the VRM was part of the VRC (Voltage Regulator Circuit).
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by Spork Schivago
        The PSU is made by a company I've never heard of, Okia. It's 450 watt.
        I tore a dead one (Okia 450W) open awhile back. JUNK!
        sigpic
        (Insert witty quote here)
          • 31204
          correct.
          and with unstable incoming power, the caps on that circuit probably got even more stressed.
          • dmill89
            • Dec 2011
            • 2534
            X2, an Okia "420w" (yah right) I opened up awhile back is the biggest pile of garbage I've ever seen, they are even poor on "free with case" PSU standards:
            • fzabkar
              • Mar 2009
              • 772
              Just as an example, the 3.30V would be 3.344V or 3.60V. Never 3.350V, etc.
              3.350V will never be reported by BIOS because 3350 is not an integer multiple of 16. The voltage can only vary in 16mV increments. That's the resolution of the A/D converter within the Super IO chip.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                The board says the bus is 1600 MHz. Whether it's running at 1600 MHz or not, I'm not sure. The RAM is DDR-1066 with a CL5-5-5-15 (2.0 - 2.1v), G.Skill F2-8500CL5D-4GBPK. The base frequency of the FSB would be 400MHz, right? The BIOS only has options to run the RAM at 667MHz or 800MHz, but my understanding is, unless someone's overclocking the FSB, there's no real point in running the RAM at a faster speed. Probably why the board only gives the option for 667MHz or 800MHz. Am I right in thinking that?
                I am wondering if that ram is compatible with that bus speed? Do you have the specifications on the computer? If it says the bus is 1600 Mhz I would suspect that is the speed of the Ram Bus. I have not study this for a while, but I am thinking that 1066 Hz Ram is not compatible with with a 1600 MHz bus. It works the other way around. That would be a higher frequency Ram is backward compatible, but because the Bus speed is faster the Ram of yesterday was not invented so would not be compatible. You are saying the forward bus is 400MHz this is an extremely slow bus. My Dell computer I had over 10 years ago had such a forward bus speed. To me I think you need to look up the Specs. on this computer.
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  #48
                  errr there is no need to go through all that just to get the bus speed. just get the bus speed for the cpu. the pentium e5200 or pentium dual-core e5200 is an 800mhz fsb cpu. so the fastest u can run the ram is ddr2-800 using the 1:2 fsb to ram ratio. u cannot run the ram at 1066 using an 800fsb cpu cuz the nbmch lacks the proper memory divider ratio to run the ram at that speed. u need a 1066 or 1333 fsb cpu to run the ram at ddr2-1066. not sure where u got that 1600 mhz figure from, spork. either its a golden cpu chip that can do an amazing 100% overclock or u must have seen something wrongly...
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #49
                    Originally posted by stj
                    correct.
                    Okay, just wanted to make sure I fully understood everything. That's what I was thinking too. The unstable incoming power stressed some of the caps and they started failing prematurely.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #50
                      This one that I have is a 450 watt and I believe it was free with case! The guy bought one of those pre-built systems off e-bay for maybe 300$ a few years back I believe. It came with the board, hard drive, CPU, RAM, etc.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #51
                        The 1600MHz is printed on the motherboard. It says:
                        FSB1600
                        DDR2 800
                        Dual Channel
                        I misunderstood the original question and thought someone was asking what was the fastest bus speed the board supported, which is a 1600MHz bus speed. The CPU, E5200, runs with an 800MHz bus speed. I know the RAM won't reach those speeds, it drops down the speed. Maybe because of this, I could tighten the timings a little bit? It's supposed to be 5-5-5-whatever at 1066MHz. I wonder if at DDR2-800, I can get 4-4-4-whatever. The RAM is running at 800MHz (400MHz base), which is correct, as far as I'm concerned.
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Yes Spork I believe you are correct as my knowledge is old. So the modern boards are divisible by the clock speed. So if you have two cores and they are running at 400 Mhz you then have 2X 400 MHz which is 800 MHz
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #53
                            I'm a bit confused by what ChaosLegionnaire said though. The RAM is running at 800MHz but it has a base frequency of 400MHz. The CPU's FSB is running at 800MHz...but because it's a dual core, would the based frequency be 400MHz? Wouldn't that give a 1:1 FSB to RAM ratio?
