Changing voltages.
  • dmill89
    • Dec 2011
    • 2534
    Re: Changing voltages.
    Originally posted by Spork Schivago
    I checked the MSDS for the Un-Du. It seems to contain Naphtha. I believe Naphtha is used in paint thinners. So perhaps they're the same thing? I bet the paint thinner / turpentine / white spirits would be cheaper than this stuff.
    From the MSDS it sounds like it is just Ronsonol (lighter-fluid) repackaged with ridiculous mark-up (looks like Un-Du is $12 for 4oz., 8oz. of Ronsonol is $2-3).
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #222
      Originally posted by diif
      I doubt the tiny quantity used would make a difference, if it was being used all day I don't think it would be good for anyone.
      To me, if something dilsolves something or has that smell about it then its probably not a good idea to breathe the fumes in/get on the skin.
      Thank you. At first, I wasn't worried too much about it because of how little we used it here, but then she said she uses it at work all the time now to remove the adhesives off the shelves. I thought maybe it'd be something to check in to. I know I'm probably just overreacting, you know? First time with my wife being pregnant and just being overly cautious about everything!
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • Spork Schivago
        • Mar 2012
        • 4734
        #223
        Originally posted by stj
        dont forget to clean off the cleaner with IPA before you use the MX4.
        I've been using AS5. Should we switch to Arctic MX-4? This is the second time now I've seen someone reference MX-4.
        I didn't clean it off. My wife didn't clean it off either. Should we remove the heatsinks, remove the AS5 with isopropyl and then reapply the AS5 and put the heatsinks back on? Or would we be okay accidently leaving it on? Next time, I'll be sure to remember to remove it with IPA.
        • Spork Schivago
          • Mar 2012
          • 4734
          #224
          Originally posted by dmill89
          Better yet use Acetone (the stuff from the hardware store, not nail-polish remover which is diluted and has additives), it won't leave a residue like paint-thinner, Naphtha, kerosene, etc.
          The probably was Isopropyl wasn't removing the pink stuff. I have some Acetone over at my mum's but didn't try it because I've never really noticed a difference between the two. Do you think the Acetone would have worked better than the Isopropyl Alcohol? I've never really had a problem with the Isopropyl though, at least with most of the thermal compound, so I never really had a reason to try something else until today. Thanks.
          • Spork Schivago
            • Mar 2012
            • 4734
            #225
            Yeah. If I was reading the datasheet correctly, the only active ingredient in there is Naphtha. So wouldn't it just be Naphtha in a bottle marked Un-Du and instead of 14$ a gallon, it's freaking 10$ for 4 freaking ounces? I told my wife she shouldn't buy it anymore and we should just try the one gallon of Naphtha.
              • 30978
              MX4 is MUCH cheaper than AS5,
              as for your heatsink, if it seems o.k. dont bother this time,
              but stuff like white spirit leave a greasy layer.
              • Spork Schivago
                • Mar 2012
                • 4734
                #227
                When you say cheaper, do you mean price wise, quality wise or both?
                • dmill89
                  • Dec 2011
                  • 2534
                  Acetone tends to work a little better than Isopropyl Alcohol in removing thermal compound (both work, but Acetone tends to be a little quicker and require less effort/scrubbing). That being said that "pink stuff" is wax and is generally a pain to remove. Out of curiosity sparked by this thread I found an old gpu cooler with that pink wax and did a little experimenting. I found the following, Isopropyl Alcohol didn't do anything, Acetone took some off but only thin layers (would require several applications), Ronsonol (Naptha) worked pretty well, but had to soak in for a few minutes, the best thing I found was Remington Rem Action Cleaner cleaner this took off the pink wax in a matter of seconds with little to no effort and left no noticeable residue (though I'd still clean it afterward with alcohol or acetone just to be safe). If you know anyone with firearms they may have some of this laying around, if not it is about $9 for a 10.5oz areosol at walmart.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #229
                    Thank you. This Un-Du must be more than just Naphtha. This Un-Du worked much like how you're describing the Remington Rem Action Cleaner. It took a few seconds and just dissolved it with no work involved. We just brushed it over it and it was gone.
                    For that Remington Rem Action Cleaner, how well does that work in extreme cold conditions, or don't you know? I'm talking -20F or colder. We used to use something called CLP albeit I never had a chance to try it out in the extreme cold. I heard during one of the wars, I think it was the Germans, who taught us we could mix gasoline with certain cleaning solutions for our rifles to prevent them from freezing.
                    • dmill89
                      • Dec 2011
                      • 2534
                      Never tried it in extreme cold, so I can't really say. The freezing point is -76F (according to the MSDS) so I imagine it would work a low temperatures but don't have any first hand experience. Ingredients listing on the MSDS is the very board "petroleum distillates" which doesn't give much useful info and CO2 as a propellant.
                        • 30978
                        Acetone is a big no for me,
                        it will take the colours off resistors, the print off caps etc.
                        as for MX-4 vs AS5, they perform around the same, but AS is Silver, and AFAIK MX-4 is Carbon.
                        so AS5 costs around 2 times more!
                        (and only comes in tiny tubes - big problem when your doing ps3's)
                        http://www.ebuyer.com/126410-arctic-...-5gram-as5-3-5
                        http://www.ebuyer.com/450905-arctic-...aco-mx40101-bl
                        btw, if you dont need the very best, MX-2 ceramic is even cheaper.
                          • 30978
                          that gun cleaner may be something like carb-cleaner.
                          i hope it's not Xylene - nasty shit that is.
                          • Capacitorial
                            Powersupply has all the voltages - Monitor still no power
                            by Capacitorial
                            Hello guys,
                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                            The weird thing is, that the Power LED is powered over the TCON board.
                            On The TCON...
                            12-28-2024, 02:12 PM
                          • gjgib
                            Help reading schematic voltages input/output
                            by gjgib
                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                            05-06-2024, 08:11 PM
                          • RossMoodley1967
                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                            by RossMoodley1967
                            Hello
                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                            03-01-2024, 06:07 AM
                          • karlp028
                            MSI Z390-A PRO missing VCORE voltages
                            by karlp028
                            I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                            06-23-2025, 01:25 AM
                          • lol999
                            Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                            by lol999
                            Motherboard after starting show Q code 00.
                            No shorts on any rail ( at last I can't finde any)
                            All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                            Nothing get hot, PSU starting, all lights came ON....
                            One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                            After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                            This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                            01-21-2024, 02:25 PM