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #54
                              I'll be sure to keep a lookout for this in future and I'll be sure to test the voltages with a DMM next time I work on a PC.
                              Thanks!
                              Thing is a DMM can't show ripple.
                              You could have a "stable" 12v readout but with 2v ripple peak to peak and the DMM would not show it.
                              (It might be able to show some of the ripple on the AC setting but it's a pretty useless test because you don't know how much of the ripple the meter is able to show if it's some cheap POS...)
                              Btw, the pictures of that PSU is what you should have started with.
                              It's not so much a PSU but more like a fucking disaster, it's amazing the computer has not been more problematic as it is with that POS.
                              When you connect the new one up you might come to see that everything works well again...
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #55
                                The number of cores in a processor has no relationship to bus speed.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #56
                                  Any good way to show ripple? I have a 200MHz (I think) oscilloscope. I also have a 1000MHz oscilloscope module for my logic analyzer. I just have to find the time to try and fix it. I've heard of ripple current but not exactly sure what it is. I've searched for the meaning before. I see, from Google,
                                  Code:
                                  The most common meaning of ripple in electrical science is the small unwanted residual periodic variation of the direct current (DC) output of a power supply which has been derived from an alternating current (AC) source. This ripple is due to incomplete suppression of the alternating waveform within the power supply.
                                  What does that mean though? residual periodic variation of the direct current output...does that mean the output voltage varies on a cap?
                                  When it says derived from an AC source...does that just mean the AC source isn't completely filtered out? I thought caps allowed AC through and blocked DC. They'd charge up and when the circuit path was "broke", they'd discharge, supplying DC voltage.
                                  Okay. I just never realized that a power supply could be "flaky". I figured they either worked or didn't. I guess I just never thought about it. I wonder how many times I had a flaky power supply and because the PSU tester showed the voltages as good, I just assumed that wasn't the problem.
                                  That's what I'm hoping. If not, I'll start with the caps around the CPU and see what the ESR / capacitance for them are.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #57
                                    Okay, so with DDR2 type RAM, I divide the effective data rate by 2 to get the base frequency.
                                    How am I supposed to get the base frequency of the FSB? If I multiply the base frequency of the FSB by the multiplier, I get the CPU speed. But how do I calculate that FSB base frequency?
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #58
                                      Well if you have a scope I'm not sure why we are having this discussion with all of the rest of the FUD about RAM clockspeed related to how many CPU cores which is just completely bananas.
                                      The ATX spec states that for the 12v line you may have a maximum of 120mV ripple.
                                      And it's 50mV for 5v and 3.3v (easy to remember since it's a division of the major voltage )
                                      So start up the comp again on the shit PSU if you are not afraid to kill it, connect the GND to any negative and the probe to 12v.
                                      Set the scope for maybe 1ms and half a volt per division and coupling to AC, if the screen isn't already filled with shit then zoom in and see how much you've got
                                        • 31204
                                        ripple current is the current (at the rated frequency) that a capacitor can absorb / release.
                                        • Spork Schivago
                                          • Mar 2012
                                          • 4734
                                          #60
                                          Okay. I never really had the time to learn how to use the scope so I don't really use it often. When I started making some simple circuit boards, I busted it out and saw how some of the components talked to each other, which was kind of cool.
                                          For the RAM clock speed and the FSB base frequency, I'm just trying to understand it. I guess we kind of gotten off track with the original topic though.
                                          For the scope part, that will show me the ripple?
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • RossMoodley1967
                                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                            by RossMoodley1967
                                            Hello
                                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                            03-01-2024, 06:07 AM
                                          • karlp028
                                            MSI Z390-A PRO missing VCORE voltages
                                            by karlp028
                                            I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                            06-23-2025, 01:25 AM
                                          • lol999
                                            Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                            by lol999
                                            Motherboard after starting show Q code 00.
                                            No shorts on any rail ( at last I can't finde any)
                                            All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                            Nothing get hot, PSU starting, all lights came ON....
                                            One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                            After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                            This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                            01-21-2024, 02:25 PM
